I2CRead & I2CWrite not working as expected
+ Reply to Thread
Results 1 to 30 of 30
    Default I2CRead & I2CWrite not working as expected
    I can't seem to Write properly to an I2C device
    I can't seem to Read properly back from an I2C device
    My I2C Serial EEPROM doesn't always save my data
    I can't Write to the Registers on my I2C Real Time Clock, ADC etc
    Check your I2CRead and IC2Write statements...
    Do you have any CONSTANTS in the device address?
    If so, your code is flawed... remove the constants and put in VARIABLES in their place...
    Example: Write to location 8 on a 24LC32... these are NOT CORRECT...
    I2CWrite SDA,SCL,$A0,$08,[DataA]
    I2CWrite SDA,SCL,$A0,8,[DataA]
    I2CWrite SDA,SCL,$A0,$0008,[DataA]
    I2CWrite SDA,SCL,$A0,%00001000,[DataA]
    I2CWrite SDA,SCL,$A0,%0000000000001000,[DataA]
    Example: Write to location 8 on a 24LC32... this is CORRECT...
    I2CAddress=8
    I2CWrite SDA,SCL,I2CDevice,I2CAddress,[DataA]
    where previously I2CAddress has been defined as a WORD, and I2CDevice has been defined as a BYTE and preloaded with $A0.
    Remember that the type of VARIABLE I2CAddress must match the requirement for the device you are addressing... eg it's a WORD for devices like a 24LC32 or 24LC64, but it's a BYTE for other devices like a 24LC16 or DS1307 RTC. Check your device Datasheet.
    France
    Default Use of the last label at the end of a I2CWRITE
    Always and again Thanks Melanie for the support.
    Just one question about the "label" at the end of a I2CWRITE command
    I see in the help menu this sentence "If the optional Label is included, this label will be jumped to if an acknowledge is not received from the I2C device. "
    My question :
    Could we say this is a GOTO or a GOSUB command ?
    I was "swimming" when I was building a prototype WITHOUT the I2C module
    (TV RECEIVER MODULE) connected ....
    Program was working ... let say 6 times ... and seems to go in a strange loop
    ... I would say a "dead loop" .... I use a Blinking led to follow the process !
    I have removed this label, now it is working
    Label is a sub routine with a return ...
    I am sure I am wrong somewhere !
    thanks in advance
    Francois
    Quote Originally Posted by F1CHF View Post
    My question :
    It would be a GOTO command. I suppose it's a question of how you read the manual.
    If the manual said 'If the optional Label is included, this label will be ----CALLED---- if an acknowledge is not received from the I2C device', then I would reasonably assume that it would be a goto...
    But, the manual says 'this label will be ----JUMPED TO---- if an acknowledge....'. That tells me it's a GOTO.
    If all else fails, check your .lst file and see what the compiler puts in there for you. Make a few 'special' labels so you can follow yourself thru the .lst file and search them in the file. You should be able to find what you need.
    France
    Thumbs up I2Cwrite error label
    OK good, let assume this is a GOTO, that will explain my application
    was going on a dead loop with a return ..
    I must try to find a PBP Help File in FRENCH or read carrefully !
    thanks for this help
    Francois
    good luck to find it in french... unless you want to try GooGLE or else on-line translator that will'nt be better
    Default Re: I2CRead & I2CWrite not working as expected
    SDA var PORTA.1
    SCL var PORTA.2
    T1 var byte
    T1=15
    I2CAddress var word 'I2C address
    I2CDevice var byte 'I2C device add
    i2CDevice=$A0
    I2CAddress=8
    I2CWrite SDA,SCL,I2CDevice,I2CAddress,127
    i2cread SDA,SCL,I2CDevice,I2CAddress,T1
    LCDOUT $FE,$c0, "value ", dEC T1
    stop
    Ports are set to digital, analog and comparators turned off. 4.7K resistors in place, 24C32 chip is brand new and authentic.
    Only VDD/VSS and SDA/SCL pins are used, others are left floating, according to datasheet.
    The interesting thing is, that i2cread returns nothing - I mean, I added T1=15 just for test, so that 15 is displayed, instead of 127
    whole i2croutine doing nothing?
    France
    hello
    start a TEST first to see if your I2C unit is OK
    let go here
    https://playground.arduino.cc/Main/I2cScanner/
    francois
    let go here
    or read the data sheet again and work out the consequences of floating address pins on the device address
    From the datasheet:
    DEVICE/PAGE ADDRESSES (A2, A1, A0): The A2, A1 and A0 pins are device address
    inputs that are hard wired or left not connected for hardware compatibility with
    AT24C16. When the pins are hardwired, as many as eight 32K/64K devices may be
    addressed on a single bus system (device addressing is discussed in detail under the
    Device Addressing section). When the pins are not hardwired, the default A2, A1, and A0
    are zero.
    WRITE PROTECT (WP): The write protect input, when tied to GND, allows normal write
    operations. When WP is tied high to VCC, all write operations to the upper quandrant
    (8/16K bits) of memory are inhibited. If left unconnected, WP is internally pulled down to
    GND.
    The A2, A1, and A0 pins use an internal proprietary circuit that biases them
    to a logic low condition if the pins are allowed to float.
    to my surprise i found the 24c32 on my ds3231 module did not behave as expected when the resistor block [circled] was removed
    to conserve energy for a battery device
    Name:  Screenshot 2021-10-08 164704.jpg
    the address was still 0xAE, contrary to the datasheet , so i looked at a data sheet from another manufacturer, where for a 24c32n
    they did not describe this address pin biased low behavior for their version
    to ensure 0xA0 the pins needed to be grounded
    so how sure are you that the datasheet matches the chip?
    its an easy test
    I will try grounding. I will also hook up scope to see what happens.
    I do have pull up resistors in place for SDA/SCL pins.
    Regarding how I know about datasheet?
    I bought this IC from digikey, and downloaded datasheet from the SKU page
    This is genuine atmega part.
    It could be that a static discharge killed the pull down circuitry, so the floating pins may not be a $A0 anymore.
    I had in the past various issues with static and decided to be almost paranoid with this thing. Have anti-static mate on the floor, also on the bench and I earth my self too. Of course the soldering iron is earthed too by a tens of kΩ range resistor.
    Chips from various vendors also have differences and datasheet may not cover that. Richard is right.
    Here I connected the scope.
    This is how this code looks:
    My scope (Hantek DSO2D10) Has I2C decode function, but I can't get it running properly.
    mainloop:
       For B0 = 0 To 15 step 2
         I2CREAD DPIN,CPIN,$A0,B0,X
         lcdout $fe, $1, dec b0, " ", dec X
       Next B0
    Goto mainloop
    Oh by the way, I swapped chip with 24C04N - no difference.
    I set up I2C capture and it looks suspicious.
    The 1st entry at "data" is actually and address of the chip
    and 3rd entry - the address I'm sending to it for reading
    but I'm getting no response?
    yet still another pointless snippet , with nothing defined
    you persist in using incorrect syntax , it should be
    I2CREAD DPIN,CPIN,$A0,B0,[X ]
    proper code, not snippet with undefined rubbish, its not hard
    #CONFIG             __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_OFF &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
    ;pic16f1825
    DEFINE OSC 32
    OSCCON=$70
    ANSELA=0
    ANSELC=0
    trisa.0=0
    DEFINE I2C_SLOW 1
    ANSELA = 0
    a Var Byte
    addr Var word
    ar Var Byte
    SCL var Porta.2
    SDA var Porta.1
    lata.0=1
    DEFINE DEBUG_REG PORTA
    DEFINE DEBUG_BIT 0      ;  if not used for pwr
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0
    pause 2000
    Debug 13,10,"Start",13 ,10
    a=20
    addr=$200
    I2cwrite Sda,SCL,$a0 ,addr,[a]
    pause 10
    addr=$200
    I2CREAD Sda,SCL,$a0 ,addr,[ar ]
    debug 13,10,sdec ar
    what a write looks like
    what a read looks like
    Well, if there's syntax error, compiler should warn about it, right?
    I tried to add brackets and now it starts working, but in the weird way.
    I2CWRITE DPIN,CPIN,$A0,B0,[127]
    Writes 127 into eeprom
    but if I substitute variable there, no matter, byte or word
    after reading, I'm getting zeroes.
    no the compiler produces code to I2CREAD DPIN,CPIN from device $A0 @eeprom address B0,X then read nothing as asked for
    there is no error
    produce a compliable example that demonstrates the problem
    DPIN Var PORTA.2       ' I2C data pin
    CPIN Var PORTA.1       ' I2C clock pin
    B0   Var word
    B1   Var byte
    B2   Var byte
    X var byte
    x=0
       For B0 = 0 To 15
       b1=b2
         I2CWRITE DPIN,CPIN,$A0,B0,[99]
         Pause 10        '
       Next B0
    mainloop:
       For B0 = 0 To 15
         I2CREAD DPIN,CPIN,$A0,B0,[X]
       Next B0
       Goto mainloop
    CPIN Var PORTA.1       ' I2C clock pinB0   Var wordB1   Var byteB2   Var byteX var bytex=0   For B0 = 0 To 15       b1=b2     I2CWRITE DPIN,CPIN,$A0,B0,[99]       Pause 10        'pause 100    Next B0mainloop:   For B0 = 0 To 15        I2CREAD DPIN,CPIN,$A0,B0,[X]       lcdout $fe, $1, dec b0, " ", dec X      pause 1000   Next B0    Goto mainloop
    so we guess whats wrong then
    DPIN,CPIN are analog
    the chip[undefined] has no porta
    the vcc is too low
    the clock is too fast
    the lcd is not setup properly
    the config settings are incorrect
    the interrupt in the unseen part of the code is ruining the timing
    what's the point
    this
    '*    pic16f1825      :  eprom addr =$a0
    DEFINE OSC 32
    OSCCON=$70
    ANSELA=0
    ANSELC=0
    trisa.0=0
    DEFINE I2C_SLOW 1
    ANSELA = 0
    B0   Var word
    X var byte
    SCL var Porta.2
    SDA var Porta.1
    lata.0=1
    DEFINE DEBUG_MODE 0
    pause 2000
    clear
    For B0 = 0 To 15
     I2CWRITE sda,scl,$A0,B0,[99]
     Pause 10        '
    Next B0
    mainloop:
        For B0 = 0 To 15
         I2CREAD sda,scl,$A0,B0,[X]
         debug 13,10, dec b0, " ", dec X
        Next B0
    Goto mainloop
    produces as expected this
    Start
    0 99
    1 99
    2 99
    3 99
    4 99
    5 99
    6 99
    7 99
    8 99
    9 99
    10 99
    11 99
    12 99
    13 99
    14 99
    15 99
    Pins are configured properly, LCD also working fine.
    TRISA=%00000000  'SET A TO OUTPUT
    TRISC=%00001101
    TRISB=%00011000
    ANSELH=%00000000   ' ADC OFF B
    ANSEL=%000000000 ' turn off ADC
    ADCON1=%10000000  'adc justify
    OSCCON=%01110101  'SET FREQUENCY TO 8MHZ
    WPUB=%00000000    'turn off Pullups
    CM1CON0=0         'DISABLE COMPARATORS
    CM2CON0=0
    This code works, if there is a number [99] or whatever in the write loop
    If I modify that part to look like
    I2CWRITE DPIN,CPIN,$A0,B0,[B1]
    or any other variable instead of B1
    all zeros get written into there, instead of actual variable value.
    what code ?
    minimal, complete and verifiable example MCVE , its not hard
    this code
    '*    pic16f1825      :  eprom addr =$a0   #CONFIG
    DEFINE OSC 32
    OSCCON=$70
    ANSELA=0
    ANSELC=0
    trisa.0=0
    DEFINE I2C_SLOW 1
    ANSELA = 0
    B0   Var word
    b2 var byte
    X var byte
    SCL var Porta.2
    SDA var Porta.1
    lata.0=1
    DEFINE DEBUG_MODE 0
    pause 2000
    clear
    For B0 = 0 To 15
      b2=99+b0
     I2CWRITE sda,scl,$A0,B0,[b2]
     Pause 10        '
    Next B0
    mainloop:
        For B0 = 0 To 15
        Next B0
    Goto mainloop
    Start
    0 99
    1 100
    2 101
    3 102
    4 103
    5 104
    6 105
    7 106
    8 107
    9 108
    10 109
    11 110
    12 111
    13 112
    14 113
    15 114
    The code which I've posted, which writes 99 into eeprom.
    I replace 99 with any other value - it works.
    I put variable name into brackets - it writes zeroes into eeprom.
    no matter what type of variable or what value do it has.
    Here is full complete code.
    ;----[16F886 Hardware Configuration]--------------------------------------------
    cfg1 = _INTRC_OSC_NOCLKOUT    ; INTOSCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    cfg1&= _WDT_ON                ; WDT enabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_OFF             ; RE3/MCLR pin function is digital input, MCLR internally tied to VDD
    cfg1&= _CP_OFF                ; Program memory code protection is disabled
    cfg1&= _CPD_OFF               ; Data memory code protection is disabled
    cfg1&= _BOR_OFF               ; BOR disabled
    cfg1&= _IESO_ON               ; Internal/External Switchover mode is enabled
    cfg1&= _FCMEN_ON              ; Fail-Safe Clock Monitor is enabled
    cfg1&= _LVP_OFF               ; RB3 pin has digital I/O, HV on MCLR must be used for programming
    cfg1&= _DEBUG_OFF             ; In-Circuit Debugger disabled, RB6/ICSPCLK and RB7/ICSPDAT are general purpose I/O pins
      __CONFIG _CONFIG1, cfg1
    cfg2 = _BOR40V                ; Brown-out Reset set to 4.0V
    cfg2&= _WRT_OFF               ; Write protection off
      __CONFIG _CONFIG2, cfg2
    'chip configs
    TRISA=%00000000  'SET A TO OUTPUT   1=input
    TRISC=%00001101   'set half C for in/out
    TRISB=%00011000   'set PortB to output
    ANSEL=%000000000 'configure PortA as digital except first 2
    CM2CON0=0         'SAME HERE
    'CCP1CON=%01000000 ' configure pwm
    'PSTRCON=%00010110 'disable C pwm
    DEFINE OSC 8
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    'lcd config
    pause 200
    ' Set LCD Data port
    DEFINE LCD_DREG PORTC
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 1500
    DEFINE LCD_DATAUS 44
    define i2c_slow 1
    B   Var word
    B1   Var byte
    B2   Var byte
    For B = 0 To 15
      b1=99+b
     I2CWRITE dpin,cpin,$A0,B,[b1]
     Pause 10        '
    Next
    mainloop:
       For B = 0 To 15
         I2CREAD DPIN,CPIN,$A0,B,[b2]
         lcdout $fe, $1, dec b, " ", dec b2
       Next
       Goto mainloop
    And funny thing happens - the returned value of B2, as shown on display, is 114! for all 16 locations.
    looks like 1st loop executed before writing to EEPROM ?
    Maybe read routine is faulty?
    yes it is read routine - it reads eeprom only once.
    works perfectly on simulator
    had to increase some delays for slow old lcd
    ' Set LCD Data port
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    lcdout $fe, $1, "ready " ;added to prove lcd working
    I will use everything different - LCD, PIC, EEPROM and will check again...
  1. I2cwrite - I2cread
    Last Post: - 5th July 2006, 01:12
  2. Problem with I2Cread and I2CWRITE function
    By Tony85 in forum mel PIC BASIC Pro
    Last Post: - 6th June 2006, 20:03
  3. Problem with I2Cread and I2CWRITE function
    Last Post: - 6th June 2006, 18:32
  4. PFC8583 Connection and I2Cwrite I2cread!
    By uludere72 in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 13:32
  5. I2CWRITE and I2CREAD
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2004, 02:30
