ADC keyboard and fast response to user input, possible?
Results 1 to 11 of 11
    Default ADC keyboard and fast response to user input, possible?
    I have and ADC input and two resistor network driving it, so when no button pressed, adc reads 255. On button 1 it returns 128 and on button 2 it returns 0.
    Both buttons are used to control same variable value, one increases it, another one decreases. User can either keep button pressed for variable to change, or use short presses to change it. The problem is that when user keeps button pressed, value should not increase too rapidly, user should be able to see changes on display and react in time. Very basically, code looks like this:
    MAINCODE:
    ADCIN 0,X
    IF X=128 THEN Y=Y+1
    IF X=0 THEN Y=Y-1
    GOSUB DISPLAY
    PAUSE 100
    GOTO MAINCODE
    This works fine if user presses button and keeps holding it - pause 100 statement ensures that variable does not change too fast. But here comes the problem - if user uses short press, he might press it right during PAUSE 100 statement, there will be no response from the system, so it will appear to him as lagging.
    The obvious fix would be to add a loop, and move PAUSE statement into it, with lower value, to reduce the lag, like this:
    MAINCODE:
    FOR Z=1 TO 100
    ADCIN 0,X
    IF X=128 THEN Y=Y+1
    IF X=0 THEN Y=Y-1
    IF X=255 THEN GOTO POINTCHECK
    PAUSE 1
    NEXT
    POINTCHECK:
    GOSUB DISPLAY
    GOTO MAINCODE
    But this also does not works properly - depending on how long user pressed the buttons, he's getting final result after he releases the key.
    Any ideas?
    Meanwhile, my nixie clock thread seems to be gone, so I'm posting picture of freshly developed model here - Runs completely on PBP, using 16F887, about 7K of code.
    OK
    Default Re: ADC keyboard and fast response to user input, possible?
    You didn't show how you're dealing with ADC; FRC? or are you using the ADCCLK and manually timing it? If I have issues where a quick read proves inaccurate, but a repeated or longer read shows accurate results, increasing the acquisition time almost always fixes things.
    There are no problems with ADC readings. It returns stable result.
    So what I need.
    if user presses key, there should be immediate response, but if he keeps it pressed, variable value should increase slowly, so he won't skip desired value.
    Bombay, India
    I would try something like this. Of course, you have to
    define var key
    K_None con 0
    K_Inc con 1
    K_Dec con 2
    AdcSub:
            ADCIN 0,x
            if x = $FF then key = K_None
            if x < 125 then key= K_Dec
            if x > 130 then key = K_Inc
    MAINCODE:
          Gosub AdcSub
          if key = K_Inc then
                y=y+1
                goto Mydelay
          if key = K_Dec then
                y = y-1
    Mydelay:
          Gosub Display
    goto Maincode
    So what I need.
    What's YOUR time lag for " immediate " ...
    as always, this is a highly subjective point of view ...
    Generally ... " immediate " means ... Interrupt !
    Knowing your general way of thinking ... that probably could be much slower than a few microseconds ...
    just consider the time spent between your thinking you must strike a key, and the act of striking the key, may be add the time needed to analyze the info that decide you to strike wich key , plus the time to define as a target the right key ... : interesting point of view, no ???
    " immediate ", you told ???
    LOL.
    Do you have at least TV remote at hands?
    when you press say channel up button, it immediately switches the channel (the actual change might occur a bit later, but here we're talking about system response), but if you keep it pressed, it will slowly cycle between channels.
    So I think I should do the code in the following way:
    Once key is pressed, start counter, say to 100, and do pause 1 inside it. If user releases key before counter hits 100, then do the action. But if user keeps key pressed and counter reached say 200, do the action, reset counter and start again.
    Some readings about the very powerful ... BUTTON command could be helpful, then ...
    but, of course, you can rewrite it by your own ...
    Maincode:
    Adcin 0,x
    if x=128 then y=y+1
    if x=0 then y=y-1
    if x=255 then pointcheck
    if x < 255 then maincode
    pointcheck:
    Gosub display
    goto maincode
    Could you post your clock schematic and code please? Maybe in a new thread..
    Yes I can, but there are no schematics, I've directly developed PCB. So I can post gerber files for it. It uses 16F887A chip, DS3231 for timekeeping, UC3843 with external mosfet for HV generation and also there are 30 pieces of MPSA42 transistors, which drive nixie tubes. Here how assembled PCB looks. (16F887 not installed in socket).
  1. another way to get a keyboard matrix to work off 1 adc pin
    By longpole001 in forum mel PIC BASIC Pro
    Last Post: - 4th May 2013, 01:23
  2. Use a PIC ADC like a fast interrupt comparator?
    By pxidr84 in forum mel PIC BASIC Pro
    Last Post: - 19th August 2011, 05:33
  3. Storing user input - whassall that about then?
    Last Post: - 19th July 2010, 15:08
  4. Replies: 17
    Last Post: - 13th June 2008, 21:33
  5. Reading multiple ADC channels FAST
    By lwindridge in forum mel PIC BASIC Pro
    Last Post: - 21st April 2004, 22:37
