help with SERIN & SEROUT
Results 1 to 6 of 6
    Sep 2005
    Question help with SERIN & SEROUT
    hello my name is Max I`m from Mexico
    I have a problem; Im building a remote control using RF with modulation ASK, at the beginning I try to turn on and turn off a led. and Iam using the pic 16f84a. To turn on the led i used a switch and the command serout example:
    if sw1=1 then
    serout datout,N2400,{5}
    to turn off i used another switch an the command serout
    if sw2=1 then
    serout datout, N2400,{8}
    the first test works very good even a 50mts of distance.
    But my problem is here: I try to turn on and turn off with the same switch but i cant do this, why? i have some theory about.
    when i use a one SW only have 2 (obvius)on/off, when is off the serout send the data again and again and when the SW do the same. the RX recieve the data time and time again with this the program behaves very rare.
    how i can to do the tx send only one time the code, even the sw still on or off during anytime?
    the rx: code is like this
    rx:
    serin datin, N2400,dato
    if dato =5 then
    high led
    if dato=8 then
    low led
    I was reading the command serin is able to compare the entrance variables, but i dont know how
    please any have an idea??? help me
    P.S. my english is too bad sorry i hope you understand my problem
    Even it could be much than what you think, can you try that one and post resukt
    Oldata  var byte
    Dato    var byte
    dato=0
    oldata=1
    rx:
        serin datin, N2400,[dato]
        if dato != Oldata then
            if dato =5 then
                high led
                oldata-dato
            if dato=8 then
                low led
                oldata=dato
    But you may/must need a synchro data, then receive the function you want to do. Lookj for the WAIT modifier.
    A common protocol is Manchester, do a search within this forum you'll find the theory. But as you want to receive only 1 or few bytes, send some preamble data (like $aa, $55), then send a Synchro by, then your data). The receiver must wait the synchro, then get the data.
    Sep 2005
    Thumbs up Danke
    thank you.
    I will test with your code or similar, but i dont understand the syncrho data. the transmitter and recivier works with asyncronous data too.
    SEROUT SerPin,BAUD,["UUUUUSYNCHRO",YourByte]
    RECEIVER SIDE
    SERIN2 SerPin,BAUD,[WAIT ("SYNCHRO"),YourByte]
    Or a variant of it.
    Sep 2005
    Red face Hi
    well, i tested the first program and doestn works, then I use a LCD (16X2) for view the variable in the Reciever, the lcd show me the number and show me how works my program and i can view that my program is wrong because the data is send time and time again, and before a while the data changes. I mean first put p.e.: 0,0,0,0,0,3,3,3,0,0,0,0 during the switch is off an suposed the lcd put only zeros. and "viceversa"
    Then i try to fix the problem but now i doesnt pass anything, i cant recieve or i cant transmitt, i testes the pics and works perfectly, I thought that modules RF had been disturbed, And I connected pics directly and even so it does not pass anything, then I believe that it is my program and at this point already my mind is blocked some help?
    here the two codes: (when it worked )
    transmitter code:'TX CODIGO TRANSMISOR
    INCLUDE "modedefs.bas"
    TRISA=6
    DATOUT VAR PORTA.0
    ONN VAR PORTA.1
    OF1 VAR PORTA.2
    C VAR BYTE
    TX:
    IF OF1=1 THEN
    C=2
    IF ONN=1 THEN
    C=5
    IF C=2 THEN
    SEROUT DATOUT,N1200,[0]
    IF C=5 THEN
    SEROUT DATOUT,N1200,[7]
    GOTO TX
    reciever code:'RX CODIGO RECEPTOR
    TRISB=1
    DATAIN VAR PORTB.0
    LEDVER VAR PORTB.1
    DATO VAR WORDS
    RX:
    SERIN DATAIN,N1200,DATO
    IF DATO=0 THEN
    LOW LEDVER
    IF DATO=7 THEN
    HIGH LEDVER
    goto rx
    Sep 2005
    Thumbs down my mind is dead
    Hola, mi cabeza ya de plano tiene muchos golpes, como volví hacer todo, hagamos de cuenta que no uso los modulos rf, ahora solo comunico los pics con un cable directamente, pero no me sale nada. se supone que con un switch mando un dato para prender un led y si esta cerrado mando otro para apagarlo y no lo hace. ya revise los pics y si funcionan, ya me canse de cambiar el programa y nada la verdad ya no se que hacer. les juro que ya me duele la cabeza de estar piense y piense y nada mas no me queda. he hecho otros programas pero este en particular como me ha dado dolores de cabeza
    alguna ayuda aqui los codigos:
    INCLUDE "MODEDEFS.BAS"
    TRISA=1
    BOTON VAR PORTA.0
    VIATX VAR PORTA.1
    LEDVE VAR PORTA.2
    LEDRO VAR PORTA.3
    TX:
    IF BOTON=1 THEN
    GOSUB SEND1
    IF BOTON=0 THEN
    GOSUB SEND2
    GOTO TX
    SEND1:
    SEROUT VIATX,N9600,[7]
    LOW LEDRO
    HIGH LEDVE
    SEND2:
    SEROUT VIATX,N9600,[0]
    LOW LEDVE
    HIGH LEDRO
    ' RX CODIGO RECEPTOR
    TRISB=1
    VIARX VAR PORTB.0
    LEDRO VAR PORTB.1
    LEDVE VAR PORTB.2
    DATO VAR BYTE
    RX:
    SERIN VIARX,N9600,DATO
    IF DATO=0 THEN
    HIGH LEDVE
    LOW LEDRO
    IF DATO=7 THEN
    LOW LEDVE
    HIGH LEDRO
    GOTO RX:
    ya no puedo mas estoy frito alguna ayuda porfavor
  1. A Serial GLCD 128x64 Simple Project
    By Oldspring in forum Off Topic
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
  3. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  4. Advice-scrutiny for my serial controller
    By kevlar129bp in forum mel PIC BASIC Pro
    Last Post: - 13th December 2008, 18:11
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
