Finding the MCU I need on MICROCHIP's website
+ Reply to Thread
Results 1 to 6 of 6
    SWITZERLAND (french region)
    Default Finding the MCU I need on MICROCHIP's website
    Hi there,
    I'm asking for some guidance on how to use the MAPS or the Parametric Search Tool from MICROCHIP.
    My project consists of driving a 8x8 LED matrix. So, to make it a little more "easy" for me to program, I'd like to find an MCU that has at least two in-a-raw (from 0 to 7) 8bits Outgoing PORTs (i.e. PORTA.0...PORTA.7 and PORTB.0...PORTB.7).
    As I'm short in space, I can not just pick-up a 40 pins MCU and voilą.
    I do have some MCUs in my drawer but, unfortunately, most of them have at least one of the PORT working only as an Input (mostly PORTA.5).
    Currently, I have to read every and single datasheet to find out what I'm looking for.
    But is there a better and faster way to do so?
    Roger
    Sep 2009
    Default Re: Finding the MCU I need on MICROCHIP's website
    I don't know how to search for that.
    Maybe PIC16F54?
    But it's very limited on call stack, so not all pbp command are supported.
    I might suggest an 18F26K22. Can be operated @ 64 Mhz. with 3 full ports A,B,C.
    EN82fn
    Northeast
    Pin arrangements are fairly consistent, even between PIC16F and 18F parts. If you find that a 28-pin format will work, choose one with the features you need. If you can't find a 20-pin part with the layout needed, you probably never will as they are all mostly the same. You can, however, create aliases that will allow you to use pins from PORTA, PORTB, and PORTC to perform the function of D0, D1, etc. That can enable practically any PIC with the number of pins you need to do the job.
    Thanks All.
    I finally went for a 18F2431...I had to find out after some more search
    Roger
    Apr 2011
    Portland, Oregon
    It's not a particularly "user friendly" tool. I typically begin with a couple must have attributes and filter on those, then sort on some of my secondary requirements. Finally, order 3 - 2 of which I'll probably never use. :\
  1. problem with website?
    By wdmagic in forum Off Topic
    Last Post: - 23rd October 2015, 18:57
  2. Microchip's website
    By enauman in forum General
    Last Post: - 27th May 2011, 13:04
  3. Shared PCB order website...
    By Heckler in forum PCB Manufacture
    Last Post: - 25th April 2011, 16:00
  4. Lamp Dimmer on ME Website
    By jw666 in forum mel PIC BASIC Pro
    Last Post: - 1st August 2007, 17:14
Members who have read this thread : 17
