How does 2N3055 work here?
Results 1 to 2 of 2
    Aug 2016
    Default How does 2N3055 work here?
    Good day,all
    In a lot of power supplies the main transformer has several outputs, which are switched via a relay when the supply output exceeds a certain voltage.
    Below is a Mastech HY1803 psu schematic - the SK1 relay switches the transformer outputs, while the schematic around the U2A opamp handles the switching after the output voltage exceeds 5V.
    The question is - why is that switch needed? Am I understanding it right that it is just to lower the transformer output voltage when the voltage on the psu output is lower than 5V and lower the 2N3055 dropout voltage and, therefore, the power dissipation? Are there any other reasons to do that?
    Default Re: How does 2N3055 work here?
    wasn't the answer from stack exchange good enough when asked 9 months ago ?
    https://electronics.stackexchange.co...nsformer-relay
    where this was copied from
  1. Looking for work!
    By Art in forum Off Topic
    Last Post: - 16th January 2017, 07:11
  2. Paid work anyone?
    By George in forum mel PIC BASIC Pro
    Last Post: - 19th October 2010, 04:23
  3. Cant get it to work
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 9th April 2010, 10:21
  4. Will This program work
    By deepgfishing in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 23:45
  5. does this work?
    By igor@24 in forum mel PIC BASIC Pro
    Last Post: - 13th June 2005, 20:19
