I2CRead problem
Results 1 to 10 of 10
Thread: I2CRead problem
    Default I2CRead problem
    Very strange problem.
    Executing an I2CRead command does only I2CWrite as it is shown on the Logic capture.
    This is my test code for an 24C64 EEPROM
    DEFINE I2C_SLOW 1
    b1  var byte
    b2  var byte
    addr VAR word
    cont CON %10100000
    data_pin  var porte.0
    clk_pin     var porte.1
    addr = 0
    ' Read data at address 0 into B1,B2
    I2CREAD data_pin,clk_pin,cont,addr,[b1,b2]
    stop
    Any ideas?
    Default Re: I2CRead problem
    can we see the whole transaction , an i2c read needs to do a write to set address and then a restart to read . you have not shown enough
    Thank you Richard. Will do that this evening.
    I tried byte read, word read, page read, Nothing works and all var's are just a zero.
    The chip is a 16F1939 but I am sure this does not matter. Logic analyzer shows I2C activity either way.
    Edit:
    OK, now that is weird. On a 45K22 works just fine. On 1939 not...
    I am very embarrassed...
    I forgot completely ANSELD and ANSELE when testing it...
    Another good reason to migrate to xc8 , mcc gives all pin settings/names and function in one easy to use screen
    It is not easy to me. I detest C lanquage. Despite my efforts so far, I did not managed to flip over.
    It looks very cryptic...
    Jan 2006
    Istanbul
    Using ready-to-use tools to adjust the registers as we need, kills our ability of playing with them, and lowers the understanding of the hardware registers.
    Manual setting as much as possible is a good way of self developing, I think.
    setting pin function is pic 101 stuff , but essential to get correct .not much programming skill in there once a basic understanding is reached
    would you not use dt_ints or PicMultiCalc
    if there's a good tool use it ,I think
    Fuses and the like are a pain. So many new options on the recent chips. I hate it as I loose too much time from the programming itself, on figuring out how to set up a new (or older) chip.
    All these settings are getting more and more complex. A tool such as MCC is great but needs C understanding I suppose. Or maybe to that extend to get the fuses and then return to PBP?
    the mcc generated pin file can very easily slot into pbp
    just cut out the comments and the c bits you don't need load replace all the 0x with $
       Generated Pin Manager File
       Company:
         Microchip Technology Inc.
       File Name:
         pin_manager.c
       Summary:
         This is the Pin Manager file generated using PIC10 / PIC12 / PIC16 / PIC18 MCUs
       Description:
         This header file provides implementations for pin APIs for all pins selected in the GUI.
         Generation Information :
             Product Revision  :  PIC10 / PIC12 / PIC16 / PIC18 MCUs - 1.65.2
             Device            :  PIC18F26K42
             Driver Version    :  2.01
         The generated drivers are tested against the following:
             Compiler          :  XC8 1.45
             MPLAB             :  MPLAB X 4.15
         Copyright (c) 2013 - 2015 released Microchip Technology Inc.  All rights reserved.
         (c) 2018 Microchip Technology Inc. and its subsidiaries.
         Subject to your compliance with these terms, you may use Microchip software and any
         derivatives exclusively with Microchip products. It is your responsibility to comply with third party
         license terms applicable to your use of third party software (including open source software) that
         may accompany Microchip software.
         THIS SOFTWARE IS SUPPLIED BY MICROCHIP "AS IS". NO WARRANTIES, WHETHER
         EXPRESS, IMPLIED OR STATUTORY, APPLY TO THIS SOFTWARE, INCLUDING ANY
         IMPLIED WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY, AND FITNESS
         FOR A PARTICULAR PURPOSE.
         IN NO EVENT WILL MICROCHIP BE LIABLE FOR ANY INDIRECT, SPECIAL, PUNITIVE,
         INCIDENTAL OR CONSEQUENTIAL LOSS, DAMAGE, COST OR EXPENSE OF ANY KIND
         WHATSOEVER RELATED TO THE SOFTWARE, HOWEVER CAUSED, EVEN IF MICROCHIP
         HAS BEEN ADVISED OF THE POSSIBILITY OR THE DAMAGES ARE FORESEEABLE. TO
         THE FULLEST EXTENT ALLOWED BY LAW, MICROCHIP'S TOTAL LIABILITY ON ALL
         CLAIMS IN ANY WAY RELATED TO THIS SOFTWARE WILL NOT EXCEED THE AMOUNT
         OF FEES, IF ANY, THAT YOU HAVE PAID DIRECTLY TO MICROCHIP FOR THIS
         SOFTWARE.
     #include <xc.h>
     #include "pin_manager.h"
     #include "stdbool.h"
     void PIN_MANAGER_Initialize(void)
         LATx registers
        LATA = 0x00;
        LATB = 0x01;
        LATC = 0x02;
         TRISx registers
         TRISA = 0xFF;
        TRISB = 0xFC;
        TRISC = 0x41;
         ANSELx registers
         ANSELC = 0x01;
        ANSELB = 0xF0;
        ANSELA = 0xFF;
         WPUx registers
         WPUE = 0x00;
        WPUB = 0x00;
        WPUA = 0x00;
        WPUC = 0x00;
         ODx registers
        ODCONA = 0x00;
        ODCONB = 0x00;
        ODCONC = 0x00;
        SPI1SDIPPSbits.SPI1SDIPPS = 0x16;   //RC6->SPI1:SDI1;
        RC4PPS = 0x1E;   //RC4->SPI1:SCK1;
        SPI1SCKPPSbits.SPI1SCKPPS = 0x14;   //RC4->SPI1:SCK1;
        RC5PPS = 0x1F;   //RC5->SPI1:SDO1;
     void PIN_MANAGER_IOC(void)
      End of File
  1. Problem with I2Cread command for an 32 bits ADC
    By Pilou81 in forum mel PIC BASIC Pro
    Last Post: - 27th October 2011, 16:32
  2. Need help to get I2CRead woriking
    By w7ami in forum mel PIC BASIC Pro
    Last Post: - 29th November 2007, 17:22
  3. Problem with I2Cread and I2CWRITE function
    By Tony85 in forum mel PIC BASIC Pro
    Last Post: - 6th June 2006, 21:03
  4. Problem with I2Cread and I2CWRITE function
    Last Post: - 6th June 2006, 19:32
  5. I2CRead / I2CWrite Problem?
    By koossa in forum mel PIC BASIC Pro
    Last Post: - 31st October 2005, 19:26
