large preload includes
Results 1 to 5 of 5
    Feb 2012
    PERTH AUSTRALIA
    Default large preload includes
    HI guys
    had an need to preload a pic with an include , that has a lot of preset serial strings and other data that the pic processes and then places the data into external flash chip in the areas and format needed
    the problem is the include is now bigger than the pic can handle and exceed the complie size for the pic(128k)
    simple answer is just devide the include into smaller parts , and then load /compile smaller includes files
    how ever management of the include when i need to add/ change things is a bit of pain as well when having to deal with multi files of the same base large include
    but would be nice to keep the large include as 1 file and allow the compiler to take selected sections of it to the max compile size and then generate multi hex files
    is that at all possible
    cheers
    Sheldon
    Default Re: large preload includes
    get one of these
    http://www.autoelectric.cn/en/tl866_main.html
    and put a header on your board for the programmer to access the flash chip
    or
    add a routine to read in the flash data from an external source.
    my tft stuff included a flash routine to load images serially@38kbaud to a windbond 32meg chip, tested to do 100k files no problem
    Sep 2009
    It can be done with #IF ....
    Look manual for conditional compile in manual.
    I would suggest to you that you download data using serial port, or similar. So you don't have need to load multiple hex into pic.
    Feb 2012
    PERTH AUSTRALIA
    Talking Re: large preload includes
    ok cheers guys ,
    i have spi port on the flash chip for programming , so dont have to load multi hex files to pic after the end hex file is made for the flash, just copy it to the other flash chips as needed
    i have seperate compiles for the code as it was best to manage them that way from the start
    but now the includes on the 1 of them is grown and i rather not separate that to another install
    a structured #if would be good for those sections that could be loaded first , with a separation of the flash blocks done
    the pic install also install some information that is generated from flash info into the external EE chip sets after the external flash has loaded , so some consideration is required if the separating the install of the flash data
    fun stuff
    Feb 2012
    PERTH AUSTRALIA
    yep the #if works well enough
    just need to make sure the #define is placed prior to the includes , which makes sense
    saving the file a dif name for when the define is 0 and again when it 1 is fine
    the files now under 80k which gives the include a bit more space to grow
  1. includes?
    By keithv in forum PBP3
    Last Post: - 23rd September 2014, 23:44
  2. Project Includes
    By Demon in forum General
    Last Post: - 7th October 2012, 22:33
  3. T1 interrupt and preload confusion
    By amgen in forum General
    Last Post: - 14th September 2011, 04:24
  4. Large LCD ID and datasheet
    By skimask in forum Off Topic
    Last Post: - 17th May 2008, 16:44
  5. large displays
    By George in forum Off Topic
    Last Post: - 18th March 2007, 22:56
