+ Reply to Thread
Results 1 to 5 of 5
    May 2012
    Merseyside, UK
    Default 16f627a Loop issues
    Help Please..... Thank you for reading
    I have a loop (Mainloop) that is looking at some RTC (DS1302) values and switching an LED depending on time of day.
    All is good as is.
    What I am attempting to do now is put a simple active low Press button in the circuit so I hit the button the LED is on for an amount of time. I have enabled my pullups OPTION_REG.7=0 and am using PORTB.3 as the input, button is switching 0v onto this pin when pressed.
    Main loop looks like this... suspect code in red :-
    mainloop:   GOSUB gettime        ' Read the time from the RTC
                IF (RTCHour=$17) AND (RTCMin=$15) THEN
                GOSUB Message ' flash
                IF (RTCHour=$18) AND (RTCMin=$15) THEN
                IF (RTCHour=$19) AND (RTCMin=$15) THEN
                IF (RTCHour=$20) AND (RTCMin=$15) THEN
                GOSUB Led_On ' Led on
                IF (RTCHour=$21) AND (RTCMin=$45) THEN
                GOSUB Led_Off ' Led off
                IF PORTB.3=0 THEN
                high led
                Low led
                GOTO mainloop        ' Do it forever and ever and ever
    Led_On:     HIGH Led
    Led_Off:    LOW Led
    What my issue is is the LED is on all the time in 1second bursts regardless of Button in or out..... I have tried with real hard pullups 10k but same outcome.
    I would expect the LED to come on for a second with a button press..... Well that is what I want (Just a lamp test function)
    Thank you again for reading ...... and hopefully pointing out the obvious
    BR
    Andy
  • #2
    Jan 2006
    Istanbul
    Default Re: 16f627a Loop issues
    In the config, make sure "LVP_OFF".
    and
    TRISB.3 = 1 comes first
    OPTION_REG.7=0 comes second
  • #3
    May 2012
    Merseyside, UK
    Quote Originally Posted by sayzer View Post
    and
    I understand TRISB.3 and OPTION_REG.7=0
    Why LVP_OFF, I think it is off anyway ?
    Still not working :-(
    BR
    Andy
  • #4
    the problem is in the code not posted
    this works as expected on a 16f648a (basically the same as a 627a)
    cfg = _INTOSC_OSC_NOCLKOUT
    cfg&= _WDT_ON
    cfg&= _PWRTE_OFF
    cfg&= _MCLRE_ON
    cfg&= _BODEN_ON
    cfg&= _LVP_OFF
    cfg&= DATA_CP_OFF
    cfg&= _CP_OFF
      __CONFIG cfg
     led var porta.1
     OPTION_REG.7=0
    mainloop:
                IF PORTB.3=0 THEN
                high led
                Low led
  • #5
    May 2012
    Merseyside, UK
    Out of desperation I checked TRISB=%00000100
    Should be :- TRISB=%00001000 for RB3 Input :-)
    Not near the project at moment but might be the issue ????
    Possible lesson learnt. :-)
    BR
    Andy
  • Similar Threads
    1. Issues with a feedback loop.
      By jmgelba in forum mel PIC BASIC Pro
      Last Post: - 11th June 2012, 18:54
    2. Newbie need Help 16F627a
      By azmax100 in forum mel PIC BASIC Pro
      Last Post: - 21st January 2009, 07:38
    3. Comparator help (16F627A)
      By JohnnyV in forum mel PIC BASIC Pro
      Last Post: - 24th May 2008, 04:09
    4. 16F627A portA4 problem?
      By markedwards in forum mel PIC BASIC Pro
      Last Post: - 22nd October 2005, 19:54
    5. Programmer For 16f627a
      By TONIGALEA in forum General
      Last Post: - 13th January 2005, 12:55
    Members who have read this thread : 21
