12F683 _CONFIG problem
+ Reply to Thread
Results 1 to 11 of 11
    Alabama,USA
    Default 12F683 _CONFIG problem
    Started what I thought would be a quick turnaround to build a board to capture pulses from a rain gage and send to a master board. PicProto8 board and a 12F683 should do nicely. Why do things always have to get complicated? I want to use DT's to catch the pulses so I am assembling with MPASM.
    PROBLEM wiith compiler error _CONFIG. Nothing I have done will clear the error. Things are compileng fine on other devices.
    Error[122]c:\phpprog\wkfolder\12F683-1.asm 97:illegal opcode (_HS_OSC)
    Error[122]c:\phpprog\wkfolder\12F683-1.asm 97:illegal opcode (_CPD_OFF)
    DT's are commented out until first compile of simple code.
    Items check of for this type of problem.
    1. Does drop down minue display correct PIC? check!
    2. Does Assembler point to C:\Program Files\Microchip\MPASM Suite? check!
    3. Are config setting the same as in the MPASM INC file? check!
    I also tried commiting out PBP\12F683.INC config line as was Darrels advise on a simular issue years ago, no help.
    What have I missed?
    Wayne
    asm
    _CONFIG _HS_OSC & _MCLRE_OFF & _WDT_OFF & _PWRTE_OFF
    _CONFIG _CPD_OFF & _BOD_ON & _IESO_OFF & _FCMEN_OFF
    endasm
    ;include "DT_INTS-14"
    ;include "ReEnterPBP"
    ;Include "MODEDEFS.BAS"  ; Include for Shiftin/out modes
    ;     wsave  Var byte $20 SYSTEM
    ;     wsave1 var byte $A0 SYSTEM
         define OSC 20
         OPTION_REG = %01000000    ;Option register p.14DS  bit6-rising edge
         OSCCON =%00000000         ;External Res p.22DS
         ANSEL  = 0                ;All pins set to digital I/O     p.35datasheet
         CMCON0 = 7                ;comparators off
         VRCON  = 0
         ADCON0 = 0
         GPIO=   %00000000
         TRISIO= %00001100         ;sets GPIO.2 AND GPIO.3 as input others outputs
         IOC=    %00001100           ;interrupt on change on GPIO2 and GPIO3
         WDTCON= %01001            ;WDT control
         INTCON= %10001000         ;Interrupt control - GPIO Change Interrupt Enable p.15DS
    ;Variables
        Avar    VAR BYTE   ;general variable
        Bvar    VAR BYTE   ;general variable
        Cvar    var byte   ;general variable
    ;GPIO actioins
        LED          var GPIO.0 ;general I/O - output
      TX             var GPIO.1 ;Send all data to master unit - Output
      Raincount    var GPIO.2 ;counts rain in 1/10 inch per pulse -input
      Sendnow     var GPIO.3 ;input post to send data out after - input
    ; Gpio4&5 on resonator
    ;ASM
    ;INT_LIST  macro    ; IntSource,        Label,  Type, ResetFlag?
    ;        INT_Handler    INT_INT,  _MyISR,   PBP,  yes
    ;    endm
    ;    INT_CREATE    ; Creates the interrupt processor
    ;ENDASM
    ;@ INT_ENABLE   INT_INT
    Start:
        HIGH    LED
        pause   100
        low     LED
        pause   100
        goto start
    Last edited by MOUNTAIN747; - 29th August 2020 at 00:14. Reason: Edit-minor errors
    Default Re: 12F683 _CONFIG problem
    Try indenting the _CONFIG... lines between ASM and ENDASM.
    also is it
    _CONFIG or __CONFIG.
    also
    trying to place config on two lines that way will lead to overwrite error/warning
    at least in pbp3 not sure about dinosaur versions
    Alabama,USA
    thanks for responding. So I tried all above suggestions with no luck.
    IF (CODE ON ONE LINE)
    asm
    _CONFIG _HS_OSC & _MCLRE_OFF & _WDT_OFF & _PWRTE_OFF & _CPD_OFF & _BOD_ON & _IESO_OFF & _FCMEN_OFF
    endasm
    THEN iLLEGAL OPCODE (_HS_OSC) Character after Config illegal
    IF
    asm
    _CONFIG, _HS_OSC & _MCLRE_OFF & _WDT_OFF & _PWRTE_OFF & _CPD_OFF & _BOD_ON & _IESO_OFF & _FCMEN_OFF
    endasm
    THEN ILLEGAL CHARACTER (,) Character after Config illegal, with or without space after (,)
    IF
    @_CONFIG, _HS_OSC & _MCLRE_OFF & _WDT_OFF & _PWRTE_OFF & _CPD_OFF & _BOD_ON & _IESO_OFF & _FCMEN_OFF
    IF space after @ then Illegal opcode (_CONFIG)
    If i turn off MPASM assembler it WILL assemble OK. looks like interrupts will have to be in ASM is I can't get this worked out. Oh well, I need the practice.
    Why are you putting the pic config stuff in the assembler code sections?
    Here is one of my 12F683 configs..
    It should be right at the start of the program.
    #config
     __config _FCMEN_ON & _IESO_ON & _BOD_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_OFF & _WDT_OFF & _INTOSCIO
    DEFINE OSC 8			'Set PicBasic Pro processor speed to 8 Mhz (Must match oscillator value)
    INTCON = %10001000		'Internal oscillator
    OSCCON = %01110101		'Sets internal osc to 8 Mhz (Default) and stable
    CMCON0 = %00000111		'Comparators off
    TRISIO = %00101011		'Set Pins GPIO.0, GPIO.1 GPIO.3 & GPIO.5 as inputs
    ANSEL  = %00000000		'No Analog Inputs
    OPTION_REG = %01111111	'Global Enable Weak Pull Ups
    WPU    = %00000011		'Weak Pull Ups Enabled on GPIO.0 & 1
    I had to once, find the '683' INC or MAC file referred to by the assembler, look at the way the configs are expected in those files. I had to change my code to match the referenced/expected format/characters
    I've never seen it done like that before and I also use DT stuff and 16f83...
    Plus to the above, you still had one underscore instead of the correct two.
    I have used the following header for the 12F683 many times and never encountered any compiling problems. Try it.
    CMCON0 = 7 'comparators off
    ANSEL = 0 'all inputs digital, the adcin command automatically converts it to analog
    DEFINE OSCCON_1K 1 ' Set OSCCAL for 1K device to accurize osc
    OSCCON = %01110111 'Set osc to 8MHZ 12F683. Normally I leave this line out to default to 4MHZ
    @ DEVICE MCLR_ON, INTRC_OSC_NOCLKOUT, WDT_ON, BOD_OFF, PWRT_ON, PROTECT_ON
    START:
    I think you refer to an ancient version of PBP.
    Now we do not use this @ DEVICE MCLR_ON.....
    Current versions use this syntax:
    #config
     __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _BOD_OFF & _MCLRE_ON & _CP_OFF
    #endconfig
    Yes it is old. I think it's version 2.65 or something.
  1. 12F683 Light Dimmer Problem (SOLVED)
    By DavyJones in forum General
    Last Post: - 24th July 2020, 22:59
  2. PIC 12F683 and DS18B20 problem
    By slash819 in forum mel PIC BASIC Pro
    Last Post: - 28th February 2012, 18:31
  3. 12F683 Logic Output Problem?
    By shockwave in forum mel PIC BASIC Pro
    Last Post: - 25th February 2012, 19:48
  4. _config set change for pic12f683
    By nbrucew in forum mel PIC BASIC Pro
    Last Post: - 20th March 2010, 01:03
  5. 12F683 GPIO.3 problem
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 30th October 2009, 08:43
