How to count the time while reading ADC ?
Results 1 to 4 of 4
    Dec 2008
    Ploiesti, ROMANIA
    Default How to count the time while reading ADC ?
    Hi ! After a long time I re-started to use my solder station ...and I tried to build a simple switch.
    I need to read the ADC on 12F675 and doing two actions, one if the time is less than 2 sec, the second if time is bigger than 2 sec.
    I searched through forum but I haven't find a clue ...
    Can someone point me the right direction ?
    Thanks in advance !
    @ __config _XT_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _BODEN_ON & _CP_ON
    DEFINE OSC  4
    CMCON    = 7
    TRISIO   = %00001001
    INTCON   = 0
    IOC      = 0
    GPIO     = 0
    ANSEL    = %00110001
    DataW 		var word
    GPIO.1 = 0
    GPIO.2 = 0
    ADCON0 = %10000001
    Pauseus 50            			' Wait for channel to setup
        ADCON0.1 = 1			' Start conversion
    	While ADCON0.1=1:Wend		' Wait for conversion
    	DataW.HighByte=ADRESH		' Read variable from ADC and save
    	DataW.LowByte=ADRESL
    IF DataW < 1020 then
       if time =< 2 sec then GPIO.1 = 1 ; how to count if DataW < 1020 for less than 2 sec ?
       if time  > 2 sec then GPIO.2 = 1 ; how to count if DataW < 1020 for more than 2 sec ?
    Bombay, India
    Default Re: How to count the time while reading ADC ?
    I can offer you ideas only.
    If you're comfortable with interrupts, get a timer to ring every 1mS and keep tracking a variable that increments every ring and then use that variable that throughout your program. Use this as the reference timer for everything on your system.
    Other way, you use a hardware timer and poll it for overflow every fractional time. Then count a number of fractions equal to the 2 seconds you require. This does not need interrupts, but will block till the timer overflows
    its almost like deja vu again
    same answer as here
    Dec 2008
    Ploiesti, ROMANIA
    Unhappy Re: How to count the time while reading ADC ?
    Thanks for remember !!! I forgot the topic... Mea culpa, I became too old
  1. Reading a LTC1865 ADC
    By JTCullins in forum mel PIC BASIC Pro
    Last Post: - 8th December 2011, 15:54
  2. ADC reading voltage divider....
    By RFEFX in forum mel PIC BASIC Pro
    Last Post: - 19th December 2008, 08:33
  3. Count pulses between VARIABLE TIME
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 15th October 2007, 13:44
  4. Reading A Photo Resistor using ADC
    Last Post: - 25th January 2007, 10:28
  5. adc reading ac
    By Ruben Pena in forum mel PIC BASIC Pro
    Last Post: - 20th December 2005, 22:57
