Better code check before compile?
Results 1 to 30 of 30
    Default Better code check before compile?
    Hello. Recently accidentially deleted RETURN in one subroutine, and it caused catastrophic failure to attached hardware (almost started a fire). Of course this is my fault, but even on ZX Spectrum we had "gosub without return" error check. So I guess, it'll be nice if this will be implemented in PBP. It does that check for FOR-NEXT, why it can't be done for GOSUB-RETURN?
    Default Re: Better code check before compile?
    I don't write compilers and/or preprocessors but from my limited point of view I can't really see how a check like that would work in the case of PBP. How would the compiler or preprocessor be able to "match" a RETURN statement with a GOSUB?
    You can easily have several RETURN statements and multiple labels within a single subroutine.
    Alright, if there's one (or more) GOSUB statements in the program but not a single RETURN statement you know you have a problem but apart from that I'm not sure how it would work.
    In your case I suppose the following represents what happened, the RETURN from Label1 got deleted and is missing but that isn't NECCESARILY an error, the code is still correct.
    Label1:
      ...code
      ...clode
    Label2:
      ...code
      ...code
    Out of curiosity, would you share more details about what happened?
    As one RETURN statement can match more than one GOSUB's ...
    even math can't do anything for you ... just verify if there's at least one RETURN for one GOSUB ...or number of RETURN is smaller or equal than number of GOSUB
    the only way is to run the debugger and verify you jump at the good moment or to the right location ...
    for critical applications, only a GOTO - GOTO or multiple local subroutine INCLUDE could secure the code ...
    but you also could wipe the critical line ...
    Sep 2009
    If your code can start fire, you are doing something really wrong.
    For first run, always use PSU with limited power(at least current limiting) with no load at output. Move actuators if you have them manually to check sensors.
    If you are creating PSU controlled by PIC(or any mcu), simulate output voltage by applying voltage on feedback.
    Any way you must have HW protections that would prevent code to do catastrophic damage.
    As all software in this world PBP can have unsuspected bugs that doesn't manifest all time. I found one few years ago. Other compilers have many more than one.
    Also as this is all clock dependent, it can freeze due falling oscillator eg lot of vibration can cause crystal to breaks.
    I saw result of using PLC with untested code on 300ton press, and actuating pressing and pulling actuators, it wasn't pretty... And that could be avoided if hydraulics was done correctly to disallow engaging both actuators in opposite directions. Or using relay that would disable inputs to other solenoids, etc...
    Added to the above, no one can guarantee you that the software will always run, even with faults in it. MCU's can stop anytime and hardware must protect itself in that case.
    Now, regarding Subs, it is not easy or feasible at all, to check for correct pairs of gosub-return. It is not the same as open-close of { and } in C for example.
    In the case of Returns, you can have one or 100 for the same sub. So, how will the compiler check?
    it is simple. Just count number of Subroutines and RETURNs and make sure they match, that's all, and already done 30 years ago.
    Regarding what happened - it was huge (about 30 meters) Christmas tree 8 channel light controller. The code enables lights at max power for 0.1 second, to give "blink" effect. It worked for 2 years without any issues, until now, when I added some new programs, and forgot to add RETURN, so lights remain at high power for about 10 minutes, instead of 0.5second. It ended up with 9 pieces of solid state relays fried, until thermal switch cut off the power
    Even more simple.
    Just add different label for subroutines, say, subroutines should start with SUB statement, after the label. At compile time, do check and that's all.
    Sep 2009
    Then 80% of my programs wouldn't compile. I often use multiple entry point in same sub. And have only one return at end.
    Or the reverse. Have one entry and multiple exits:
    gosub test
    test:
    if x=1 then
       a=1
    if x=2 then
       a=2
    So you're doing it wrong - same for overlapping for-next cycles
    If you mean my example, OK, it is a not efficient one but I was trying to show that you can have many Returns from the same sub.
    Sure it can be made more compact or efficient, but still. Compiler has difficult time to check this for errors.
    Ok, here is an example (not exact syntax, just to get idea)
    MAINCODE: 'do something
    high PORTC.0
    PAUSE 500
    low PORTC.0
    Pause 500
    GOSUB CHECKER
    GOTO MAINCODE
    CHECKER:
    TOGGLE PORTD.0
    In above example, if we remove RETURN, it will compile fine in PBP, but will produce unusable code. But even on ZX Spectrum, it would give us "Gosub without return" error, and save our time.
    Agreed. This is easy to check, but above we stated other cases that are difficult to check.
    So a sub-without-return check in whole is not easy to implement. I suppose... Maybe Charles knows better to justify it.
    OK
    There have been situations where if a test meets certain criteria you want to go through 5 sequences of code. However, if one of the criteria is missing, you want to skip the first sequence and do the other 4. On down the line, you may only need to do the last 2. The subroutine may look like;
    SELECT CASE Var
     CASE < 50 : GOSUB Sub1
     CASE < 100 : GOSUB Sub2
     CASE < 150 : GOSUB Sub3
     CASE < 200 : GOSUB Sub4
     CASE ELSE : GOSUB Sub5
    END SELECT
    GOTO Main
    Sub5:
     TOGGLE LED1
    Sub4:
     TOGGLE LED2
    Sub3:
     TOGGLE LED3
    Sub2:
     HIGH LATA.4
    Sub1:
     LATB = 0
    Here is a legitimate case of needing only 1 RETURN for multiple subroutines.
    Sep 2009
    That is exactly what I have on my mind in post #8.
    Maybe it will be useful if compiler give just warning about missing RETUN.
    But That wouldn't prevent bad stuff from happening same as it throwing an error wouldn't prevent that. So no real point of having it.
    Another "bug" found - you can easily refer to out of array bounds and it won't give any error during compile
    like
    MAS var byte[5]
    MAS[10]=20
    Won't give any error or warning.
    You may have found something you did not know and it IS something to be aware of but it's not a bug. It's like that by design.
    It's all covered in details thru out section 7.6 in the manual - read it ;-)
    It is common to other languages too like C for example.
    And the compiler is really only able (if so designed) to catch out-of-bounds error when you have a static index like that MAS[10]=20 but in many cases you're using an index variable like MAS[x]=20 and then there is no way for the compiler to know what x is going to be at runtime.
    On your typical 80's computer running BASIC, like the ZX Spectrum referenced earlier, the execution was interpreted so the interpreter could catch out of bounds errors during execution. PBP isn't interpreted but say it was or that it in some other way COULD detect that out-of-bounds error - what should happen?
    Yes the example I have is static, not runtime occurrence.
    Found another "bug" - if you put more DATA lines in code, than size of built-in eeprom, it will compile without errors, but PicKit 3 programmer will show you "Warning: Hex file loaded is larger than device."
    Interesting... This is easy to check I guess.
    I made a typo, putting = instead of -
    hpwm 2,rmd*rmd=1,20000
    This statement does not produce any errors, as it should. Also, RMD value remains the same
    Found another.
    Here is sample code, both variants should work same, but they don't
    if ticker>150 and ard<140 and atrig=0 then
    ticker=1
    atrig=1
    This one is fine, but this one:
    if ticker>150 and ard<140 and atrig=0 then ticker=1: atrig=1
    is not - atrig is always set to 1, no matter if ticker and ard values are as defined in if-then thing. It looks like that code after : is handled as separate code, not part of if-then. But, if I add say GOSUB XX after it, it is executed.
    Sep 2009
    That is not bug. That way should work. This : is same as new row.
    So this line
    is same as this
    atrig=1
    I'm using PBP since 2004. And I found only one bug in pbp, and encounter multiple in MPASM.... DT helped me a lot to track bug to MPASM...
    no, it is not, because if I add GOSUB statement, it is being triggered on IF-THEN condition only.
    Sep 2009
    Hehe. Read manual...
    This : replaces new row. Same as you press enter on your keyboard. So try to compile code from my code above. You will get same results.
    Only thing behind THEN depending on IF. Next statement after : does not.
    Sep 2009
    From manual
    2.18 Line-Concatenation ( : )
    Multiple commands may be written on a single line using colon characters to tell PBP where to insert a "virtual" line break.
    I agree with peja089, the colon acts as a virtual line break.
    If more than a signle statement should execute as a result of the evaluation use IF-THEN-ENDIF.
    With that said... In section 5.35 of the manual they actually DO show the following as a valid example:
    IF B0 <> 10 THEN B0 = B0 + 1: B1 = B1 - 1
    And in fact, when compiling the followong code for a 16F628 both the Test1 and Test2 routines results in the same assembly code
    A VAR BYTE
    B VAR BYTE
    C VAR BYTE
    D VAR BYTE
    Test1:
    IF A = 12 THEN B = 2 : C = 3 :  D = 4
    Test2:
    IF A = 12 THEN
      B=2
      C=3
      D=4
    Here's the resulting assembly (both versions looks identical to me (wasn't really expecting that to be honest):
    _Test1
             clrwdt
             movf    _A,  W
             sublw   00Ch
             btfss   STATUS, Z
             goto    L00001
             movlw   low (002h)
             movwf   _B
             movlw   low (003h)
             movwf   _C
             movlw   low (004h)
             movwf   _D
    L00001
    _Test2
            clrwdt
            movf    _A,  W
            sublw   00Ch
            btfss   STATUS, Z
            goto    L00003
            movlw   low (002h)
            movwf   _B
            movlw   low (003h)
            movwf   _C
            movlw   low (004h)
            movwf   _D
    L00003
    That got me curious so I compiled both version of the original code
    ticker VAR BYTE
    ard VAR BYTE
    atrig VAR BYTE
    Test1:
    Test2:
      ticker=1
      atrig=1
    And the resulting assebly (less library code) looks like this:
    _Test1
            movf    _ticker, W
            movwf   R0
            movlw   low (096h)
            call    CMPGTB
            movwf   T1
            movf    _ard, W
            movwf   R0
            movlw   low (08Ch)
            call    CMPLTB
            movwf   T2
            movf    T1,  W
            movwf   FSR
            movf    T2,  W
            call    LAND
            movwf   T2
            movwf   T2   + 1
            movf    _atrig, W
            sublw   000h
            btfss   STATUS, Z
            movlw   -1
            xorlw   0ffh
            movwf   T3
            movf    T2,  W
            iorwf   T2  + 1, W
            movwf   FSR
            movf    T3,  W
            call    LAND
            movwf   T3
            movwf   T3   + 1
            clrwdt
            movf    T3,  W
            iorwf   (T3)  + 1, W
            btfsc   STATUS, Z
            goto    L00001
            movlw   low (001h)
            movwf   _ticker
            movlw   low (001h)
            movwf   _atrig
    L00001
    _Test2
            movf    _ticker, W
            movwf   R0
            movlw   low (096h)
            call    CMPGTB
            movwf   T1
            movf    _ard, W
            movwf   R0
            movlw   low (08Ch)
            call    CMPLTB
            movwf   T2
            movf    T1,  W
            movwf   FSR
            movf    T2,  W
            call    LAND
            movwf   T2
            movwf   T2   + 1
            movf    _atrig, W
            sublw   000h
            btfss   STATUS, Z
            movlw   -1
            xorlw   0ffh
            movwf   T3
            movf    T2,  W
            iorwf   T2  + 1, W
            movwf   FSR
            movf    T3,  W
            call    LAND
            movwf   T3
            movwf   T3   + 1
            clrwdt
            movf    T3,  W
            iorwf   (T3)  + 1, W
            btfsc   STATUS, Z
            goto    L00003
            movlw   low (001h)
            movwf   _ticker
            movlw   low (001h)
            movwf   _atrig
    L00003
    As far as I can see they are identical, meaning atrig will only get set to 1 if the evaulation is true. So I don't know what might be happening in CuriousOnes case because as far as I can see it IS working as CuriousOne expects - which I did NOT expect.
    Sep 2009
    ... which I did NOT expect.
    Same here
  1. Code check and refinement suggestions?
    By kevlar129bp in forum mel PIC BASIC Pro
    Last Post: - 31st July 2013, 03:37
  2. Replies: 4
    Last Post: - 24th January 2007, 23:20
  3. Code check -- button not working
    By docwisdom in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2006, 23:43
  4. Can some one please check my code out thanks
    By Jhdgkss in forum mel PIC BASIC Pro
    Last Post: - 10th February 2006, 09:19
  5. Code check (sorry)
    By barkerben in forum General
    Last Post: - 30th November 2004, 16:54
