+ Reply to Thread
Results 1 to 40 of 109
    Default Need to drive 40 pins on variable change, is there a way to do it in elegant way?
    Hello.
    I'm building a nixie clock, which does not uses any specific decoder ICs or multiplexer. Instead, all nixie digits are connected to individual MCU pins via transistors. It uses DS1302 as clock source. Time received from DS1302 is converted into single number in 24 hour format, for example, it time is 15:53, this number will read as 1553. Using DIG statement I'm extracting individual digits from it, so I have 4 variables, called T1-T4, which have data for individual number to be displayed on specific digit. The pin numbers to which nixies are connected are aliases in the following way - A0-A9 for numbers in 1st digit, B0-B9 for numbers in 2nd digit, C0-C9 and D0-D9 for 3rd and 4th digits correspondingly. So now, to display time, I need to run the following code:
    IF T1=0 THEN A0=1
    IF T1=1 THEN A1=1
    IF T1=2 THEN A2=1
    IF T1=3 THEN A3=1
    IF T1=4 THEN A4=1
    and so on, total, 40 lines (not shown is code for extinguishing all non-used numbers, but I'm doing it at same time for all digits)
    So question is, is there a way to avoid all these if-then lines and do it somehow in more elegant way?
    Thanks in advance!
    Jan 2006
    Istanbul
    Default Re: Need to drive 40 pins on variable change, is there a way to do it in elegant way?
    Arrays?
    A_Vals var word(4) 'A0-A9, B0-B9, C0-C9, D0-D9 in each element;
    T_Vals var byte(4) 'T1-T4
    i var byte
    Tx var byte
    Xx var word
    Begin:
        for i = 0 to 3      ' Clear array.
            A_Vals(i) = 0
            T_Vals(i) = 0
        next i
    Start:
        for i = 0 to 3  ' Scan 0-3 => T1-T4
            Tx = T_Vals(i)   ' Get the value of Tx variable.
            Xx = A_Vals(i)   ' Get the value of Ax value.
            Xx[Tx]= 1        ' Change Ax value based on Tx value.
            A_Vals(i)=Xx     ' Get the value back.
        next i
        goto start
    ' Now you have all your pins masked in array A_Vals;
    ' A0 => A_Vals(0) bit.0-bit.9
    ' A4 => A_Vals(3) bit.0-bit.9
    ' you have to read them back from A_Vals, and assign your corresponding pins on its bits 0-9.
    ' For example,
    ' xx = A_Vals(0)
    ' A0 = ax.0(0)
    ' A9 = ax.0(8)
    ' xx = A_Vals(3)
    ' B0 = ax.0(0)
    ' B9 = ax.0(8)
    How about a lookup table, 5 bytes (40 bits) wide and 10 deep (0-9).
    George
    Yes, table would be nice, but how to do with less iF-THEN ?
    Here is a routine I wrote for my 6 digit nixie clock using 2 each HV5530P high voltage shift registers. That's 64 bits.
    I use a 16F1825 14 pin processor running @ 10 Mhz. I don't like to use all of that hardware....
    HVCLK VAR LATC.0 '0-SHIFT REGISTER CLOCK
    HVSTB VAR LATC.1 '0-SHIFT REGISTER STROBE
    HVDAT VAR LATC.2 '0-SHIFT REGISTER DATA
    CLOCKIT: 'ENCODE OUTPUT SEQUENCE AND SEND TO SHIFT REGISTER W/COLLONS
    '------------------------ 64 BIT ENCODE SEQUENCE ------------------------
    '9876543210,9876543210,cc,9876543210,9876543210,cc ,9876543210,9876543210
    '10's HOURs,1's HOURs ,::,10's MIN's,1's MIN's ,::,10'S SEC's,1'S SEC's
    JUNK = 7 'FIRST CLEAR THE OUTPUT ARRAY
    WHILE JUNK < 255
    OUTPUTS(JUNK) = 0
    JUNK = JUNK - 1
    WEND
    JUNK = 0 'NEXT SET THE OUTPUT ARRAY
    WHILE JUNK < 6 'CYCLE THRU ALL 6 DIGITS TO DISPLAY
    PATDOG = 1 'FEED THE DOG
    SELECT CASE JUNK
    CASE 0 'UNIT SECONDS 'BIT POSITION
    OUTPUTS.0((JUNK * 10) + (SECONDS DIG 0)) = 1 '0-9
    CASE 1 'TEN'S OF SECONDS
    OUTPUTS.0((JUNK * 10) + (SECONDS DIG 1)) = 1 '10-19
    OUTPUTS.0((JUNK * 10) + 10) = MINSECCOL '20
    OUTPUTS.0((JUNK * 10) + 11) = MINSECCOL '21
    CASE 2 'UNIT MINUTES
    OUTPUTS.0((JUNK * 10) + 2 + (MINUTES DIG 0)) = 1 '22-31
    CASE 3 'TEN'S OF MINUTES
    OUTPUTS.0((JUNK * 10) + 2 + (MINUTES DIG 1)) = 1 '32-41
    OUTPUTS.0((JUNK * 10) + 12) = HOURMINCOL '42
    OUTPUTS.0((JUNK * 10) + 13) = HOURMINCOL '43
    CASE 4 'UNIT HOURS
    OUTPUTS.0((JUNK * 10) + 4 + (HOURS DIG 0)) = 1 '44-53
    CASE 5 'TEN'S OF HOURS
    'DISPLAY 10'S OF HOURS IF THERE IS SOMETHING TO DISPLAY
    IF HOURS DIG 1 <> 0 THEN 'IF THERE IS A DIGIT TO DISPLAY
    OUTPUTS.0((JUNK * 10) + 4 + (HOURS DIG 1)) = 1 '54-63
    END SELECT
    JUNK = JUNK + 1
    WEND
    SHIFTOUT HVDAT,HVCLK,MSBFIRST,[OUTPUTS(7)\8,OUTPUTS(6)\8,OUTPUTS(5)\8,OUTPUTS(4)\ 8,OUTPUTS(3)\8,OUTPUTS(2)\8,OUTPUTS(1)\8,OUTPUTS(0 )\8]
    PULSOUT HVSTB,PULSE
    EN82fn
    Apr 2011
    Portland, Oregon
    I typically use DATA statements (simple with internal EEPROM) to map each 7 segment character in a byte value. 'A' segment is least significant digit, 'G' segment is bit 6. Bit 7 is unused. For example, the number 8 is %01111111 (all segments on), 1 is %00000011, etc. I then read the bit value and write it to a port or series of pins. If you store the digits in the corresponding memory location, you may simply READ [DIGIT VALUE + 1] to retrieve the segment code.
  1. Can not change variable while using DT_INT?
    By hvguy0 in forum mel PIC BASIC Pro
    Last Post: - 29th March 2013, 23:05
  2. Change a variable to the opposite?
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 21st June 2012, 07:00
  3. LCD DB4-DB7 4bit mode change pins?
    By erice1984 in forum mel PIC BASIC Pro
    Last Post: - 6th March 2009, 01:36
  4. Accessing pins with a variable
    By Desterline in forum mel PIC BASIC Pro
    Last Post: - 20th August 2004, 16:03
  5. Let a variable change from bin to dec.
    By Roy in forum mel PIC BASIC Pro
    Last Post: - 25th May 2004, 19:57
Members who have read this thread : 36
