isd4003 arll that matterr
+ Reply to Thread
Results 1 to 9 of 9
    Default isd4003 arll that matterr
    I need to record voice in an ISD4003. Using the audio input with a condenser mic isn't sensitive enough. I added a 1 transistor preamp which works well but it now has a ticking noise. Filtercaps eveyrwhere don"t help. Any suggestions? Thank you.
    Jan 2006
    Istanbul
    Default Re: isd4003 arll that matterr
    A circuit schematic would be useful here.
    I would suggest using an MAX8914 breakout board from Adafruit. Connect the microphone in single ended mode with a voltage divider and set maximum input voltage for ISD4003 for 32 Millivolts. Cap coupled of course.
    EN82fn
    Thanks guys. I am attempting to attach the schematic of what I'm doing (never did this before). Like I said, any attempt to record has a loud ticking in the back round. Shorting the 1K in the mic circuit has no effect. Disconnecting the mic has no effect, removing the 220uF has no effect. Adding disc caps in parallel to the 220uF has no effect. Reversing the ANA IN + and - has no effect. The only way to stop the ticking is to disconnect the circuit. Capacitively coupling the mic directly to the ANA IN pins works but you need to put the mic up to your lips and talk very loud. This will be a modification to an existing prototype circuit board to be mass produced. Any suggestions would be appreciated.
    That didn't work Trying to attach again PDF file.
    I forgot. There's a 10K to B+ on the collector of the transistor.
    Jan 2006
    Istanbul
    Not sure about 1K and 220uf there;
    Also, instead of 1M, 100K may be better. Or have a 1M pot to see where it performs better.
    The transistor amplifier is not going to work. Bias points are wrong, currents are way too low, and a few other errors. If you don't know how to bias the transistor, Google is your friend. Here, for instance: https://backyardbrains.com/experiments/transistorDesign
    Charlie I'm running the circuit at 3V and getting about 1/2 that on the collector, class A. The amp does work. It increases the sensitivity and picks up a normal voice about 10 inches away from the mic. It's just the ticking in the back round that's holding me up. This happened to me using a different ISD chip a while back. The solution was a few .1uF discs to eliminate it. In this case nothing seems to work. BTW thanks for the link - very informative.
  1. help ISD4003 recording code , pleassssseeeeeeeee
    By mohammad in forum mel PIC BASIC
    Last Post: - 20th January 2010, 16:06
  2. ISD4003 to TDA7052A
    By Northstar in forum mel PIC BASIC Pro
    Last Post: - 14th January 2010, 17:27
  3. Interfacing with the ISD4003
    Last Post: - 2nd June 2008, 15:25
  4. ISD4003 Noise Problem
    By Agent36 in forum General
    Last Post: - 6th March 2007, 13:47
  5. ISD4003 & 16F877 Interface
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 26th December 2006, 17:50
Members who have read this thread : 14
