Array error in Hserin
Results 1 to 22 of 22
    Default Array error in Hserin
    It seems that Hserin cannot accept a word array in this expression:
    hserin 100,noreceived,[wait("#"),str word_array\2]
    Gives this error:
    PICBASIC PRO(TM) Compiler 3.1.2.4, (c) 1997, 2019 ME Labs, Inc.
    All Rights Reserved.
    ERROR: Macro HSERINSTR?WL not found in macro file.
    If array is byte size then is just fine. Is that correct? I could not find something in the manual.
    Default Re: Array error in Hserin
    Got it. It is bytes and it is referenced, somewhat cryptic, on page 47, 3rd line from the bottom in the parenthesis.
    ext modifier to the rescue
    word_array var word[2]
    word_array_asbyte var byte ext
    @word_array_asbyte=word_array
    hserin 100,noreceived,[wait("#"),str word_array_asbyte\4]
    Sep 2009
    You need _ before PBP name, when used in ASM.
    Aha! Thanks Richard.
    pedja089, you mean instead of
    be:
    @ _word_array_asbyte= _word_array
    right?
    @ word_array_asbyte= _word_array
    this way makes ext method 18 words less
    array var word[2]
    @array_asbyte=_array
    inx var byte
    i    var byte
    ADRESLO VAR BYTE
    ADRESHi VAR BYTE
    i=0
    for  inx=0 to 3
    'array[inx]=(adreshi<<8)| adreslo
    array_asbyte[i]=ADRESLO
    i=1+1
    array_asbyte[i]=ADRESHi
    i=1+1
    next
    stop
    Did you tested on 18F or 16F?
    I did on 16F887. Maybe this is why I get more memory usage?
    makes no difference , did you notice that i had removed the math from the array indexing for the better method ?
    Yes I noticed that. Still no such reduction.
    Most compact code was obtained with the crude
    word_temp.byte0=adresl
    word_temp.byte1=adresh
    array[i]=word_temp
    Now that I think about it, it is just two transfer. So makes sense, doesn't it?
    not much on today so i tried a few options with pic16f877 and 16f1825 with no other complications code wise
    resultant code sizes are commented
    array var word[2]
    ADRESLO VAR BYTE
    inx var byte
    ADRESHi VAR BYTE
    ;METHOD 0
    word_temp  var word
    ;METHODS 2 AND 3
    ;ALL METHODS EXCEPT 0 , 1
    i    var byte
    i=0
    ;METHOD 4
    @ MOVE?CW _array , FSR0L    ;  PIC16 ENH CORE
    ;METHOD 5
    '@ MOVE?CW _array , FSR     ;  PIC16 SHITTY OLD CHIP
    for  inx=0 to 3       ;1 FOR METHOD 0        ;                        36  WORDS
    '    word_temp.byte0=adreslo         ;METHOD 0
    '    word_temp.byte1=adreshi
    '    array[inx]=word_temp
    '    array[inx]=(adreshi<<8)| adreslo    ;METHOD 1  ;                52   WORDS
    '    if !i&1 then                       ;METHOD 2    ;               60   WORDS
    '        array_asbyte[i]=ADRESLO
    '    else
    '        array_asbyte[i]=ADRESHi
    '    endif
    '    i=1+1
    '    array_asbyte[i]=ADRESLO          ;METHOD 3   ;                  34   WORDS
    '    i=1+1
    '    i=1+1
    asm                                   ;METHOD 4 PIC16 ENH CORE;      23   WORDS
      MOVE?BA _ADRESLO
      MOVWI FSR0++
      MOVE?BA _ADRESHi
      MOVWI FSR0++
    'asm                               ;METHOD 5 PIC16 SHITTY OLD CHIP;  29   WORDS
    '  MOVE?BA _ADRESLO
    '  MOVWF INDF
    '  INCF FSR,F
    '  MOVE?BA _ADRESHi
    '  MOVWF INDF
    '  INCF FSR,F
    'ENDASM
    next
    stop
  1. Hserin with Array
    By JKaiser in forum Serial
    Last Post: - 11th December 2014, 19:13
  2. Hserin Array Question
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 9th May 2012, 02:39
  3. Error - Fatal Out Of Memory ( With Array)
    By stormdacta in forum mel PIC BASIC Pro
    Last Post: - 26th August 2007, 14:36
  4. Bit/Byte array for Hserin/Hserout
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 1st September 2006, 23:07
  5. HSERIN Error
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 13th January 2006, 03:30
