ANNEX ESP8266 basic announcement and invitation - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 12
Results 41 to 58 of 58
  1. #41
    Default Re: ANNEX ESP8266 basic announcement and invitation
    try again , it had crashed. i,m using chrome and my android phone with no issues.
    i will try firefox . standby
    no i deleted firefox , its gone for now
  2. #42
    OK, it works now just fine. All 3 pages.
    Very interesting what that little board can do!
    Next to battery button there is this text box. The number is different in the 3 pages. Does this 5 digit number represent the battery level?
    no thats the amount of spare ram , i was looking to see if there are any memory leaks
    its the same on all pages . you can see the memory usage going up and down
  5. #45
    it crashed again , something is upsetting it
  6. #46
    Hope it is not me requesting update now and then.
    I am showing this to a friend.
    i think multiple serving pages and multiple users may confufu [trump speak] the thing, it might be over ambitious .
    you could not rely on it for anything important if you can't reach the reset button
  8. #48
    OK, we should not forget it is just a chip after all!
    I hope to try this application soon as I am waiting for some W25Q32BV parts to arrive then replace on my 8 ESP8266-01's.
    EN82fn
  10. #50
    Oct 2009
    Utah, USA
    There is a limited number of simultaneous websockets available.
    I seem to recall that 4-8 was the limit (can't find it right now in the docs) but if there are numerous people trying to access the demo then that could be a problem.
    But then in a typical instance you should not usually be putting that much demand on one little device to be servicing so many web connections at the same time.
    @richard
    one thing to do, if you can, is to monitor the serial output from the module and you will find that there is quite a bit of helpful feedback as various things happen, web connect/disconnect, etc., and also that is where the PRINT command sends its output to.
    (ie. open a terminal window like putty at 115200 baud on the same serial port used to flash the chip. There is also a built in serial terminal in the Flasher ToolKit but I prefer putty most of the time)
    Dwight
  11. #51
    dwight
    is there an easy way to get the menu bar back after disabling it in the config ?
    its a bit of a pain re flashing it all the time , tried uploading saved backup config.ini file but it doesn't seem to work
    ps the unit is running again , i forgot the laptop was powering it and turned the laptop off when i went to bed last night
  12. #52
    a word of warning . the device is not secure !!!
    you can add /config to the ipaddress and access the config menu , turn the menu bar back on , reboot then
    add your own pgm ,the results of which may not be nice who knows whats possible.
    mines not going back on the web
  13. #53
    Oct 2009
    Utah, USA
    I will copy/paste your questions over on the other forum and see if Cicciocb can answer.
    I'd encourage you to post questions over there also.
    dwight
    Dwight
  14. #54
    and if you are wondering . ipaddr/config bypasses protected access mode too. no password required in you go .
    its really not safe
  15. #55
    Oct 2009
    Utah, USA
    @richard,
    First I would say that most of this conversation should be moved over to the Annex forum. You will certainly NOT gain the benefit from any experienced ANNEX users on this forum (though I know there are world class programmers here).
    My intent was to invite people to join the conversation and start testing and trying out Annex.
    Bear in mind that this is the first public release of Annex.
    Certainly there will be things discovered and corrected.
    Cicciocb (and other contributors/testers) are very responsive and interested in correcting bugs and educating.
    Exposing your project immediately to the wilds of the internet may not be a fair test of its usefulness at this point.
    If your project is kept secure behind your own private network then you can have a lot of fun and create amazing projects with just a few lines of code.
    Annex is built on a solid foundation and it will only get better.
    I am sure that security will be addressed in due time.
    I suggest you test out and get used to Annex in general and as questions/comments come up post them on the Annex forum.
    @ everyone
    I encourage you all to give Annex a go and see what you think. Join the conversation and contribute.
    Again, this invite should in no way be taken as a negative for our beloved PBP.
    I see the EASY addition of WiFi connectivity to any of your PBP projects as a major benefit.
    This will be my last post here regarding Annex.
    Come on over and see for yourself!
    cheers
    dwight
    Dwight
  16. #56
    I bought some ESP boards, will give them try tomorrow and let you know....
  17. #57
    @dwight
    you have the wrong end of the stick , my only intent is to warn users of this forum that annex is
    not secure at this point
    just does not cut it without a fair and obvious disclaimer
    should read
    Exposing your project immediately to the wilds of the internet may not be SAFE
    you have just given unfettered javascript access to anyone
  18. #58
    Oct 2009
    Utah, USA
    OK, now I am backtracking on my statement about "last post here"
    I have to agree with you Richard.
    I think a chapter or warning about security risks (if it does not already exist over at the Annex site) is something that needs to be created and made obvious to new users.
    Hopefully Cicciocb will take note and address security for new (and old) users.
    I have several projects that I am working on but I don't plan on putting them out for others to access from the outside.
    This is one area (among many) that I am not knowledgeable about, other than I do know that exposing any system to the www is obviously extremely risky. As I am sure we have all gotten some notice or other that our personal data (financial, passwords, email, etc. etc.) have already been compromised.
    as they say "Its a jungle out there"
    regards
    dwight
    Dwight
  1. ESP8266-01 sharing my enthusiasm
    By Heckler in forum WiFi
    Last Post: - 6th February 2019, 16:27
  2. Replies: 1
    Last Post: - 19th July 2015, 03:38
  3. ESP8266 Memory Upgrade
    By MichelJasmin in forum Ethernet
    Last Post: - 19th July 2015, 03:35
  4. Moving from Basic Stamp and MIKROE basic to PicBasic PRO
    Last Post: - 6th March 2013, 05:27
  5. Replies: 5
    Last Post: - 17th January 2006, 19:26
Members who have read this thread : 23
