GOTO to a return in a subroutine amidst multiple If-Then's
Results 1 to 4 of 4
    Default GOTO to a return in a subroutine amidst multiple If-Then's
    Are there any caveats to using multiple GOTOs to a single return from within IF-THEN-ELSE's in a subroutine? I am using it to skip irrelevant code once the first condition is met.
    Example (for reference only, not trying to actually do anything):
    carry_out_logic:
        if counter=4 then
            toggleme=~toggleme
            LED_4=1
            goto continueon
        if counter=6 then
            LED_6=1
            goto continueon
    (...other if-then stuff...)
    continueon:
    I know I can make use of ELSIF to skip irrelevant code, but it just gets really messy to read when dealing with multiple conditions in multiple IF's.
    Jan 2006
    Istanbul
    Default Re: GOTO to a return in a subroutine amidst multiple If-Then's
    just say "return".
    Whenever it is hit, it will return to last call.
    carry_out_logic:
        if counter=4 then
            toggleme=~toggleme
            LED_4=1
        if counter=6 then
            LED_6=1
    return  ' if nothing executed so far, it returns anyway.
    OK
    Your approach to a JUMP sequence at the bottom of a subroutine comes in handy when programming in ASM on older PICs that require Context saving, or when there is one or more other tidy-up duties required before a RETURN, but sayer's method works and it's clean.
    And it saves a few instructions. (faster)
    EN82fn
  1. GOTO vs RETURN after a GOSUB
    By rsocor01 in forum PBP3
    Last Post: - 25th April 2018, 20:24
  2. jumping out of subroutine with goto
    By helloo in forum General
    Last Post: - 3rd January 2012, 10:37
  3. GOTO main or RETURN - Question
    By studysession in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 16:13
  4. Does CLEAR Command clear return adrress of a subroutine?
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 19th February 2008, 16:25
  5. Return VS Goto?
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 11th January 2008, 00:13
