IR temp sensor
Results 1 to 6 of 6
Thread: IR temp sensor
    Oct 2010
    Default IR temp sensor
    Dear all,
    i need your help regarding the following code for the MLX90614 ir temp sensor.
    Finally i have some readings from the sensor at Object1 address $07.
    I do get the right temp value from the first 2 digits (XX) XX.YY
    For the second 2 digits (YY) XX.YY i see that numbers goes up to .49 and then the first two XX digits increase by one. It suppose XX change when the YY goes up to .99
    Could anyone help please?
                     '*  Name    : MLX90614.BAS                *
                     '*  Notes   : 4D Systems - IR TEMP SENSOR *
    #IF __PROCESSOR__ = "18F26k22"
    @ ERRORLEVEL -306 ; this command prevents the compiler to give you a notice of   *
                      ; crossing page boundary - make sure bits are set              *
      #CONFIG   ;  The PBP configuration for the PIC18F26K22 is:
         CONFIG FOSC     = HSHP                   ; HS oscillator (high power > 16 MHz)
         CONFIG PLLCFG  = OFF                     ;Oscillator used directly
         CONFIG PRICLKEN  = ON                  ;Primary clock enabled
         CONFIG FCMEN     = OFF                  ;Fail-Safe Clock Monitor disabled
         CONFIG IESO      = OFF                      ;Oscillator Switchover mode disabled
         CONFIG  BOREN    = SBORDIS      ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
         CONFIG  WDTEN    = ON           ; WDT is always enabled. SWDTEN bit has no effect
         CONFIG  WDTPS    = 32768        ; 1:32768 ---> HERE enable the watchdog timer with a 1:32768 postscale
         CONFIG  PWRTEN   = ON
         CONFIG  HFOFST   = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
         CONFIG  MCLRE    = EXTMCLR      ; MCLR pin enabled, RE3 input pin disabled
         CONFIG  LVP      = OFF          ; Single-Supply ICSP disabled
         CONFIG  XINST    = OFF          ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
         CONFIG  DEBUG    = OFF          ; Disabled
         CONFIG  CP0 = OFF             ; Block 0 (000800-003FFFh) not code-protected
         CONFIG  CP1 = OFF             ; Block 1 (004000-007FFFh) not code-protected
         CONFIG  CP2 = OFF             ; Block 2 (008000-00BFFFh) not code-protected
         CONFIG  CP3 = OFF             ; Block 3 (00C000-00FFFFh) not code-protected
         CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
         CONFIG  WRT0 = OFF            ; Block 0 (000800-003FFFh) not write-protected
         CONFIG  WRT1 = OFF            ; Block 1 (004000-007FFFh) not write-protected
         CONFIG  WRT2 = OFF            ; Block 2 (008000-00BFFFh) not write-protected
         CONFIG  WRT3 = OFF            ; Block 3 (00C000-00FFFFh) not write-protected
         CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
         CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
         CONFIG  EBTR0 = OFF           ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
         CONFIG  EBTR1 = OFF           ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
         CONFIG  EBTR2 = OFF           ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
         CONFIG  EBTR3 = OFF           ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
         CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    #ELSE
        #MSG "Wrong Processor selected!"
    #ENDIF
    define  OSC 16
            INCLUDE "modedefs.bas"
            INCLUDE"ALLDIGITAL.pbp"
    OSCCON     = %01110000   ; 16Mhz
    '                            INITIALIZE RAM                                    |
    initialize:
                    CLEAR
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %10000110
    '----------------------- At start all PORTS LOW -------------------------------|
    PORTA = 0            'make low all ports at A range                            |
    PORTB = 0            'make low all ports at B range                            |
    PORTC = 0            'make low all ports at C range                            |
    '-------------------------- COMPARATORS OFF -----------------------------------|
    CM1CON0.7 = 0 'Disable comparator1                                             |
    CM2CON0.7 = 0 'Disable comparator2                                             |
    Timeout     CON 2000
    addr        var byte
    reg         var word
    ORANGE      var LATA.2     ' ORANGE LED TO INDICATE POWER ON OF THE PIC
    BLUE        var LATC.0     ' BLUE LED TO INDICATE SENSOR WOKRING CONDITION
    SDA         var portc.1    ' DATA PIN
    SCL         VAR portc.2    ' CLOCK PIN
    sign        var byte       ' for + or -
    TEMP        var word       ' this is the word variable for TEMP
    temperature var word       ' for result and output to lcd
    TEMPIR      var word       ' set a variable tempir
    Remainder   var word       ' Get the remainder = tempir//50
    Sign_Bit    VAR Temp.Bit14 ' Sign-Bit for +/- Temp. 1 = Below 0 deg C
    SignCold    CON 1          ' Define Sign Cold = 1
    '*----------------------- | EUART 1 Configuration  | --------------------------|
            DEFINE HSER_SPBRG 25  ' 38400 Baud @ 16MHz, 0.16%
            SPBRGH = 0
    '                          [ LCD Initialization ]                              |
    gosub initlcd
    start:
    gosub object
    goto start
    '                          Measure object temp                                 *
    object:
    reg    = $07             ' based on the datasheet $07 is the object's temp
    addr   = %10110100       ' $B4  binary value: %10110100
    i2cwrite SDA, scl, addr  ' shift the address B4, 8 bits where LSB is W = 0
    i2cwrite sda, scl, reg   ' register is $07
    addr   = %10110101       ' $B5  Binary value: %10110101
    i2cwrite sda, scl, addr  ' shift the address B5, 8 bits where LSB is R = 1, clock idles low
    i2cread SDA, SCL, 0,reg,[temp.lowbyte,temp.highbyte] ' reg = $07
    Sign   = "+"
    'shifts 8 bits to the left
    tempir = temp.highbyte << 8
    tempir = tempir + temp.lowbyte   ' add the temp.lowbyte
    temperature  = tempir/50         ' based on the manual we need to divide by 50 or 0.02
    temperature  = temperature - 273 ' subtract 273 for Degree in C,actually is 273,15
    remainder    = tempir//50    ' i think this gives me a wrong result or it may need some better maths to get the right value.
    gosub display
    '                          Display the parameters                              *
    display:
    hserout [$73,$00,$02,$12,$00,$ff,"TEMP =", Sign,dec2 temperature,".",dec2 remainder,"*C",00]
    Hserin  timeout,error,[wait(6)]
    hserout [$73,$02,$06,$10,$ff,$00,"RAW IR = ",dec tempir,00]
    hserout [$73,$02,$08,$10,$ff,$00,"T HI = ",dec temp.highbyte,00]
    hserout [$73,$02,$0A,$10,$ff,$00,"T LOW = ",dec temp.lowbyte,00]
    error:
    high blue
    PAUSE 10
              ' FIRST TIME BOOTUP: We give plenty of time for tbe LCD '
    initlcd:
    HSEROUT[$55]      ' uOLED Initialize this is the 'U' character of autoband rate to LCD
    hserout[$56,$01]  ' this is the Version info --> '01 10 17 28 28   -->> "(("
    Hserin  timeout,error,[wait(1),wait(16),wait(23),wait(40),wait(40)]
    PAUSE 1000
    HSEROUT [$45]    ' clear the LCD
    Hserout[$4F,$01] ; Set Transparent-Opaque Text - 4Fhex
    high orange
    As a last thought, i would like to add a sign depends on the bit which is responsible to + or -.
    IF sign_Bit = signCold THEN Change_Sign ' If Sign_Bit = 1, it's below "0" deg C
    '                        If it is cold change to "-"                           *
    Change_Sign:
    Sign   = "-"                     ' Display - symbol for negative temp
    Default Re: IR temp sensor
    Yeah, when you do x= y // 50 it will do a divide by 50 and then give you the remainder which can't be more than 49, right?
    If you first multiply the raw value by 2 it means you can then divide by 100 (instead of 50) and do modulo 100 (that's the // operator) to give you two digits after the decimal point. This won't increase the resolution, you'll still have 50 "steps" to the right of the decimal point but they will range from 0 to 98 instead of from 0 to 49.
    Oct 2010
    Thanks Henrik,
    i will try it out now.
    In the mean time i was playing with the ERPROM registers in order to assign the sign bit. I will leave that on a side and try your advice.
    Sep 2009
    Can you display raw register data?
    So you can compare result of your calculation with register value. Maybe sensor have some drift issues.
    Oct 2010
    Henrik,
    it worked!!!
    i did the following.
    remainder = (TEMPIR*2)//100
    It looks like it worked as expeced.
    Now i'm focusing to get the sign bit.
    Oct 2010
    i can display values depends on the temp...yes.
    like 14971. When i divide that by 50 it give me 299,42.
    Then i seperate the 299 and the 42 as remainder.
    The calculation then is : 299 - 273 in order to get the value in Degree C. The problem is that i do not have the right knowledge to divide that by 273,15. But that is ok for me at the moment.
  1. Dodge temp sensor
    By Art in forum mel PIC BASIC Pro
    Last Post: - 19th August 2015, 16:18
  2. TMP05 Temp Sensor
    By RichG in forum mel PIC BASIC Pro
    Last Post: - 8th February 2009, 04:33
  3. Using WDT as a Temp Sensor?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 20th June 2006, 18:55
  4. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 16:55
  5. Temp sensor problem
    Last Post: - 14th June 2006, 15:49
