PIC16F18855 and DT elapsed timer
Results 1 to 3 of 3
    Porto - Portugal
    Default PIC16F18855 and DT elapsed timer
    Hello to you all,
    As PIC16F876A become obsolete I decided to use PIC16F18855 to replace it, it is much cheaper than the old PIC16F876A and has more features.
    I implemented the code below (using PBP3) to get sure that the faithfull ELAPSED TIMER from Darrol's would still work with the new PIC
    ''* Name : test_pic16f18885.PBP *
    '* Date : 17-10-2018 *
    '* Version : 1.0 *
    '* Notes : *
    __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON ; pag 92
    __config _CONFIG2, _MCLRE_ON & _PWRTE_ON & _LPBOREN_OFF & _BOREN_ON & _BORV_LO & _ZCD_OFF & _PPS1WAY_OFF & _STVREN_ON & _DEBUG_OFF ;pag 93
    __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    __config _CONFIG4, _WRT_ON & _SCANE_available & _LVP_ON
    __config _CONFIG5, _CP_ON & _CPD_OFF
    DEFINE OSC 08
    OSCFRQ = %11
    include "DT_INTS-14.bas"
    include "Elapsed_INT.bas"
    Clear
    ANSELA = 0
    ANSELB = 0
    ANSELC = 0
    TRISA=%11111100
    TRISB=%11111111
    TRISC=%11111111
    StatLED VAR PORTA.0
    LED var PORTA.1
    led =0
    led=1 ' to make sure PIC is running
    if SecondsChanged = 1 then
    SecondsChanged = 0
    Toggle StatLED ' counting seconds is "alive"
    led=1
    However the compilation always return:
    [ASM ERROR] Symbol not previously defined (INT_ENTRY) (0) : ERROR[113)
    [MESSAGE] pic16lf18855.pbpinc(603): HPWM command only supports CCP channels (not PWM channels).
    Can any of you tell me how to solve this?
    Thank's in advance
    Vicente
    nomada
    Default Re: PIC16F18855 and DT elapsed timer
    Several versions of ELAPSED_INT seems to exist. One that predates the existance of DT-Ints and one which is supposed to work WITH DT-Ints. For the one that's using DT-Ints it looks like you also need to include ReEnterPBP.bas file. Here's an example by Darrel himself, from this thread:
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    INCLUDE "Elapsed_INT.bas"  ; Elapsed Timer Routines
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
        INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    GOSUB ResetTime           ' Reset Time to  0d-00:00:00.00
    GOSUB StartTimer          ' Start the Elapsed Timer
      IF SecondsChanged = 1 THEN
         SecondsChanged = 0
         LCDOUT $FE,2, DEC Days,"d-",DEC2 Hours,":",DEC2 Minutes,":",DEC2 Seconds
    GOTO Main
    Also, OSCFRQ = %11 can't be right but I suspect that it's the forum messing with the text.
    When posting code, please use the proper code tags.
    Jan 2006
    Istanbul
    Henrik posted the same code 1 second before me. So I deleted mine.
  1. DT Elapsed Timer Question
    By rocket_troy in forum PBP3
    Last Post: - 10th August 2018, 07:34
  2. DT Elapsed Timer
    Last Post: - 15th December 2017, 00:21
  3. Elapsed Timer findings
    By Art in forum General
    Last Post: - 18th June 2015, 20:14
  4. SPWM and Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 8th May 2008, 04:16
  5. DT Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 00:17
