Need to drive 4 rgb leds, but have only 1 pin available...
Results 1 to 12 of 12
    Default Need to drive 4 rgb leds, but have only 1 pin available...
    Hello.
    The situation is as follows:
    PIC16F877A, running @ 8mhz intosc.
    Have 1 free pin available (can alocate any, including one with PWM output).
    Need to drive 4 rgb leds. All 4 should change colors together, so it can be considered as a single led. There is no animation, color effects or whatever - this is backlight and it will be tuned to specific value once configured and that's all.
    I'd like to do it with as few extra components as possible, due to lack of available space.
    I have the following ideas:
    1. Add another MCU in 8 pin case, say, 12F683, connect it to main chip via serial and use it to drive leds via bitbam or whatever.
    2. Use WS2812 LEDs, and to solve timing issues, wire them in parallels, instead of serial?
    3. As a last resort - use only two colors of leds, say red and blue, and use inverted HPWM to drive them.
    Of course, I'd like to do #2 - requires less extra hardware than others, but is this doable on 16F887?
    Default Re: Need to drive 4 rgb leds, but have only 1 pin available...
    PIC16F877A has internal osc?
    On 20MHz, with WS2812 LED try this: http://www.picbasic.co.uk/forum/showthread.php?t=23399
    Should be work.
    Sorry I should write 887A.
    Yes I have read that, but I don't have 20Mhz capability, so this is why I'm asking.
    OK, I try to decreasing the clock frequency, and the minimum clock is 16MHz and the WS2812 works fine.
    In my case at 8MHz the WS2812 not work.
    Pulse generator code for 16MHz looks like this:
    ;------------ Pulse generator ---------------
    NeoBit:
        IF DataBit = 1 THEN
            ;generate 800ns pulse
            NeoPin = 1
                nop
            NeoPin = 0
            ;generate 400ns pulse
            NeoPin = 1
            NeoPin = 0
    With the APA101 clock frequency is not an issue. We did some experiments in this thread:
    http://www.picbasic.co.uk/forum/show...ghlight=apa101
    Yes, but APA needs two legs. Data and clock,. Or I'm wrong?
    Yes, you are right. Forgot that, sorry!
    OK
    If you are trying to get a specific color from your RGB, and you aren't needing to change that color, use different value resistors from VREF to your individual LED legs and use the PIC to provide ground. For brightness control, you could use that one PWM pin on your PIC and vary duty cycle. You wouldn't be able to change the colors, due to the fixed resistors.
    Sep 2009
    Quote Originally Posted by louislouis View Post
    Not necessary, you can create clock and data using only one pin.
    eg
    https://www.romanblack.com/shift1.htm
    This is customizable backlight, so user will be setting the color. Idea with shift register is nice, but if I have to add an extra IC, I can add say 12F683 and use it directly to drive RGB leds. Footprint will be much smaller
    Sep 2009
    You missed the point...
    Use same RC circuit to drive APA LED. Apa have Data and Clock pin and you have one pin free.
    Out of the box. A small PIC device running the 4 LEDs and reading a 2 bit serial pattern with a longish pause to sync.
    George
  1. Re: RGB Fading Using 3 LEDs and PWM
    By Fernandoangel in forum Off Topic
    Last Post: - 8th April 2012, 06:59
  2. Oh Dear. My head is spinning. HPWM RGB LEDs What to choose?
    By jimseng in forum mel PIC BASIC Pro
    Last Post: - 19th March 2012, 18:03
  3. TV remote controlled RGB LEDs
    By idtat in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 18:15
  4. RGB Fading Using 3 LEDs and PWM
    Last Post: - 20th February 2007, 16:53
  5. RGB Fading Using 3 LEDs and PWM
    By _abello in forum mel PIC BASIC Pro
    Last Post: - 19th April 2006, 16:50
