+ Reply to Thread
Results 1 to 2 of 2
    Northeast
    Default Programming several PICs on same PCB board
    My current project involves using 3 PICs; PIC18F14K50, PIC18F26K42, and PIC16F18426...all on the same board. Can I install jumpers between the PIC's Vpp and the IDC 4 / PICkit3 (etc) ICSP header? The idea is to jump Vpp on the PIC I want to program next. This would leave DAT & CLK lines permanently connected. I left these pins dedicated for ICSP (no secondary use in circuit).
    I don't need the world to know my name, but I want to live a life so all my great-grandchildren proudly remember me.
    Sep 2009
    Default Re: Programming several PICs on same PCB board
    Data and clock pin then must be set as inputs if you don't put MCLR of unused PIC's to GND.
    And then should work, if you menage to preserve signal integrity.
    That will depend mainly on programmer you use and PCB layout. Main issue is parasitic capacitance of PIC pin's and PCB traces.
    I would simply put 3x 5pin header, or test pad and make pogo pin jig to program it.
    If you change jumpers, then you must change hex 3 times for single board. If not done automatically, it will be slower then to flash one pic, on all board, then second, etc.
    EDIT:
    Another approach would be to make 7pin header, and to put jumpers on programmer interface board. If board size is critical.
  1. Cheapest printed circuit board ( tinned ) pcb
    By msdesigner in forum PCB Manufacture
    Last Post: - 21st August 2016, 07:59
  2. PCB board place
    By lerameur in forum General
    Last Post: - 11th March 2011, 22:56
  3. Reliable PCB, PCBA Board House?
    By modifyit in forum Off Topic
    Last Post: - 17th November 2005, 17:52
  4. universal PIC Board (PCB)
    By NavMicroSystems in forum Schematics
    Last Post: - 19th September 2005, 19:13
Members who have read this thread : 18
