Why does PICkit2 show it as an LF device?
Results 1 to 4 of 4
    May 2011
    Bangalore, India
    Default Why does PICkit2 show it as an LF device?
    About a month back, I bought 5 pieces of PIC12F1840 (SOIC package) from Ali Express for $ 3.22. I am able to program them and run the code at 5 volts without any problem. But PICkit2 always identifies it as 12LF1840 (LF version) and reduces the supply voltage to 3.3. I can increase it up to 3.6, but not beyond that. I understand that it is a safety feature for low voltage devices.
    Since the laser etching on the PIC clearly describes it as 12F1840 and since it is not getting fried when connected to a supply of 5 Volts, I am sure it's not an LF version. I have three questions.
    1. How do I tell PICkit2 that it is not an LF version (assuming it is possible)?
    2. Is there a difference in programming voltage between F and LF versions?
    3. Is there any way of finding out whether it is a genuine PIC manufactured by Microchip?
    Thanks for any comments / suggestions.
    - Bala
    Default Re: Why does PICkit2 show it as an LF device?
    I have seen microchip forum topics indicating that early versions of the PK2DeviceFile.dat
    have that chip incorrectly represented. try getting the latest version.
    other than that try a different programmer to verify chip credentials, it may be some sort of clone
    I use this [post15]
    https://www.microchip.com/forums/m731464.aspx
    Hello,
    I done programming lots of genuine 12F1840 pic's with 12LF1840 settings on pickit2 without any problems.
    Lets try it, it works for me.
    Louis
    May 2011
    Bangalore, India
    That's right.
    As I have mentioned in my earlier post, the PIC works fine. I understand that there is no difference in programming voltage between 12F1840 and 12LF1840 . I havae a PICkit2 programmer and it is able to program the PIC. So, there is no problem in using those PICs.
  1. Replies: 1
    Last Post: - 5th October 2011, 08:59
  2. Debug Watch does not show all of an array
    By reppig in forum mel PIC BASIC Pro
    Last Post: - 12th July 2011, 17:22
  3. Target Device does not match selected device
    By queenidog in forum FAQ - Frequently Asked Questions
    Last Post: - 25th June 2011, 00:24
  4. show on LCD decimal numbers
    Last Post: - 31st March 2007, 20:36
  5. mass storage device 1 MB Flash device
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 31st August 2006, 03:11
