Question regarding Interrupt handler - No DT_Ints used.
+ Reply to Thread
Results 1 to 23 of 23
    Jun 2017
    Post Question regarding Interrupt handler - No DT_Ints used.
    Hello everyone.
    I'm just wondering if I should be concerned when using an inline assembly interrupt handler to save w, status and pclath, then using pbp code to something, then reverting back to using inline assembly to exit the interrupt handler?
    Any takers are appreciated. Thanks
    Default Re: Question regarding Interrupt handler - No DT_Ints used.
    its not clear what you are asking
    if you mean can I call segments of pbp code called from an inline asm routine that saves and restores context {Wreg,Status,Pclat} then
    the answer is no . you need to emulate the functionality of dt's reenter.bas to preserve pbp internal regs and flags.
    if you mean does the context need to be preserved in isr routines then
    the answer is yes always. some chips have auto context save which means the isr need not bother with that task unless it a low priority interrupt
    Jun 2017
    Post Re: Question regarding Interrupt handler - No DT_Ints used.
    Thanks for your reply Richard.
    So basically what you are saying is that the example below is incorrect?
    Define INTHAND  OutputControl
    OutputControl
    ; Save the state of critical registers
        movwf wsave             ; Save W
        swapf STATUS,W          ; Swap STATUS to W (swap avoids changing STATUS)
        clrf STATUS             ; Clear STATUS
        movwf ssave             ; Save swapped STATUS
        movf PCLATH,W           ; Move PCLATH to W
        movwf psave             ; Save PCLATH
        TempIOCFlgs = IOCAF
        for GPCounter = 0 to 3
            if TempIOCFlgs.0[GPCounter] = 1 then
                TimerEnable.0[GPCounter] = 1
        next GPCounter
        TempIOCAF = IOCAF ^ $FF     ; Clear the individual interrupt flags.
        IOCAF = TempIOCAF & IOCAF
        if Mode = 1 then
            LED3 = 1
            LED3 = 0
    ; Restore the state of critical registers (PIC12/PIC16)
        movf psave,W            ; restore PCLATH
        movwf PCLATH
        swapf ssave,W           ; restore STATUS
        movwf STATUS
        swapf wsave,F           ; restore W (swap avoids changing STATUS)
        swapf wsave,W
        retfie
    Thanks again
    sorry for the delay [customers who needs them]
    yes ,that is a recipe for failure
    Jun 2017
    Ok thanks!
    Jun 2017
    Richard,
    So doing it this way as well " is a recipe for failure"? Please see example below.
    '*  Name    : TestCode
    '*  Author  : csantex
    '*  Notice  : Copyright (c) 2018
    '*          : All Rights Reserved
    '*  Date    : 11/8/2018
    '*  Version : 1.0
    '*  Notes   :
    ; Files that are included,
    '    @ ERRORLEVEL -306   ; Suppress messages related to Page Boundries.
    ;MPASM __CONFIG Directive Options.  The PBP default configuration for the PIC10F322 is:
        __config _FOSC_INTOSC & _BOREN_ON & _WDTE_OFF & _MCLRE_OFF & _CP_OFF & _LVP_OFF & _PWRTE_ON & _LPBOR_OFF & _BORV_HI
        DEFINE OSC 4                       ; Oscillator set to 4Mhz set by Config1 above.
        DEFINE INTHAND OutputControl        ; Define interrupt handler.
    ; Interrupt control registers.
        INTCON  = %11001000     ; Global/Peripheral Interrups and IOC enabled.
        PIE1    = %00000010     ; TMR2IE: TMR2 to PR2 Match Interrupt Enable bit.
        PIR1    = %00000000
        CLKRCON = %00000000     ; Bit 6 = 0. Reference Clock output disabled.
        OSCCON  = %01010000     ; Bit 6-4 IRCF<2:0>: INTOSC (FOSC) Frequency Select bits @ 4Mhz.
        PR2     = 255           ; Decimal 255 = 240 mS timer.
        T2CON   = %01111111     ; 1:16 Postscale, Timer2 is off, Prescaler is 64.
        ANSELA  = %00000000     ; Set all analog pins to digital.
        TRISA   = %00001100     ; Port A set to inputs.
        WPUA    = %00000000     ; Weak pull-ups disabled.
        PORTA   = %00000000     ; Clear register.
        LATA    = %00000000     ; Clear register, set bit 0 high.
    ; Interrupt On Change for ports with IOC.  Ports A only applies.
    ; 1 = enabled, 0 = diabled.
        IOCAF = %00000000       ; Interrupt-on-Change PORTA flags.
        IOCAP = %00000100       ; Interrupt-on-Change PORTA Positive Edge Enable bits.
        IOCAN = %00000100       ; Interrupt-on-Change PORTA Negative Edge Enable bits.
    ; Constants.
    ; Variables listing.
        wsave           var byte BANK0 SYSTEM ; wsave in access RAM
        ssave           var byte BANK0 SYSTEM ; wsave in access RAM
        psave           var byte BANK0 SYSTEM ; wsave in access RAM
        TMR2ON          var T2CON.2
        TMR2IF          var PIR1.1
        PulseCount      var byte    ; General Puspose Counter to count how many pulses received.
        NIOCCounter     var byte    ; General Puspose Counter to count how many edges detected.
        PIOCCounter     var byte    ; General Puspose Counter to count how many edges detected.
        TimerCounts     var byte    ; General Puspose Counter to count how many times the timers has overflowed.
        States          var byte    ; Flag variable.
        OutputTmrFlg    var States.0
        FunctModeFlg    var States.1
    ; Port Pin names.
        Output2         var PORTA.0    ; Active high output.
        Output1         var PORTA.1    ; Active high output.
        Control         var PORTA.2    ; Active low input.
        Mode            var PORTA.3    ; Logic state input, high or low.
        goto Start
    ; INTERRUPT SERVICE ROUTINES START HERE.
    ; IOC interrupt handler checks which interrupt flag has been set for PORTA.
    ; Each flag bit corresponds to an intput.
    OutputControl
    ;   IOC interrupt section.
            if IOCAF.2 = 1 then
                TMR2ON = 0       ; 0 = Timer2 is off.
                if Control = 0 then
                    if NIOCCounter = 1 then
                        if PIOCCounter = 1 then NIOCCounter = 2
                    if NIOCCounter = 0 then NIOCCounter = 1
                if Control = 1 then
                    if NIOCCounter = 2 then
                        if PIOCCounter = 1 then PIOCCounter = 2
                    if NIOCCounter = 1 then PIOCCounter = 1
                T2CON = %01111111       ; Timer2 is on.
                MOVLW 0xff
                XORWF IOCAF, W
                ANDWF IOCAF, F
    ;   Timer 2 interrupt section.
        if TMR2IF = 1 then
            TMR2IF = 0       ;
            TMR2ON = 0          ; 1 = Timer2 is off.
                if PIOCCounter = 2 then PulseCount = 2
                if PIOCCounter = 1 then PulseCount = 1
            if TimerCounts = 0 then
                if OutputTmrFlg = 1 then
                    OutputTmrFlg = 0
                    Output1 = 0
                    Output2 = 0
                    NIOCCounter = 0
                    PIOCCounter = 0
            if TimerCounts = 1 then
                TimerCounts = 0
                NIOCCounter = 0
                PIOCCounter = 0
        movwf STATUS
        swapf wsave,W
        retfie
    ; CODE STARTS HERE.
    ; Start of program.
    Start:
        PulseCount = 0
        States = 0
        NIOCCounter = 0
        PIOCCounter = 0
        TimerCounts = 0
        if Mode = 0 then   ; If the jumper is in place, then we are in legacy mode.
            if FunctModeFlg = 1 then
                FunctModeFlg = 0
                PulseCount = 0
                OutputTmrFlg = 0
            if PulseCount = 1 then
                Output2 = 1
                TimerCounts = 1
                gosub StartTimers
            if PulseCount = 2 then
                Output1 = 1
                TimerCounts = 1
                gosub StartTimers
    Mode1:
        if Mode = 1 then                ; If the jumper is not in place, then we are in pulse mode.
            if FunctModeFlg = 0 then
                FunctModeFlg = 1
                PulseCount = 0
                OutputTmrFlg = 0
                Output2 = 1
                TimerCounts = 0
                gosub StartTimers
                Output1 = 1
                TimerCounts = 0
                gosub StartTimers
        goto Main
    StartTimers:
        PulseCount = 0
        OutputTmrFlg = 1
        NIOCCounter = 0
        PIOCCounter = 0
    The reason for all this is that this code is working and being tested overnight to see if it fails. So far, it hasn't failed yet but I am concerned with it failing at some point. If it doesn't fail within 48 hours of continuous run time as it responds to its inputs, then I will let it run until it fails.
    Thanks again Richard for your input.
    I welcome other eyes on the subject or perhaps someone might have a different approach besides converting the whole ISR into assembly.
    Thanks to all who can help.
    you may get away with this flawed approach in very limited circumstances . rest assured that if you
    use code that has conflicting use of pbp internal regs/flags or fsr/tblptr regs it will fail .
    a careful examination of the lst file can reveal conflicts
    caveat emptor
    Jun 2017
    Thanks for the pointer Richard.
    I have looked through the entire LIST file not sure what I was looking for.
    I looked at the following variable/ram locations and there were no inconsistencies between the LIST file and the ASM file that is generated, as one would expect.
    R0 = R0_Save
    R1 = R1_Save
    R2 = R2_Save
    R3 = R3_Save
    R4 = R4_Save
    R5 = R5_Save
    R6 = R6_Save
    R7 = R7_Save
    R8 = R8_Save
    FLAGS = Flags_Save
    GOP = GOP_Save
    RM1 = RM1_Save
    RM2 = RM2_Save
    RR1 = RR1_Save
    RR2 = RR2_Save
    The example above was taken from the Renter PBP Include. I did not see any RX_Save variables in the LIST file but I did see the Rx,RRx in there, if this makes any sense. The only reason I mention these is because as you mention before about emulating DT's Reenter PBP Include, I noticed that they were at the top of the include file so I figured that they must take priority and should be saved somewhere. Towards the end of the LIST file, I saw the example below:
    MEMORY USAGE MAP ('X' = Used,  '-' = Unused)
    0000 : X---XXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
    0040 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
    MPASM 5.77                   BRC CODE V1.ASM   11-14-2018  18:55:36         PAGE 49
    0080 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
    00C0 : XXXXXXXXXXXXXXXX XXXXXXXX-------- ---------------- ----------------
    2000 : -------X-------- ---------------- ---------------- ----------------
    All other memory blocks unused.
    Program Memory Words Used:   213
    Program Memory Words Free:   299
    Errors   :     0
    Warnings :     0 reported,     0 suppressed
    Messages :     0 reported,     0 suppressed
    Is this were I would find the conflicts you mentioned? Further explanation as to what I should be looking for is appreciated.
    I also looked at the ERR file generated but it was blank. So I would guess it's a good thing. I understand the consequences of doing this and I do appreciate your feedback so if you have any other "pointers" to look at, again, I would greatly appreciate it.
    Thanks again Richard.
    no , you must examine the code produced for the isr
    expand out any calls it makes and then see what resources it uses .
    once you know that you can examine the remainder of your code to see if it uses any of those same resources
    if there is any conflict then the isr must preserve the conflicted resources.
    there is a good reason why dt-ints exists and why its so popular
    Jun 2017
    I like it too! There is just not enough room to use it. Thanks all the same.
    I can't compile for that chip . so I can't really speculate the list file contents
    I would assume that it would not be overly complex
    post it if you like
    Jun 2017
    I tried to show it in code quotes but it was too long. Please look at the attached file.
    the revelent piece of list is below
    if you search it for internal regs R0 to R8 there are no hits
    if you search it for FSR USE there are no hits
    the isr block makes no calls so that's clear too
    {the internal regs used can be found in the symbol table at the end of the listing and in the form Rx}
    there may be other bits and pieces involved re-enter.bas will give you some clues if anything else is required
                          00177         ASM?
                          00178
    001D                  00179 OutputControl
                          00180 ; Save the state of critical registers
    001D   00DA           00181     movwf wsave                 ; Save W
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE  7
    LOC  OBJECT CODE     LINE SOURCE TEXT
      VALUE
    001E   0E03           00182     swapf STATUS,W              ; Swap STATUS to W (swap avoids changing STATUS)
    001F   00D9           00183     movwf ssave                 ; Save swapped STATUS
    0020   0183           00184     clrf STATUS                 ; Clear STATUS
                          00185
                          00186
                          00187         ENDASM?
                          00188
                          00189
                          00190 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00112   PortAIOC:
                          00191
                          00192         LABEL?L _PortAIOC
                              M     ifdef PM_USED
                              M         LALL
                              M _PortAIOC
                              M         XALL
                              M     else
    0021                      M _PortAIOC
                              M     endif
                          00193
                          00194 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00114           if IOCAF.2 = 1 then
                          00195         CMPNE?TCL       _IOCAF??2, 001h, L00001
                              M     if ((001h) == 0)
                              M         CLRWDT?
                              M         BIT?GOTO 1, IOCAF, 002h,  L00001
                              M     else
                              M       if ((001h) == 1)
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    0021   0064               M         clrwdt
                              M     endif
                              M         BIT?GOTO 0, IOCAF, 002h,  L00001
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00001))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    0022   1D1C               M         btfss   IOCAF, 002h
                              M     else
                              M         btfsc   IOCAF, 002h
                              M     endif
                              M
    0023   2858               M         goto    L00001
                              M       else
                              M         L?GOTO  L00001
                              M       endif
                              M     endif
                          00196
                          00197 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00115               TMR2ON = 0       ; 0 = Timer2 is off.
                          00198         MOVE?CT 000h, _TMR2ON
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE  8
      VALUE
                              M     if (((000h) & 1) == 1)
                              M         bsf     T2CON,  002h
                              M     else
    0024   1113               M         bcf     T2CON,  002h
                              M     endif
                          00199
                          00200 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00116               if Control = 0 then
                          00201         CMPNE?TCL       _Control, 000h, L00003
                              M     if ((000h) == 0)
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    0025   0064               M         clrwdt
                              M     endif
                              M         BIT?GOTO 1, PORTA, 002h,  L00003
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00003))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((1)      == 0)
                              M         btfss   PORTA, 002h
                              M     else
    0026   1905               M         btfsc   PORTA, 002h
                              M     endif
                              M
    0027   283B               M         goto    L00003
                              M     else
                              M       if ((000h) == 1)
                              M         CLRWDT?
                              M         BIT?GOTO 0, PORTA, 002h,  L00003
                              M       else
                              M         L?GOTO  L00003
                              M       endif
                              M     endif
                          00202
                          00203 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00117                   if NIOCCounter = 1 then
                          00204         CMPNE?BCL       _NIOCCounter, 001h, L00005
                              M     if (((001h) > -100h) & ((001h) < 100h))
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    0028   0064               M         clrwdt
                              M     endif
                              M         MOVE?BA _NIOCCounter
    0029   085B               M         movf    _NIOCCounter, W
    002A   3C01               M         sublw   001h
                              M         BIT?GOTO 0, STATUS, Z, L00005
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00005))
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE  9
      VALUE
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    002B   1D03               M         btfss   STATUS, Z
                              M     else
                              M         btfsc   STATUS, Z
                              M     endif
                              M
    002C   2834               M         goto    L00005
                              M     else
                              M         L?GOTO  L00005
                              M     endif
                          00205
                          00206 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00118                       if PIOCCounter = 1 then NIOCCounter = 2
                          00207         CMPNE?BCL       _PIOCCounter, 001h, L00007
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    002D   0064               M         clrwdt
                              M     endif
                              M         MOVE?BA _PIOCCounter
    002E   085C               M         movf    _PIOCCounter, W
    002F   3C01               M         sublw   001h
                              M         BIT?GOTO 0, STATUS, Z, L00007
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00007))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    0030   1D03               M         btfss   STATUS, Z
                              M     else
                              M         btfsc   STATUS, Z
                              M     endif
                              M
    0031   2834               M         goto    L00007
                              M     else
                              M         L?GOTO  L00007
                              M     endif
                          00208         MOVE?CB 002h, _NIOCCounter
                              M     if (low (002h) == 0)
                              M         clrf    _NIOCCounter
                              M     else
    0032   3002               M         movlw   low (002h)
    0033   00DB               M         movwf   _NIOCCounter
                              M     endif
                          00209         LABEL?L L00007
                              M     ifdef PM_USED
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 10
      VALUE
                              M         LALL
                              M L00007
                              M         XALL
                              M     else
    0034                      M L00007
                              M     endif
                          00210
                          00211 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00119                   endif
                          00212         LABEL?L L00005
                              M     ifdef PM_USED
                              M         LALL
                              M L00005
                              M         XALL
                              M     else
    0034                      M L00005
                              M     endif
                          00213
                          00214 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00120                   if NIOCCounter = 0 then NIOCCounter = 1
                          00215         CMPNE?BCL       _NIOCCounter, 000h, L00009
                              M     if (((000h) > -100h) & ((000h) < 100h))
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    0034   0064               M         clrwdt
                              M     endif
    0035   085B               M         movf    _NIOCCounter, W
    0036   3C00               M         sublw   000h
                              M         BIT?GOTO 0, STATUS, Z, L00009
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00009))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    0037   1D03               M         btfss   STATUS, Z
                              M     else
                              M         btfsc   STATUS, Z
                              M     endif
                              M
    0038   283B               M         goto    L00009
                              M     else
                              M         L?GOTO  L00009
                              M     endif
                          00216         MOVE?CB 001h, _NIOCCounter
                              M     if (low (001h) == 0)
                              M         clrf    _NIOCCounter
                              M     else
    0039   3001               M         movlw   low (001h)
    003A   00DB               M         movwf   _NIOCCounter
                              M     endif
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 11
      VALUE
                          00217         LABEL?L L00009
                              M     ifdef PM_USED
                              M         LALL
                              M L00009
                              M         XALL
                              M     else
    003B                      M L00009
                              M     endif
                          00218
                          00219 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00121               endif
                          00220         LABEL?L L00003
                              M     ifdef PM_USED
                              M         LALL
                              M L00003
                              M         XALL
                              M     else
    003B                      M L00003
                              M     endif
                          00221
                          00222 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00122               if Control = 1 then
                          00223         CMPNE?TCL       _Control, 001h, L00011
                              M     if ((001h) == 0)
                              M         CLRWDT?
                              M         BIT?GOTO 1, PORTA, 002h,  L00011
                              M     else
                              M       if ((001h) == 1)
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    003B   0064               M         clrwdt
                              M     endif
                              M         BIT?GOTO 0, PORTA, 002h,  L00011
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00011))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    003C   1D05               M         btfss   PORTA, 002h
                              M     else
                              M         btfsc   PORTA, 002h
                              M     endif
                              M
    003D   2851               M         goto    L00011
                              M       else
                              M         L?GOTO  L00011
                              M       endif
                              M     endif
                          00224
                          00225 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00123                   if NIOCCounter = 2 then
                          00226         CMPNE?BCL       _NIOCCounter, 002h, L00013
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 12
      VALUE
                              M     if (((002h) > -100h) & ((002h) < 100h))
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    003E   0064               M         clrwdt
                              M     endif
    003F   085B               M         movf    _NIOCCounter, W
    0040   3C02               M         sublw   002h
                              M         BIT?GOTO 0, STATUS, Z, L00013
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00013))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    0041   1D03               M         btfss   STATUS, Z
                              M     else
                              M         btfsc   STATUS, Z
                              M     endif
                              M
    0042   284A               M         goto    L00013
                              M     else
                              M         L?GOTO  L00013
                              M     endif
                          00227
                          00228 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00124                       if PIOCCounter = 1 then PIOCCounter = 2
                          00229         CMPNE?BCL       _PIOCCounter, 001h, L00015
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    0043   0064               M         clrwdt
                              M     endif
    0044   085C               M         movf    _PIOCCounter, W
    0045   3C01               M         sublw   001h
                              M         BIT?GOTO 0, STATUS, Z, L00015
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00015))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    0046   1D03               M         btfss   STATUS, Z
                              M     else
                              M         btfsc   STATUS, Z
                              M     endif
                              M
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 13
      VALUE
    0047   284A               M         goto    L00015
                              M     else
                              M         L?GOTO  L00015
                              M     endif
                          00230         MOVE?CB 002h, _PIOCCounter
                              M         clrf    _PIOCCounter
                              M     else
    0048   3002               M         movlw   low (002h)
    0049   00DC               M         movwf   _PIOCCounter
                              M     endif
                          00231         LABEL?L L00015
                              M     ifdef PM_USED
                              M         LALL
                              M L00015
                              M         XALL
                              M     else
    004A                      M L00015
                              M     endif
                          00232
                          00233 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00125                   endif
                          00234         LABEL?L L00013
                              M     ifdef PM_USED
                              M         LALL
                              M L00013
                              M         XALL
                              M     else
    004A                      M L00013
                              M     endif
                          00235
                          00236 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00126                   if NIOCCounter = 1 then PIOCCounter = 1
                          00237         CMPNE?BCL       _NIOCCounter, 001h, L00017
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    004A   0064               M         clrwdt
                              M     endif
    004B   085B               M         movf    _NIOCCounter, W
    004C   3C01               M         sublw   001h
                              M         BIT?GOTO 0, STATUS, Z, L00017
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00017))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    004D   1D03               M         btfss   STATUS, Z
                              M     else
                              M         btfsc   STATUS, Z
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 14
      VALUE
                              M     endif
                              M
    004E   2851               M         goto    L00017
                              M     else
                              M         L?GOTO  L00017
                              M     endif
                          00238         MOVE?CB 001h, _PIOCCounter
                              M         clrf    _PIOCCounter
                              M     else
    004F   3001               M         movlw   low (001h)
    0050   00DC               M         movwf   _PIOCCounter
                              M     endif
                          00239         LABEL?L L00017
                              M     ifdef PM_USED
                              M         LALL
                              M L00017
                              M         XALL
                              M     else
    0051                      M L00017
                              M     endif
                          00240
                          00241 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00127               endif
                          00242         LABEL?L L00011
                              M     ifdef PM_USED
                              M         LALL
                              M L00011
                              M         XALL
                              M     else
    0051                      M L00011
                              M     endif
                          00243
                          00244 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00128               PR2 = 255               ; Decimal 255 = 240 mS timer.
                          00245         MOVE?CB 0FFh, PR2
                              M     if (low (0FFh) == 0)
                              M         clrf    PR2
                              M     else
    0051   30FF               M         movlw   low (0FFh)
    0052   0092               M         movwf   PR2
                              M     endif
                          00246
                          00247 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00129               T2CON = %01111111       ; Timer2 is on.
                          00248         MOVE?CB 07Fh, T2CON
                              M     if (low (07Fh) == 0)
                              M         clrf    T2CON
                              M     else
    0053   307F               M         movlw   low (07Fh)
    0054   0093               M         movwf   T2CON
                              M     endif
                          00249
                          00250 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00130   ASM
                          00251
                          00252         ASM?
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 15
      VALUE
                          00253
    0055   30FF           00254             MOVLW 0xff
    0056   061C           00255             XORWF IOCAF, W
    0057   059C           00256             ANDWF IOCAF, F
                          00257
                          00258
                          00259         ENDASM?
                          00260
                          00261
                          00262 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00135           endif
                          00263         LABEL?L L00001
                              M     ifdef PM_USED
                              M         LALL
                              M L00001
                              M         XALL
                              M     else
    0058                      M L00001
                              M     endif
                          00264
                          00265 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00139       if TMR2IF = 1 then
                          00266         CMPNE?TCL       _TMR2IF, 001h, L00019
                              M     if ((001h) == 0)
                              M         CLRWDT?
                              M         BIT?GOTO 1, PIR1,  001h,  L00019
                              M     else
                              M       if ((001h) == 1)
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    0058   0064               M         clrwdt
                              M     endif
                              M         BIT?GOTO 0, PIR1,  001h,  L00019
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00019))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    0059   1C8C               M         btfss   PIR1,  001h
                              M     else
                              M         btfsc   PIR1,  001h
                              M     endif
                              M
    005A   288E               M         goto    L00019
                              M       else
                              M         L?GOTO  L00019
                              M       endif
                              M     endif
                          00267
                          00268 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00140           TMR2IF = 0       ;
                          00269         MOVE?CT 000h, _TMR2IF
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 16
      VALUE
                              M         bsf     PIR1,   001h
                              M     else
    005B   108C               M         bcf     PIR1,   001h
                              M     endif
                          00270
                          00271 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00141           TMR2ON = 0          ; 1 = Timer2 is off.
                          00272         MOVE?CT 000h, _TMR2ON
                              M         bsf     T2CON,  002h
                              M     else
    005C   1113               M         bcf     T2CON,  002h
                              M     endif
                          00273
                          00274 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00142           if NIOCCounter = 2 then
                          00275         CMPNE?BCL       _NIOCCounter, 002h, L00021
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    005D   0064               M         clrwdt
                              M     endif
    005E   085B               M         movf    _NIOCCounter, W
    005F   3C02               M         sublw   002h
                              M         BIT?GOTO 0, STATUS, Z, L00021
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00021))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    0060   1D03               M         btfss   STATUS, Z
                              M     else
                              M         btfsc   STATUS, Z
                              M     endif
                              M
    0061   2869               M         goto    L00021
                              M     else
                              M         L?GOTO  L00021
                              M     endif
                          00276
                          00277 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00143               if PIOCCounter = 2 then PulseCount = 2
                          00278         CMPNE?BCL       _PIOCCounter, 002h, L00023
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    0062   0064               M         clrwdt
                              M     endif
    0063   085C               M         movf    _PIOCCounter, W
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 17
      VALUE
    0064   3C02               M         sublw   002h
                              M         BIT?GOTO 0, STATUS, Z, L00023
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00023))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    0065   1D03               M         btfss   STATUS, Z
                              M     else
                              M         btfsc   STATUS, Z
                              M     endif
                              M
    0066   2869               M         goto    L00023
                              M     else
                              M         L?GOTO  L00023
                              M     endif
                          00279         MOVE?CB 002h, _PulseCount
                              M         clrf    _PulseCount
                              M     else
    0067   3002               M         movlw   low (002h)
    0068   00DD               M         movwf   _PulseCount
                              M     endif
                          00280         LABEL?L L00023
                              M     ifdef PM_USED
                              M         LALL
                              M L00023
                              M         XALL
                              M     else
    0069                      M L00023
                              M     endif
                          00281
                          00282 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00144           endif
                          00283         LABEL?L L00021
                              M     ifdef PM_USED
                              M         LALL
                              M L00021
                              M         XALL
                              M     else
    0069                      M L00021
                              M     endif
                          00284
                          00285 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00145           if NIOCCounter = 1 then
                          00286         CMPNE?BCL       _NIOCCounter, 001h, L00025
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    0069   0064               M         clrwdt
                              M     endif
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 18
      VALUE
    006A   085B               M         movf    _NIOCCounter, W
    006B   3C01               M         sublw   001h
                              M         BIT?GOTO 0, STATUS, Z, L00025
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00025))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    006C   1D03               M         btfss   STATUS, Z
                              M     else
                              M         btfsc   STATUS, Z
                              M     endif
                              M
    006D   2875               M         goto    L00025
                              M     else
                              M         L?GOTO  L00025
                              M     endif
                          00287
                          00288 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00146               if PIOCCounter = 1 then PulseCount = 1
                          00289         CMPNE?BCL       _PIOCCounter, 001h, L00027
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    006E   0064               M         clrwdt
                              M     endif
    006F   085C               M         movf    _PIOCCounter, W
    0070   3C01               M         sublw   001h
                              M         BIT?GOTO 0, STATUS, Z, L00027
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00027))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    0071   1D03               M         btfss   STATUS, Z
                              M     else
                              M         btfsc   STATUS, Z
                              M     endif
                              M
    0072   2875               M         goto    L00027
                              M     else
                              M         L?GOTO  L00027
                              M     endif
                          00290         MOVE?CB 001h, _PulseCount
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 19
      VALUE
                              M         clrf    _PulseCount
                              M     else
    0073   3001               M         movlw   low (001h)
    0074   00DD               M         movwf   _PulseCount
                              M     endif
                          00291         LABEL?L L00027
                              M     ifdef PM_USED
                              M         LALL
                              M L00027
                              M         XALL
                              M     else
    0075                      M L00027
                              M     endif
                          00292
                          00293 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00147           endif
                          00294         LABEL?L L00025
                              M     ifdef PM_USED
                              M         LALL
                              M L00025
                              M         XALL
                              M     else
    0075                      M L00025
                              M     endif
                          00295
                          00296 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00148           if TimerCounts = 0 then
                          00297         CMPNE?BCL       _TimerCounts, 000h, L00029
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    0075   0064               M         clrwdt
                              M     endif
                              M         MOVE?BA _TimerCounts
    0076   085F               M         movf    _TimerCounts, W
    0077   3C00               M         sublw   000h
                              M         BIT?GOTO 0, STATUS, Z, L00029
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00029))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    0078   1D03               M         btfss   STATUS, Z
                              M     else
                              M         btfsc   STATUS, Z
                              M     endif
                              M
    0079   2882               M         goto    L00029
                              M     else
                              M         L?GOTO  L00029
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 20
      VALUE
                              M     endif
                          00298
                          00299 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00149               if OutputTmrFlg = 1 then
                          00300         CMPNE?TCL       _OutputTmrFlg, 001h, L00031
                              M     if ((001h) == 0)
                              M         CLRWDT?
                              M         BIT?GOTO 1, _States, 000h, L00031
                              M     else
                              M       if ((001h) == 1)
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    007A   0064               M         clrwdt
                              M     endif
                              M         BIT?GOTO 0, _States, 000h, L00031
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00031))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    007B   1C5E               M         btfss   _States, 000h
                              M     else
                              M         btfsc   _States, 000h
                              M     endif
                              M
    007C   2882               M         goto    L00031
                              M       else
                              M         L?GOTO  L00031
                              M       endif
                              M     endif
                          00301
                          00302 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00150                   OutputTmrFlg = 0
                          00303         MOVE?CT 000h, _OutputTmrFlg
                              M         bsf     _States, 000h
                              M     else
    007D   105E               M         bcf     _States, 000h
                              M     endif
                          00304
                          00305 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00151                   Output1 = 0
                          00306         MOVE?CT 000h, _Output1
                              M         bsf     PORTA,  001h
                              M     else
    007E   1085               M         bcf     PORTA,  001h
                              M     endif
                          00307
                          00308 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00152                   Output2 = 0
                          00309         MOVE?CT 000h, _Output2
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 21
      VALUE
                              M         bsf     PORTA,  000h
                              M     else
    007F   1005               M         bcf     PORTA,  000h
                              M     endif
                          00310
                          00311 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00153                   NIOCCounter = 0
                          00312         MOVE?CB 000h, _NIOCCounter
                              M     if (low (000h) == 0)
    0080   01DB               M         clrf    _NIOCCounter
                              M     else
                              M         movlw   low (000h)
                              M     endif
                          00313
                          00314 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00154                   PIOCCounter = 0
                          00315         MOVE?CB 000h, _PIOCCounter
    0081   01DC               M         clrf    _PIOCCounter
                              M     else
                              M         movlw   low (000h)
                              M     endif
                          00316
                          00317 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00155               endif
                          00318         LABEL?L L00031
                              M     ifdef PM_USED
                              M         LALL
                              M L00031
                              M         XALL
                              M     else
    0082                      M L00031
                              M     endif
                          00319
                          00320 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00156           endif
                          00321         LABEL?L L00029
                              M     ifdef PM_USED
                              M         LALL
                              M L00029
                              M         XALL
                              M     else
    0082                      M L00029
                              M     endif
                          00322
                          00323 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00157           if TimerCounts = 1 then
                          00324         CMPNE?BCL       _TimerCounts, 001h, L00033
                              M         CLRWDT?
                              M     ifndef NO_CLRWDT
    0082   0064               M         clrwdt
                              M     endif
    0083   085F               M         movf    _TimerCounts, W
    0084   3C01               M         sublw   001h
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 22
      VALUE
                              M         BIT?GOTO 0, STATUS, Z, L00033
                              M     ifdef USE_LINKER
                              M         CLRWDT?
                              M     else
                              M       if ($ == (L00033))
                              M         CLRWDT?
                              M       endif
                              M     endif
                              M
                              M     if ((0)      == 0)
    0085   1D03               M         btfss   STATUS, Z
                              M     else
                              M         btfsc   STATUS, Z
                              M     endif
                              M
    0086   288E               M         goto    L00033
                              M     else
                              M         L?GOTO  L00033
                              M     endif
                          00325
                          00326 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00158               PR2 = 255               ; Decimal 255 = 240 mS timer.
                          00327         MOVE?CB 0FFh, PR2
                              M         clrf    PR2
                              M     else
    0087   30FF               M         movlw   low (0FFh)
    0088   0092               M         movwf   PR2
                              M     endif
                          00328
                          00329 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00159               T2CON = %01111111       ; Timer2 is on.
                          00330         MOVE?CB 07Fh, T2CON
                              M         clrf    T2CON
                              M     else
    0089   307F               M         movlw   low (07Fh)
    008A   0093               M         movwf   T2CON
                              M     endif
                          00331
                          00332 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00160               TimerCounts = 0
                          00333         MOVE?CB 000h, _TimerCounts
    008B   01DF               M         clrf    _TimerCounts
                              M     else
                              M         movlw   low (000h)
                              M         movwf   _TimerCounts
                              M     endif
                          00334
                          00335 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00161               NIOCCounter = 0
                          00336         MOVE?CB 000h, _NIOCCounter
    008C   01DB               M         clrf    _NIOCCounter
                              M     else
                              M         movlw   low (000h)
    MPASM 5.77           TEST CODE V1 - COPY.ASM   11-14-2018  21:42:28         PAGE 23
      VALUE
                              M     endif
                          00337
                          00338 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00162               PIOCCounter = 0
                          00339         MOVE?CB 000h, _PIOCCounter
    008D   01DC               M         clrf    _PIOCCounter
                              M     else
                              M         movlw   low (000h)
                              M     endif
                          00340
                          00341 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00163           endif
                          00342         LABEL?L L00033
                              M     ifdef PM_USED
                              M         LALL
                              M L00033
                              M         XALL
                              M     else
    008E                      M L00033
                              M     endif
                          00343
                          00344 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00165       endif
                          00345         LABEL?L L00019
                              M     ifdef PM_USED
                              M         LALL
                              M L00019
                              M         XALL
                              M     else
    008E                      M L00019
                              M     endif
                          00346
                          00347 ; C:\TEST CODE\TEST CODE V1 - COPY.PBP  00167   ASM
                          00348
                          00349         ASM?
                          00350
                          00351 ; Restore the state of critical registers
    008E   0E59           00352     swapf ssave,W           ; restore STATUS
    008F   0083           00353     movwf STATUS
    0090   0EDA           00354     swapf wsave,F           ; restore W (swap avoids changing STATUS)
    0091   0E5A           00355     swapf wsave,W
    0092   0009           00356     retfie
                          00357
                          00358
                          00359         ENDASM?
                          00360
    ps on those limited resource use
    DEFINE NO_CLRWDT 1 'Donít insert CLRWDTs
    and make sure wdt is off in config
    can save some space
    Jun 2017
    Thanks for all your help Richard.
    Sep 2009
    You could try to use only ReEnterPBP.bas to take care about saving and restoring variables.
    So just call
    SavePBP_H:
    After saving status wreg etc,
    And before you exit interrupt call
    RestorePBP_H:
    Than restore Status etc
    Jun 2017
    So just call
    SavePBP_H:
    RestorePBP_H:
    Thanks for the advice pedja089. I couldn't make it work as you suggested but I did manage to get it to work this way:
        DEFINE NO_CLRWDT 1                  ; Donít insert CLRWDTs.
    ; Interrupt control registers.    Not used.
        PIR1    = %00000000
    ; Interrupt On Change for ports with IOC.  Ports A,B and C only apply.
    ; Constants.
    ' Save locations for PBP system Vars
        R0_Save     VAR WORD ;BANK0 SYSTEM
        R1_Save     VAR WORD ;BANK0 SYSTEM
        R2_Save     VAR WORD ;BANK0 SYSTEM
        R3_Save     VAR WORD ;BANK0 SYSTEM
        R4_Save     VAR WORD ;BANK0 SYSTEM
        R5_Save     VAR WORD ;BANK0 SYSTEM
        R6_Save     VAR WORD ;BANK0 SYSTEM
        R7_Save     VAR WORD ;BANK0 SYSTEM
        R8_Save     VAR WORD ;BANK0 SYSTEM
        Flags_Save  VAR BYTE ;BANK0 SYSTEM
        GOP_Save    VAR BYTE ;BANK0 SYSTEM
        RM1_Save    VAR BYTE ;BANK0 SYSTEM
        RM2_Save    VAR BYTE ;BANK0 SYSTEM
        RR1_Save    VAR BYTE ;BANK0 SYSTEM
        RR2_Save    VAR BYTE ;BANK0 SYSTEM
        TMR2ON          var T2CON.2
        TMR2IF          var PIR1.1
        ControlFlg      var States.2
    ; Port Pin names.
        goto Start
    ;ASM INTERRUPTS COURTESY OF DARREL TAYLOR.
    '    ASM
    'INT_LIST  macro    ; IntSource,        Label,  Type, ResetFlag?
    '        INT_Handler   IOC_INT,          _OutputControl ,  PBP,  yes
    '        INT_Handler   TMR2_INT,         _TimerControl  ,  PBP,  yes
    '    endm
    '    INT_CREATE              ; Creates the interrupt processor
    '    ENDASM
    '@ INT_ENABLE  IOC_INT       ; Enable Interrupts On Change interrupts
    '@ INT_ENABLE  TMR2_INT      ; Enable Timer 1 interrupts
    OutputControl
    ;    call _SavePBP_H
    SavePBP:                ' Save all PBP system Vars
        R0_Save = R0        '  4/ 4
        R1_Save = R1        '  4/ 8
        R2_Save = R2        '  4/12
        R3_Save = R3        '  4/16
        R4_Save = R4        '  4/20
        R5_Save = R5        '  4/24
        R6_Save = R6        '  4/28
        R7_Save = R7        '  4/32
        R8_Save = R8        '  4/36
        Flags_Save = FLAGS  '  2/38
        GOP_Save = GOP      '  2/40
        RM1_Save = RM1      '  2/42
        RM2_Save = RM2      '  2/44
        RR1_Save = RR1      '  2/46
        RR2_Save = RR2      '  2/48
    'OutputControl:
            if IOCAF.2 = 1 then
                if Control = 0 then
                if Control = 1 then
                MOVLW 0xff
                XORWF IOCAF, W
                ANDWF IOCAF, F
    '@ INT_RETURN
    'TimerControl:
        if TMR2IF = 1 then
            TMR2IF = 0       ;
                    OutputTmrFlg = 0
                    Output1 = 0
                    Output2 = 0
                    NIOCCounter = 0
                    PIOCCounter = 0
                TimerCounts = 0
                NIOCCounter = 0
                PIOCCounter = 0
    '@ INT_RETURN
    RestorePBP:
        R0 = R0_Save
        R1 = R1_Save
        R2 = R2_Save
        R3 = R3_Save
        R4 = R4_Save
        R5 = R5_Save
        R6 = R6_Save
        R7 = R7_Save
        R8 = R8_Save
        FLAGS = Flags_Save
        GOP = GOP_Save
        RM1 = RM1_Save
        RM2 = RM2_Save
        RR1 = RR1_Save
        RR2 = RR2_Save
    ;    call _RestorePBP_H
        movwf PCLATH
        movwf STATUS
        swapf wsave,W
        retfie
    ; CODE STARTS HERE.
    It compiled with no errors eventually. There were a few things I had to straighten out first.
    The test that I've been running has not failed as of yet. I have another test running with this new ISR version. I'll wait and see who will fail first, if anyone is interested.
    Thank you both (Richard and pedja089) for your help.
    There's nothing wrong with saving all that stuff, but that's a lot of bother for what you've got going on.
    If all you do is simple sets and tests with port bits and bytes like you have then you don't really need any of it
    except for what you had originally. You're code isn't using any of the PBP system variables.
    Jun 2017
    Thanks for your input tumbleweed. What you said coincides with what I have been able to gather by looking at the LST file. As Richard pointed out, I may have been stepping on system variables but couldn't find anywhere in the file where I was doing it. Thanks to Richard, I now have a greater understanding of the inner workings of PBP.
    So far, my testing has not yielded any errors or failures which would add to the belief that the code was fine from the beginning as you stated. Thanks goes to all who put in their two cents. It was money well spent on my education.
    If anything changes in my testing, I'll post about it for those who are interested.
    Thanks for all the help everyone, Cheers.
    Northeast
    Section 6.5 (page 39) of the PIC10F322 Data Sheet declares the only context saving it does is saves the PC. Example 6-1 spells out the minimal Assembly code required to accomplish that feat (note, you must declare the variables wsave and ssave). You can eliminate the psave variable and related code. I'm not sure how time sensitive your Interrupt results are, but here's a thought:
    I like to create Bits that I use as flags ("flag1 VAR BIT" works). In the Main routine, I poll these flags. The flags are set by the ISR. Setting them may be time sensitive, but initiating ALL of the code related may not be. If you can "get around to" dealing with at least some of the duties with a couple instruction cycles of delay, just set a flag in the ISR then poll that flag in Main. Create subroutines that deal with the actual duties. It keeps the ISR short, it "corrupts" very few registers, and keeps you in familiar PBP territory.
    As a side note, you are attempting to return from your ISR with the "@ INT_RETURN " command. That ONLY works with DT_INTS. Returning from a PBP interrupt, use RESUME; returning from an ASM interrupt, use RETFIE. Hope this helps.
    I would be pretty cautious about that. pbp code is full of goto's
    actual note from data sheet
    Note: These devices do not require saving the
    PCLATH. However, if computed GOTOs
    are used in both the ISR and the main
    code, the PCLATH must be saved and
    restored in the ISR.
    GOTO Unconditional BranchSyntax: [label ] GOTO k
    Operands: 0
    k 2047
    Operation: k
    PC<10:0>
    PCLATH<4:3>
    PC<12:11>
    Status Affected: None
    Description:
    GOTO is an unconditional branch.
    The 11-bit immediate value is
    loaded into PC bits <10:0>. The
    upper bits of PC are loaded from
    PCLATH<4:3>.
    GOTO is a
    2-cycle instruction
    It's probably good to be aware of the minimal context saving done automatically, but for the code in question it's not using any computed GOTO's so I think you should be safe with the code pretty much as originally posted in #6.
    A lot of times you see WAY too much going on inside the interrupt handler. I'm a big fan of doing as little in the ISR as required, but I've seen folks take this to the extreme and do nothing more than set a flag in the ISR which is then handled in main. If that's all you're doing then you can get rid of the interrupt handler all together and just poll the xxxxIF flags directly in main.
    Depending on what's going on inside the main loop, many times this approach ends up being faster (and a lot more reliable) than using interrupts.
    PS a lot of Richard's comments are spot on, esp. the one about adding 'DEFINE NO_CLRWDT 1'. PBP can add a lot of things "behind the scene", so you do have to careful about what features you use when doing the minimal approach.
    Northeast
    UART Receive specifically came to mind with the "flags" comment. Unload the RCREG, set a flag, then figure out what it means later. This still requires an Interrupt to clear out the RCREG so the next byte can be received, but it can be loaded into a buffer through the ISR and deciphered later from the Main loop (or subroutine).
  1. Counting Timer0 and Timer1 overflows without any interrupt handler
    By dw_picbasic in forum mel PIC BASIC Pro
    Last Post: - 16th March 2015, 21:33
  2. PIC18 timer0 interrupt handler, still not getting it
    By ImAnEE in forum mel PIC BASIC Pro
    Last Post: - 30th April 2011, 00:25
  3. Interrupt Handler issue with PBPro
    By DonD in forum mel PIC BASIC Pro
    Last Post: - 18th February 2011, 20:04
  4. PIC18 interrupt handler, where to save W etc?
    Last Post: - 13th June 2010, 08:18
  5. DT-INTs Interrupt handler question
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 8th January 2010, 00:06
Members who have read this thread : 22
