PBP3 and Mplabx5.10
+ Reply to Thread
Results 1 to 6 of 6
    Default PBP3 and Mplabx5.10
    Has someone succeeded with that damn couple ????
    MPLABX 5.05 was working fine ... but looks 5.10 once more, is buggy ...
    Northeast
    Default Re: PBP3 and Mplabx5.10
    MPLABX 5.10 seems to be working with MicroCode Studio & PBP3.1.1.4. It also works fine with XC8_16, including DEBUG & SIM. I haven't tried using PBP inside MPLABX.
    I haven't been able to get PBP working in mplabx 5.10 and I've tried just about every combination of install/uninstall/download/manually add tool I could think of.
    I always end up with a 'Compiler toolchain "PICBASIC-PRO" of type "PICBASIC-PRO" does not exist' message.
    I don't know if this matters or not, but when I look at the embedded build tool selection PBP shows as type "PICBASIC PRO" with a tm mark (and no hyphen). It's that way in previous mplabx installs and it works ok, but maybe 5.10 doesn't like it.
    You could try submitting a support ticket and see if they have anything to say other than "contact PBP"
    Sep 2009
    Is there any way to make syntax highlighter to work in newer versions?
    I'm stuck at 2.05...
    Don't think so... that was the function of the Language Tool plugin and that was removed.
    Sep 2009
    So, I'll just stick with 2.05 as log as I can... For now I don't have any major reason to update...
    I don't get who is responsible for maintaining plugins for MPLABX.
    Any idea how to get to plugin source? Maybe to publish plugin as open source?
  1. Pbp3.1.1
    By mpgmike in forum PBP3
    Last Post: - 13th January 2018, 17:40
  2. PBP3 Code Does not Compile with PBP3.1
    By RossWaddell in forum PBP3
    Last Post: - 2nd July 2017, 08:42
  3. I really need some help with PBP3
    Last Post: - 26th February 2012, 17:05
  4. Pbp3
    By rcbandwidth in forum mel PIC BASIC Pro
    Last Post: - 18th September 2011, 14:13
  5. What's with PBP3?
    Last Post: - 10th August 2011, 17:09
Members who have read this thread : 20
