Setting 8Mhz clock speed on PIC16F684
Results 1 to 8 of 8
    Feb 2010
    I live in the UK
    Default Setting 8Mhz clock speed on PIC16F684
    Can someone kindly help me please?
    I am trying to make a PIC16F684 run at 8Mhz instead of the default 4Mhz.
    Problem is, test led's just keeping flashing at 10 secs...
    I have MPASM ticked as the Compiler/Assembler and using PBP 2.60
    Simple code below:
    @ __config _INTOSCIO & _WDT_OFF
    DEFINE OSC 8
    OSCCON = %01110000 ' Internal 8MHz osc
    'OSCTUNE = %00000000 ' not in use
    ANSEL = %00000000 'Disable analog select so ports work as digital i/o.
    CMCON0 = %00000111 'Disable analog comparators.
    TRISA = %00000000 'Set PORTA as OUTPUT.
    PORTA = %00000000 'Set PORTA pins all low.
    Start
    HIGH PORTA.2
    PAUSE 10000
    LOW PORTA.2
    PAUSE 2000
    HIGH PORTA.2
    PAUSE 10000
    LOW PORTA.2
    PAUSE 2000
    Default Re: Setting 8Mhz clock speed on PIC16F684
    PAUSE 10000 is 10 seconds
    if the osc is 8 mhz and you tell the compiler the osc is 8 mhz with
    DEFINE OSC 8
    then the pause is 10 seconds as requested
    what do you expect the result to be ?
    Feb 2010
    I live in the UK
    Hi Richard, thanks for the reply.
    "what do you expect the result to be ?"
    I thought (and was hoping) that double the OSC speed from 4 to 8Mhz would drive the led's twice as fast, 10secs would become five at 8Mhz if you see what I mean.
    Feb 2010
    I live in the UK
    Just to add, I based my last post on this article: http:// melabs.com/resources/pbpmanual/7_0.htm
    But I may have misinterpreted it, in that I thought PAUSE 1000 with DEFINE OSC 4 internal OSC would give one second delay and pause 1000 with DEFINE OSC 8 internal OSC would give 0.5 second delay.....
    So are we saying that the above PAUSE 1000 would both cause a one second delay?
    Is it only external Xtals/resonators that throw the internal timing off?
    no not at all.
    the only time it fails is when DEFINE OSC does not match the real osc frequency.
    Feb 2010
    I live in the UK
    Thanks again Richard.
    So as long as I use DEFINE OSC X, PB knows and compensates for the change still giving the correct timings PAUSE etc?
    David
  1. 18F2520 clock speed ?
    By Gixxer in forum mel PIC BASIC Pro
    Last Post: - 21st August 2008, 19:01
  2. code size VS speed optimization setting?
    Last Post: - 28th April 2008, 14:38
  3. Setting up internal clock correctly?
    By JohnM in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 20:29
  4. Clock Speed
    By Del Tapparo in forum mel PIC BASIC Pro
    Last Post: - 24th November 2007, 02:06
  5. clock speed
    By Armando Herjim in forum General
    Last Post: - 30th November 2006, 12:25
