+ Reply to Thread
Results 1 to 8 of 8
    Jun 2011
    Indian Harbour Nova Scotia
    Default inverting all bits in a byte
    How do I invert all the bits in a byte?
    Eg %011010110 would become %100101001
    I assumed, then read it was by using the tilde (~) function but I'm having trouble using it in code.
    eg if I had byteA=%011010110
    and I did this: byteA=~byteA, shouldn't ~byteA display %100101001?
    Strangely I can display the value of byteA in the display (LabX1) but ~byteA comes up empty.
    Default Re: inverting all bits in a byte
    how many bits in a byte ? not 9
    what display? , how displayed ?
    if its a common garden variety lcd , chrs in this range 127 < chr >160 are not in the built in font
    so using var A = $66
    A will print on lcd
    ~A ($99) will not print on lcd
    Northeast
    There is a simple ASM command, COMF. This is what it would look like:
    @ BANKSEL _byteA
    @ COMF _byteA, F
    The first line moves the BSR (Bank Select Register) to the BANK containing your variable. The variable is preceded by an underscore for ASM; _byteA.
    The second line executes the command, Compliment F (F is your variable). The appending ", F" puts the result back in your variable, byteA.
    Hope this helps
    Use the ^ operator for Bitwise Exclusive OR
    ByteA = ByteA ^ %11111111 Inverts the bits of ByteA
    Jun 2011
    thanks Dick
    Jun 2011
    I have the new "enhanced" byte, with 9 bits.
    Aug 2003
    Australia
    Using comf would be about twice as fast there since you don’t have to do anything at all with the literal 0xFF.
    Jan 2006
    Istanbul
    Why not just use grandpa's way:
    byte = 255- byte
    Inverts the bits.
  1. An easy way to get bits to byte
    Last Post: - 6th November 2015, 11:16
  2. Problem with bits in byte array....
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 19th October 2011, 06:27
  3. Accessing several bits together in a byte or word...
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 7th May 2007, 18:07
  4. Bits in Byte Arrays
    By crhomberg in forum mel PIC BASIC Pro
    Last Post: - 24th April 2007, 22:37
  5. reading first four bits of a byte
    By kamet in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2007, 08:50
Members who have read this thread : 32
