Assembly Interrupts for PIC 18F27K42
+ Reply to Thread
Results 1 to 4 of 4
    Mar 2020
    Default Assembly Interrupts for PIC 18F27K42
    The attached file demonstrates implementing non-vectored interrupts in assembly for a PIC 18F27K42. For this exercise, Timer1 and Timer3 are configured to run concurrently and each generates an interrupt on rollover. The interrupt service routine (ISR) demonstrates how to: disable additional interrupts during processing the current interrupt; determine which timer generated the interrupt; increment a rollover counter; reset the interrupt flag; re-enable interrupts; and return to the main program. All Timer and interrupt configuration is handled in the main code. The Main code includes a forever loop that toggles indicator LEDs when each timer counter equals a predefined trigger value. I do not code in Assembler, so there are likely better ways to do this. It works for my application, which is measuring time values for a tach measuring RPM from <100 to >11K. References for my approach include Section 6.3 of the PBP3 compiler reference manual; Section 41 Instruction Set Summary of the PIC18F27K42 datasheet; and various internet sources, including discussions on this forum.
    Default Re: Assembly Interrupts for PIC 18F27K42
    You should never manipulate the GIE bit inside the ISR. That is handled automatically when you get the intr, and then RETFIE restores it on exit.
    Remove those two instructions.
    Mar 2020
    Thanks for the comment, it should assist others in learning how to implement an ISR in Assembly. Consistent with that objective, I was able to find a Microchip reference (Section 8.1 of Microchip's PICmicro MID-RANGE MCU FAMILY) that states that the “return from interrupt” instruction, RETFIE, exits the interrupt routine as well as sets the GIEbit, which allows any pending interrupt to execute. The same document goes on to state, "When an interrupt is responded to, the GIE bit is cleared to disable any further interrupt, the return address is pushed into the stack and the PC is loaded with 0004h." While it is not explicitly stated, it seems reasonable to assume that this is being done in hardware. The demo code was edited as suggested.
    Dec 2010
    Melbourne Australia
    Thanks for this. I'm trying to implement a completely different interrupt on an 18F26K83 and this is the closest thing I've seen so far as a starting point.
    Troy
  1. Replies: 2
    Last Post: - 8th February 2009, 05:10
  2. assembly in Pic
    By lerameur in forum Off Topic
    Last Post: - 1st May 2008, 20:06
  3. decoding PIC assembly -- need help
    By uchiprox in forum General
    Last Post: - 12th February 2007, 04:19
  4. Simultaneous equation using PIC assembly
    By mankan in forum General
    Last Post: - 11th September 2006, 19:16
  5. PIC to PIC communication and interrupts
    By lwindridge in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2004, 05:59
