+ Reply to Thread
Results 1 to 4 of 4
    Default 4x MAX7219 dot matrix modules, daisy chained, usable with PBP
    Hello, there are a lot of modules, containing 4x MAX7219, which are daisy chained, and each of them drives 8x8 led matrix, like this: https://www.ebay.com/itm/MAX7219-Blue-led-matrix-MCU-control-LED-Display-module-for-Arduino-Raspbe-JBM/264335324017
    I want to drive them with PBP, and as I learned from this app note: https://www.maximintegrated.com/en/app-notes/index.mvp/id/3947 when they are daisy chained with all pins, I have to send complete set of data in sequence. I mean, first I send data for 1st module (whole batch, including brightness, decode mode, etc) and when I send it again, 2nd module receives it, then 3rd module and so on, correct?
    Default Re: 4x MAX7219 dot matrix modules, daisy chained, usable with PBP
    Yes, you have to send 16 bits x number of chips in the chain.
    Clock and CS\-Load is common for all chips
    Send the bits while CS\-Load is low and at the end set CS\-Load to high to latch the data to the chips.
    So say I want to directly send something to chip #3, but I can't, right? have to update whole daisy chain at same time?
    Well, you can have seperate lines for the CS\-Load from the PIC and while sending the complete set of bits, select only the CS\-Load of the specific chip. The others will not latch the data already in their shift register.
    But as you can understand, the data is shifted-in and shifted out from each chip in the chain, so have to pass through.
  1. Sure Electronics 0832 Dot Matrix Display
    By wellyboot in forum Code Examples
    Last Post: - 2nd January 2013, 19:50
  2. Sure Electronics Dot Matrix Display
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 6th May 2010, 13:30
  3. PbP usable releases ???
    By Acetronics2 in forum General
    Last Post: - 15th July 2009, 13:12
  4. Flashing!! LED Dot matrix problem
    Last Post: - 4th December 2006, 09:45
  5. 4x16 Dot Matrix LCD control is possible?
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 1st September 2005, 09:56
Members who have read this thread : 12
