MCU with ICSP instead of PGD/PGC
+ Reply to Thread
Results 1 to 2 of 2
    Jun 2013
    Default MCU with ICSP instead of PGD/PGC
    I try to program MCU with ICSP programming pin but MPLAB X return "The circuit on your board may require you to slow the speed down. Please change the setting in the tool properties to low and try the operation again"
    I had tried changing the config for all the available clock speed setting but all return the same error massage,while using a MCU with PGD/PGC I came program it succesfully
    MCU used is PIC16F57
    Programmer PICKIT 4
    please help
    Northeast
    Default Re: MCU with ICSP instead of PGD/PGC
    PICKit4 probably killed your PIC16F57. In the Eratta for the PICKit4 it mentions putting a 100 ohm resistor in series with the ICSP pins. Apparently the PICKit4 outputs a higher voltage than the older PICs can tolerate. Look it up.
  1. MCU seset and stop
    By Sabahan in forum mel PIC BASIC Pro
    Last Post: - 1st February 2017, 09:24
  2. 16F690 VREF PGC question
    By dsicon in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2014, 17:14
  3. PGC (ICSPCLK) Conflicts with Vref ?
    Last Post: - 6th August 2012, 05:57
  4. Sound Command with 12-bit MCU's
    By Melanie in forum General
    Last Post: - 12th September 2007, 20:49
  5. Defining MCU with MPASM
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 24th May 2007, 14:16
