It is Y2K19 but DS18B20PAR+ Returns either 127 or 85 depending on resistor value.
+ Reply to Thread
Results 1 to 13 of 13
    Default It is Y2K19 but DS18B20PAR+ Returns either 127 or 85 depending on resistor value.
    Hello, I'm trying to get this sensor working with PIC16F1519. It is connected to PORTD.1 and MAX7219 display to PORTC. Nothing else. I'm using 4.7k resistor to deliver voltage to it. But it does not works. If I use 4.7k or 5.6k resistor, it will return 127, if I use 2.2k or 10k resistors, it will return 85. I've tried replacing chip, playing with ANSELD and TRISD registers - no luck. I'm using "classic" code from melabs example. What I'm doing wrong?
    ;----[16F1519 Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "16F1519"
      #DEFINE MCU_FOUND 1
    cfg1 = _FOSC_INTOSC           ; INTOSC oscillator: I/O function on CLKIN pin
    cfg1&= _WDTE_OFF              ; WDT disabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_OFF             ; MCLR/VPP pin function is MCLR
    cfg1&= _CP_OFF                ; Program memory code protection is disabled
    cfg1&= _BOREN_OFF             ; Brown-out Reset disabled
    cfg1&= _CLKOUTEN_OFF          ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
    cfg1&= _IESO_OFF              ; Internal/External Switchover mode is disabled
    cfg1&= _FCMEN_OFF             ; Fail-Safe Clock Monitor is disabled
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF               ; Write protection off
    cfg2&= _VCAPEN_OFF            ; VCAP pin function disabled
    cfg2&= _STVREN_ON             ; Stack Overflow or Underflow will cause a Reset
    cfg2&= _BORV_LO               ; Brown-out Reset Voltage (Vbor), low trip point selected.
    cfg2&= _LPBOR_OFF             ; Low-Power BOR is disabled
    cfg2&= _LVP_OFF               ; High-voltage on MCLR/VPP must be used for programming
      __CONFIG _CONFIG2, cfg2
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    '*  Notice  : Copyright (c) 2018 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 11.12.2018                                        *
    'SERVOCONTROLLER SYSTEM
    'init
    include "modedefs.bas"
    OSCCON = %01111010  'SET INTOSC TO 16MHZ
    ANSELC=%00000000
    ANSELD=%00000000
    TRISC=%00000000 'set PORTC as output all
    TRISD=%11111111 'set PORTD as output all
    DEFINE OSC 16
    dqd var PORTD.1
    tvla var word
    temperature var word
    'DEFINES:
     Clk     Var PORTC.6  ' Data is clocked on rising edge of this pin            mcvane
     Dta   Var PORTC.5  ' Bits are shifted out of this pin          KVITELI
     Load    Var PORTC.4  ' Transfers data to LEDs when Pulsed   lurji
     'MAX7219 STUFF
        ' ** Declare Constants **
     Decode_Reg  Con 9 ' Decode register, a 1 turns on BCD decoding for each digit.
     Lum_Reg  Con 10 ' Intensity register.
     Scan_Reg Con 11 ' Scan-limit register.
     Switch_Reg Con 12 ' On/Off Register.
     Test_Reg Con 15 ' Test mode register (all digits on, 100% bright)
     Max_Digit Con 4 ' Amount of LED Displays being used.
    ' ** Declare Variables **
       Counter  Var Word ' Variable used for the Demo Counting routine
     Max_Disp Var Word ' 16-bit value to be displayed by the MAX7219
     Max_Dp  Var Byte ' Digit number to place Decimal point (0-4)
     Register Var Byte ' Pointer to the Internal Registers of the MAX7219
     R_Val  Var Byte ' Data placed in Each Register
     Digit  Var Byte ' Position of individual numbers within MAX_Disp (0-3)
     Position Var Byte ' Position of each LED display (1-4)
     ' Turn Off test mode
     Register=Scan_Reg  ' Point to the Scan Register
     R_Val=7    ' send 3, (Four LED Displays 0-3)
     Gosub Transfer   ' Transfer this 16-bit Word to the MAX7219
     Register=Lum_Reg  ' Point to the Luminance Register
     R_Val=1    ' Send 5, (Value for Brightness)
     Register=Decode_Reg  ' Point to BCD Decode Register
     R_Val=%00001111 ' Decode the first 8 digits
     Register=Switch_Reg  ' Point to the Switch Register
     R_Val=1    ' Set to One, (switches the display ON)
     Register=Test_Reg  ' Point to the Test Register
     R_Val=0    ' Reset to Zero, (turns off Test mode)
     Max_Dp=0   ' Display number for Decimal Point
    REGISTER=8      'display some name
    R_VAL=124
    GOSUB TRANSFER
    REGISTER=7
    R_VAL=110
    GOSUB TRANSFER
    REGISTER=6
    R_VAL=120
    GOSUB TRANSFER
    REGISTER=5
    R_VAL=57
    GOSUB TRANSFER
    TTK:
    gosub gradus1
    max_disp=temperature
    GOSUB DISPLAY
    GOTO TTK
    GRADUS1:
            OWOUT DQD, 1, [$CC, $44] ' Start temperature conversion
            pause 750
            OWOUT DQD, 1, [$CC, $BE]         ' Read the temperature
            OWIN DQD, 0, [temperature.LOWBYTE, temperature.HIGHBYTE]
            temperature = temperature */ 1600
            TEMPERATURE=TEMPERATURE/100
    Display:
     Digit=0      ' Start at Digit 0 of Max_Disp Variable
     For Position=4 to 1 step -1   ' Start at Farthest Right of Display
     Register=5-Position    ' Place Position into Register
     R_Val=Max_Disp Dig Digit   ' Extract the individual numbers from Max_Disp
     If Max_Disp<10 and Position=3 then R_Val=15 ' Zero Suppression for the second digit
     If Max_Disp<100 and Position=2 then R_Val=15 ' Zero Suppression for the Third digit
     If Max_Disp<1000 and Position=1 then R_Val=15 ' Zero Suppression for the Forth digit
     If Max_Disp<10000 and Position=0 then R_Val=15 ' Zero Suppression for the Fifth digit
     If Digit=Max_Dp then R_Val.7=1   ' Place the decimal point, held in Max_DP
     Gosub Transfer     ' Transfer the 16-bit Word to the MAX7219
     If Digit>=3 then Digit=0   ' We only need the first four digits
     Digit=Digit+1     ' Point to next Digit within Max_Disp
     Next Position     ' Close the Loop
    ' Send a 16-bit word to the MAX7219
    Transfer:
       Shiftout Dta,Clk,msbfirst,[Register,R_Val] ' Shift Out the Register first, then the data
     High Load    ' The data is now acted upon
     PAUSEUS 100
    @ Nop
    @ Nop     ' A small delay to ensure correct clocking times
     Low Load    ' Disable the MAX7219
     Return     ' Exit from Subroutine
    Default Re: It is Y2K19 but DS18B20PAR+ Returns either 127 or 85 depending on resistor value.
    Tried to move to PORT.C or B, same result.....
    Well, you are working with a parasitic powered device and the "85" you are getting from it is correct as it is the poweron default temperature. have you read the spec for the part? it states:
    CONVERT T [44h]
    This command initiates a single temperature conversion. Following the conversion, the resulting thermal
    data is stored in the 2-byte temperature register in the scratchpad memory and the DS18B20-PAR returns
    to its low-power idle state. Within 10 μs (max) after this command is issued the master must enable a
    strong pullup on the 1-Wire bus for the duration of the conversion (tconv) as described in the PARASITE
    POWER section.
    is the port pin at a high level with out the resistor after giving the "44" command? It may have worked on the test board designed by MeLabs because they used the normal DS18B20 part which has an input for +5 volts.
    I also notice this in your code as the comment is wrong:
    setting these bits to 1 set's the pins to inputs. Thy something like this for parasitic powered devices:
    TRISD.1 = 0 'set portd.1 as an output, this pin will be made an input when required
    LATD.1 = 1 'set the default output state to high, when not set as output this pin will source +5 volts.
    EN82fn
    Try this:
    ANSELD=%00000000
    TRISD=%11111101
    LATD.1 = 1 'DEFAULT OUTPUT STATE FOR PORTD.1
    dqd var PORTD.1
    GRADUS1:
    TRISD.1 = 0 'MAKE PIN AN OUTPUT WITH DEFAULT STATE HIGH
    pause 760 'ADD AN EXTRA 10 Ms.
    EN82fn
    Thanks, tried it, but still 85.....
    Well I have NO idea what pullup resistor you are using but, after my last post I took the code I presented to you and placed it into an 16F88 processor running @ 20 Mhz. with a 4.7K resistor. It works flawlessly. Here are the lines of code exactly.
    OWOUT PB0, 1, [$CC, $44] ' Start temperature conversion
    PORTB.0 = 1 'KEEP PIN POWERED
    TRISB.0 = 0 'MAKE PIN AN OUTPUT WITH DEFAULT STATE HIGH
    pause 760 'ADD AN EXTRA 10 Ms. FOR THE CONVERSION
    OWOUT PB0, 1, [$CC, $BE] ' Read the temperature
    OWIN PB0, 0, [temperature.LOWBYTE, temperature.HIGHBYTE]
    EN82fn
    I tried all values from 2.2k to 10k, same "85".
    Here is complete code
      #DEFINE MCU_FOUND 1
    #ENDIF
    #IFNDEF MCU_FOUND
    #ENDIF
    'init
    ANSELC=%00000000
    ANSELD=%00000000
    TRISD=%11111101 'set PORTD as output all
    LATD.1=1
    DEFINE OSC 16
    dqd var PORTD.1
    tvla var word
    'DEFINES:
    	'MAX7219 STUFF
    R_VAL=124
    GOSUB TRANSFER
    REGISTER=7
    R_VAL=110
    GOSUB TRANSFER
    REGISTER=6
    R_VAL=120
    GOSUB TRANSFER
    REGISTER=5
    R_VAL=57
    GOSUB TRANSFER
    TTK:
    gosub gradus1
    GOSUB DISPLAY
    GOTO TTK
    GRADUS1:
    Display:
    Transfer:
    	PAUSEUS 100
    @	Nop
    Oct 2009
    Have you tried a different sensor. It could be that the current sensor is faulty as the code looks to be correct.
    What's the cable length between the chip and the sensor. I have 18B20's in a project, one of which is at the end of a 6m cable and that reads fine with 4.7K pull up.
    Yes tried another one, same "85". There is no cables, sensor directly hooked on breadboard.
    CuriousOne, How many times are you letting the program cycle? Here is the output from my terminal after I reset the processor power. Notice the "85" as the first reading from the DS18B20-PAR. This behavior is normal after power up.
    +85.0C +185.0F
    +21.1C +70.1F
    +21.2C +70.2F
    +21.2C +70.2F
    +21.2C +70.2F
    +21.2C +70.2F
    +21.2C +70.2F
    +21.2C +70.2F
    +21.2C +70.2F
    Also, is the pullup source voltage stable during operation? It sounds like the device is being reset between each reading.
    EN82fn
    Try this routine:
    LATD.1=1 SET PIN STATE TO HIGH
    EN82fn
    Excellent!
    now it works!
    so it was latd/trisd issue as I guess...
    Yes, the LATD.1 = 1 has to be set as there is no telling what state it was left in after the preceding OWOUT command.
    EN82fn
  1. Replies: 5
    Last Post: - 17th May 2012, 10:14
  2. DS1307 returns incorrect data ???
    By gtvmarty in forum mel PIC BASIC Pro
    Last Post: - 8th October 2009, 09:54
  3. 16F819 ADC 8bit=127, Not 255?Help!
    By Accelerator in forum mel PIC BASIC Pro
    Last Post: - 24th June 2006, 17:34
  4. Replies: 5
    Last Post: - 20th March 2006, 02:34
  5. Program returns to beginning at interupt
    By BGreen in forum mel PIC BASIC Pro
    Last Post: - 25th April 2005, 11:20
Members who have read this thread : 12
