Hserout questions
+ Reply to Thread
Results 1 to 9 of 9
    May 2012
    Merseyside, UK
    Default Hserout questions
    Hi All
    Attempting to get some serial communication working with a 16f628 (4Meg Xtal) My defines are as below :-
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_SPBRG 25
    It works sometimes but not reliably ..... Any issues with above, ///maybe external xtal too slow ?
    Just looking for a little guidance.
    BR
    Andy
    Default Re: Hserout questions
    Try adding
    DEFINE HSER_CLROERR 1
    May 2012
    Merseyside, UK
    Quote Originally Posted by aerostar View Post
    Try adding
    I have ..... Still intermittent coms 🙄
    Jan 2006
    Istanbul
    Quote Originally Posted by andybarrett1 View Post
    Hi All
    Andy
    By Xtal, do you mean that an external 4Mhz crystal with two caps like 22pf?
    May 2012
    Merseyside, UK
    Yes 4Megs Crystal
    Your serial circuit diagram/connection details would help - what is connected to the TX line ?
    Is it just TX that is the problem ? have you tried RXing ?
    Have you tried lower rates ?
    Do you have a good earth between your PIC and whatever is receiving. ?
    Is there a short on the TX pin to an adjacent pin ?
    What do you mean by unreliable ? wrong characters/no characters/locking up.
    Oct 2009
    For a 4Mhz timing at 9600 baud
    Register settings
    RCSTA = $90   ' Enable serial port & continuous receive
    TXSTA = $20   ' Enable transmit, BRGH = 0
    SPBRG = 25    ' 9600 Baud @ 0.16%
    SPBRGH = 0
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
    And the defines
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ SPBRGH = 0
    Details of the circuit and what you are sending / receiving, and what's at the other end of the serial cable would help
    BAUDCON does not appear in 628 or 628a data sheet.
    MisterE Multicalc shows
    Registers
    TXSTA = $24 ' Enable transmit, BRGH = 1
    SPBRG = 25 ' 9600 Baud @ 4MHz, 0.16%
    PBP DEFINES
    DEFINE HSER_SPBRG 25 ' 9600 Baud @ 4MHz, 0.16%
    May 2012
    Merseyside, UK
    Hi All
    Thanks for all your advice guys.... Turns out I was right with the defines except the 9600 should have been 9615
    The thing that fixed it all was putting a small delay (pause 100) between my serial instructions ?
    Anyway all good now !
    Thank you
    Andy
  1. Replies: 1
    Last Post: - 31st October 2016, 08:40
  2. Questions about using the A to D
    By Ramius in forum FAQ - Frequently Asked Questions
    Last Post: - 1st September 2014, 17:22
  3. pic16f88 Serial questions (hserin/hserout, etc.)
    By harralk in forum mel PIC BASIC Pro
    Last Post: - 28th October 2012, 00:29
  4. 2 questions
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 1st December 2006, 02:47
  5. New with questions
    By Terke in forum General
    Last Post: - 6th December 2005, 06:35
Members who have read this thread : 18
