Someone help me to simplify this
Results 1 to 5 of 5
    thrix's Avatar
    thrix Guest
    Question Someone help me to simplify this
    hi all... i manage to program my led matrix with the following code. is there any way to make it simpler?
    I VAR WORD 'DELAY FOR ALL COLUMN DISPLAY
    J VAR WORD 'DELAY FOR SHIFT LEFT NO 1 DISPLAY
    K VAR WORD 'DELAY FOR SHIFT LEFT NO 2 DISPLAY
    L VAR WORD 'DELAY FOR SHIFT LEFT NO 3 DISPLAY
    M VAR WORD 'DELAY FOR SHIFT LEFT NO 4 DISPLAY
    N VAR WORD 'DELAY FOR SHIFT LEFT NO 5 DISPLAY
    TRISA = 255
    TRISB = 0
    MAIN:
    FOR I = 0 TO 25
    GOTO LOOP
    loop:
    ' DISPLAYING AT ALL COLUMN
    PORTB = $7F ''''''''''''''''''
    LOW PORTA.4 ' END POINT '
    PAUSE 3 ' '
    HIGH PORTA.4 ''''''''''''''''''
    PORTB = $8
    LOW PORTA.3
    PAUSE 3
    HIGH PORTA.3
    PORTB = $8
    LOW PORTA.2
    PAUSE 3
    HIGH PORTA.2
    PORTB = $8
    LOW PORTA.1
    PAUSE 3
    HIGH PORTA.1
    PORTB = $7F 'STARTING POINT
    LOW PORTA.0
    PAUSE 3
    HIGH PORTA.0
    NEXT
    'SHIFT NO 1 TO LEFT
    FOR J = 0 TO 25
    PORTB = $8
    LOW PORTA.0
    PAUSE 3
    HIGH PORTA.0
    PORTB = $8
    LOW PORTA.1
    PAUSE 3
    HIGH PORTA.1
    PORTB = $8
    LOW PORTA.2
    PAUSE 3
    HIGH PORTA.2
    PORTB = $7F 'END POINT
    LOW PORTA.3
    PAUSE 3
    HIGH PORTA.3
    NEXT
    'SHIFT LEFT NO 2
    FOR K = 0 TO 25
    PORTB = $8
    LOW PORTA.0
    PAUSE 3
    HIGH PORTA.0
    PORTB = $8
    LOW PORTA.1
    PAUSE 3
    HIGH PORTA.1
    PORTB = $7F ' END POINT
    LOW PORTA.2
    PAUSE 3
    HIGH PORTA.2
    ' --------------> ' COLUMN 3 IS HIGH
    PORTB = $7F ' STARTING POINT
    LOW PORTA.4
    PAUSE 3
    HIGH PORTA.4
    NEXT
    'SHIFT LEFT NO 3
    FOR L = 0 TO 25
    PORTB = $8
    LOW PORTA.0
    PAUSE 3
    HIGH PORTA.0
    LOW PORTA.1
    PAUSE 3
    HIGH PORTA.1
    LOW PORTA.3
    PAUSE 3
    HIGH PORTA.3
    PORTB = $8
    LOW PORTA.4
    PAUSE 3
    HIGH PORTA.4
    NEXT
    'SHIFT LEFT NO 4
    FOR M = 0 TO 25
    LOW PORTA.0
    PAUSE 3
    HIGH PORTA.0
    PORTB = $7F ' STARTTING POINT
    LOW PORTA.2
    PAUSE 3
    HIGH PORTA.2
    PORTB = $8
    LOW PORTA.3
    PAUSE 3
    HIGH PORTA.3
    PORTB = $8
    LOW PORTA.4
    PAUSE 3
    HIGH PORTA.4
    NEXT
    'SHIFT LEFT NO 5
    FOR N = 0 TO 25
    LOW PORTA.1
    PAUSE 3
    HIGH PORTA.1
    PORTB = $8
    LOW PORTA.2
    PAUSE 3
    HIGH PORTA.2
    PORTB = $8
    LOW PORTA.3
    PAUSE 3
    HIGH PORTA.3
    PORTB = $8
    LOW PORTA.4
    PAUSE 3
    HIGH PORTA.4
    NEXT
    goto MAIN
    ' Go back to loop and blink LED forever
    Dec 2003
    Wichita KS
    Hello Thrix
    Thrix, a couple of things ok?
    1. I do not have anyway how to test this ok?
    Now. 2nd thing.... I noticed that you used the variables I-N for some For-Next Loops. Well I also noticed that none of these loops were nested. That means you can use 1 variable for *all* the loops (for this program example only that you gave).
    Now the 3rd thing.... I Noticed that you were only Toggling 5 ports on and off... Nothing more. So what I did, was put every one of your toggles into a SubRoutine. When I want to Toggle that port, I just call that subroutine. This probably cut the number of lines in your code by 1/3.
    Since I have no way of checking the program against something, I may have errored in reading your code. I also noticed a Loop: and a Goto Loop: Those seemed redundant, because at the end of your program you have Goto Main. It is also not wise to jump in the middle of a For/Next loop with a goto *outside* the for/next loop.
    Here is what i think the code may look like after the above points are implimented:
    TRISA = 255
    TRISB = 0
    MAIN:
    FOR I = 0 TO 25
    GoSub TogPA4
    PORTB = $8
    GoSub TogPA3
    PORTB = $8
    GoSub TogPA2
    PORTB = $8
    GoSub TogPA1
    GoSub TogPA0
    NEXT I
    'SHIFT NO 1 TO LEFT
    FOR I = 0 TO 25
    PORTB = $8
    GoSub TogPA0
    PORTB = $8
    GoSub TogPA1
    PORTB = $8
    GoSub TogPA2
    Gosub TogPA3
    NEXT I
    'SHIFT LEFT NO 2
    FOR I = 0 TO 25
    PORTB = $8
    gosub TogPA0
    PORTB = $8
    GoSub TogPA1
    Gosub TogPA2
    GoSub TogPA4
    NEXT I
    'SHIFT LEFT NO 3
    FOR I = 0 TO 25
    PORTB = $8
    GoSub TogPA0
    GoSub TogPA1
    GoSub TogPA3
    PORTB = $8
    GoSub TogPA4
    NEXT I
    'SHIFT LEFT NO 4
    FOR I = 0 TO 25
    GoSub TogPA0
    GoSub TogPA2
    PORTB = $8
    GoSub TogPA3
    PORTB = $8
    GoSub TogPA4
    NEXT I
    'SHIFT LEFT NO 5
    FOR I = 0 TO 25
    GoSub TogPA1
    PORTB = $8
    GoSub TogPA2
    PORTB = $8
    GoSub TogPA3
    PORTB = $8
    GoSub TogPA4
    NEXT I
    goto MAIN
    ;subroutines!!!!!!!!!!
    TogPA4:
    PAUSE 3 ' '
    TogPA3:
    LOW PORTA.3
    PAUSE 3
    HIGH PORTA.3
    TogPA2:
    LOW PORTA.2
    PAUSE 3
    HIGH PORTA.2
    TogPA1:
    LOW PORTA.1
    PAUSE 3
    HIGH PORTA.1
    TogPA0:
    LOW PORTA.0
    PAUSE 3
    HIGH PORTA.0
    Dec 2003
    Wichita KS
    Hello Thrix,
    A couple of more things.
    1. I was able to do a For/Next loop, and shift 5 times, but I could not include the very first shift, because I did not know if you had to "Toggle" the port in that sequence.
    the First time you toggled, (the I loop) you toggled P.4, P.3, P.2, P.1,P.0, in that order. The rest of the times you toggled them exactly backwards. P.0,P.1,P.2,P.3,P.4.
    I looped the ones you toggled backwards together, and put if statments in them. I couldn't loop the very first one, because I do not know if you can toggle them the other way.
    2. I wrote the *if* statements in a different langauge. I do not know the exact structure of the if statement for what you are using. This means you will have to convert my if statement to yours. For example;
    if(counter==1)
    } else
    Might be converted to your if statement as:
    if (counter=1)
    Begin
    3. If it doesn't matter on the very first loop whether you toggle the ports 0-4 or 4 - 0 , You can include that into my loop by adding just one if statement and making the counter go from 0 to 5, instead of 1 to 5, and get rid of another loop and simplify it even more.
    Here is a shorter , more simplified program....
    counter var word'
    TRISA = 255
    TRISB = 0
    MAIN:
    FOR I = 0 TO 25
    GoSub TogPA4
    PORTB = $8
    GoSub TogPA3
    PORTB = $8
    GoSub TogPA2
    PORTB = $8
    GoSub TogPA1
    GoSub TogPA0
    NEXT I
    'Lets shift!
    For counter=1 to 5
    For J = 0 TO 25
    if(counter==4)
    PORTB = $7
    GoSub TogPA0
    }else if(counter!=5)
    PORTB = $8
    GoSub TogPA0
    if((counter==3) or (counter==5))
    PORTB = $7
    GoSub TogPA1
    }else if(counter!=4)
    PORTB = $8
    GoSub TogPA1
    if((counter==2) or (counter==4))
    PORTB = $7
    GoSub TogPA2
    }else if(counter!=3)
    PORTB = $8
    GoSub TogPA2
    if((counter==1) or (counter==3))
    PORTB = $7
    GoSub TogPA3
    }else if(counter!=2)
    PORTB = $8
    GoSub TogPA3
    if(counter==2)
    PORTB = $7
    GoSub TogPA4
    }else if(counter!=1)
    PORTB = $8
    GoSub TogPA4
    NEXT j
    Next counter
    goto MAIN
    TogPA4:
    PAUSE 3 ' '
    TogPA3:
    LOW PORTA.3
    PAUSE 3
    HIGH PORTA.3
    TogPA2:
    LOW PORTA.2
    PAUSE 3
    HIGH PORTA.2
    TogPA1:
    LOW PORTA.1
    PAUSE 3
    HIGH PORTA.1
    TogPA0:
    LOW PORTA.0
    PAUSE 3
    HIGH PORTA.0
    thrix's Avatar
    thrix Guest
    Smile thanks
    thanks a lot friend... i'm new to this pic thing but getting okay step by step .. btw thanks again
    Dec 2003
    Wichita KS
    Hello Thrix,
    Thrix >>thanks a lot friend... i'm new to this pic thing but getting okay step by step .. btw thanks again<<
    You are very welcome. I am also very new to these PIC chips. I used to program the Phillips chips with assembly, and decided to try these little PIC chips for a project of mine.
    I chief programmer for a major company, so the programming part I have no problems with. Its just trying to learn the different syntax of this chip and/or the basic pro.
    Dwayne
  1. Simplify This:
    By Art in forum General
    Last Post: - 29th December 2009, 21:19
  2. Recommendations - Model Train Controller
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 8th March 2007, 09:17
  3. Strangw results when using PWM command
    Last Post: - 10th July 2006, 13:14
