Any elegant way of text string handling?
+ Reply to Thread
Results 1 to 6 of 6
    Default Any elegant way of text string handling?
    Hello.
    I'm making a LCD clock which uses 1602 LCD. I want to display day of the week according to RTC reading.
    However, since there are no string variables, I have to make an array, in which I put ASCII codes of letters to be written, and read them accordingly:
    DNAME[1]=77:DNAME[2]=111: DNAME[3]=110 'Mon
    DNAME[4]=84:DNAME[5]=117: DNAME[6]=101 'Tue
    DNAME[7]=87:DNAME[8]=101: DNAME[9]=100 'Wed
    DNAME[10]=84:DNAME[11]=104: DNAME[12]=117 'Thu
    DNAME[13]=70:DNAME[14]=114: DNAME[15]=105 'Fri
    DNAME[16]=83:DNAME[17]=97: DNAME[18]=116 'Sat
    DNAME[19]=83:DNAME[20]=117: DNAME[21]=110 'Sun
    TAVAKI:
    FOR CNT=1 to 21 STEP 3
    lcdout $fe, $01, DNAME[CNT], DNAME[CNT+1],DNAME[CNT+2]
    PAUSE 1000
    NEXT CNT
    GOTO TAVAKI
    Here it works, because I've trimmed all weekday names to same length. But say if I want to have different length texts, I have to add another array, which will hold the length of the words. This is very weird, is there any means to avoid this?
    Default Re: Any elegant way of text string handling?
    there are many ways that have be discussed on this forum over the years
    try a forum search "embedded string" or "null terminated"
    Well I've checked and there are some posts, with ASM code and referring to non-existing pbpcommunity domain.
    So as I can see, the easiest method is to use an external EEPROM or chip's built in one (if there are not much strings to be used) and build system like this - say first 32 bytes (16 words) of eeprom contain entry addresses of separate strings, and to read the stirng we launch a routine, which will start reading eeprom at X address till it reaches value, stored in next string entry address area. Code (for reading single string) should look like this
    READ 0, startval ' read entry address of 1st string
    READ 2, nextval 'read entry address of next string
    nextval=nextval-startval 'determine string length
    LCDOUT $fe,$2 'set LCD start position to needed area (1st line in this case)
    FOR A=1 to nextval 'start the loop
    READ A,TXT 'read into variable
    LCDOUT $fe,TXT, $14 "Output char and move cursor to next position
    next
    Not the best, but I guess better than with dealing with ASM.
    Why not use a termination character, say 0 terminated string.
    So you only have to check if you reached the 0 value in the data area that your message is stored.
    This is what Richard suggested. No calculations required.
    Nice idea, but I have to have all entries for next string marked, so this makes no big difference.....
    It sure does...
    Think about it.
  1. Replies: 3
    Last Post: - 3rd December 2011, 23:48
  2. How to prepare text (lots of text) for HSEROUT ?
    Last Post: - 15th February 2010, 23:31
  3. Elegant "in circuit programming"
    By Ted's in forum General
    Last Post: - 1st September 2008, 00:42
  4. Interrupt handling on 16F628A
    By Mugelpower in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 00:20
  5. interrupt handling faster than if's?
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 27th October 2006, 02:25
