+ Reply to Thread
Results 1 to 14 of 14
    Default Error when compiling with DT_INTS_3_4b"
    I have been using the modified DT_INTS_3_4b for some time but, now when I try to use LOW PRIORITY interrupts I get the following ASM ERROR's:
    : Illegal character (=)
    : Symbol not previously defined (K40 family)
    I have been using the 18F27K40 and have now tried to use the 18F47K40 with LOW PRIORITY interrupts.
    Code excerpts in order are below:
    INCLUDE "C:\PBP\INCLUDES\DT_INTS-18_3_4b.bas" ' Interrupt Control routines
    INCLUDE "C:\PBP\INCLUDES\ReEnterPBP-18.bas" ' Interrupt Control routines
    INCLUDE "C:\PBP\INCLUDES\ReEnterPBP-18LP.bas" ; Include if using Low Pr. PBP INTS
    DEFINE OSC 64
    DEFINE USE_LOWPRIORITY 1
    asm
    ;----[High Priority Interrupts]-----------------------------------------------
    ;LINEAR or ROTARY ENCODER INPUT - A (INCREMENT POSITION)
    INT_Handler INT0_INT, _INC_C, PBP, yes
    ;LINEAR or ROTARY ENCODER INPUT - B (DECREMENT POSITION)
    INT_Handler INT1_INT, _DEC_C, PBP, yes
    INT_CREATE ; Creates the High Priority interrupt processor
    ;----[Low Priority Interrupts]------------------------------------------------
    INT_LIST_L macro ; IntSource, Label, Type, ResetFlag?
    INT_Handler TX1_INT, _UARTTX1, PBP, no
    INT_Handler RX1_INT, _UARTRX1, PBP, no
    INT_Handler TX2_INT, _UARTTX2, PBP, no
    INT_Handler RX2_INT, _UARTRX2, PBP, no
    INT_Handler TMR1_INT, _TIMR1, PBP, yes
    INT_CREATE_L ; Creates the LOW Priority interrupt processor
    This coding works perfectly with an 18F26K22 and 18F46K22 before changing to DT_INTS18_3_4b.
    Any help would be appreciated...
    EN82fn
    Default Re: Error when compiling with DT_INTS_3_4b"
    Dave,
    Seems that there were a few mistakes when the low priority interrupts were defined. Try this new version (3.4c) and see if it works out.
    It compiled ok using the test code below, but I didn't try actually running it
    '18F27K40
    DEFINE OSC 64
    INCLUDE "DT_INTS-18_3_4c.bas" ' Interrupt Control routines
    INCLUDE "ReEnterPBP-18.bas"      ' Interrupt Control routines
    INCLUDE "ReEnterPBP-18LP.bas"   ' Include if using Low Pr. PBP INTS
    GIEH    VAR INTCON.7        ' high priority interrupts
    GIEL    VAR INTCON.6        ' low priority interrupts
    asm
        INT_Handler TMR1_INT, _TIMER1, PBP, yes
    goto OverIntHandlers
    INC_C:
    @ INT_RETURN
    DEC_C:
    @ INT_RETURN
    UARTTX1:
    @ INT_RETURN
    UARTRX1:
    @ INT_RETURN
    UARTTX2:
    @ INT_RETURN
    UARTRX2:
    @ INT_RETURN
    TIMER1:
    @ INT_RETURN
    OverIntHandlers:
    '----[ Interrupt control ]-------------------------------------------------------
    NOP
    GIEL = 1     ' Enable low priority interrupts
    GIEH = 1     ' Enable global interrupts
    Tumbleweed, It works a treat. Thanks... Wow these K40's can really be a pain but, twice the memory. I only wish my UMC Loader worked with them...
    EN82fn
    Great. Glad it's working.
    I've got a 27K40 floating around here someplace. When I get a chance I'll see if I can get a UMC build together that works with it.
    I believe the problem is with the UMCBuild.exe file that needs to be changed. I have tried a few times with the config's set for the appropriate devices and all I get is the message "Device not Self Programmable". I have emailed David Barker and he said that he will not support new devices for that Bootloader any more.
    EN82fn
    UMCBuild.exe requires mpasm and some of the files from the old MPLAB8, but you need mpasmx from MPLABX to support the K40. Add to that it's possible MPLABX no longer includes some of the files UMCBuild is looking for.
    I'm pretty sure I can knock something together for you... I just need some free time to look at it.
    Well, it turned out that there are so many changes required to get umcbuild to use mpasmx it just wasn't worth the bother.
    Here's the asm source for a UMC loader that works with the K40 (at least the 27K40... the only one I tried).
    You'll have to change the entries in the USER CONFIGURATION SECTION to match what you're using.
    Right now it's setup for an 18F27K40, 16MHz intosc, and uart1 on RC6/RC7.
    There are no other files required except for the mpasmx p18FxxK40.inc file. Don't use umcbuild.exe... just assemble it with mpasmx
    Thanks Tumbleweed, I will give it a try when I get home from work tonight and let you know.
    EN82fn
    Well Tumbleweed, I just couldn't wait to try it out. It all looks good. The only error I got when compiling was "undefined symbol":
    ; check to make sure program fits 26-5-2018
    #if $ > DEVICE_ROM
    error "program code exceeds flash size. change LOADER_SIZE_MIN"
    #endif
    I just commented them out and away we go....
    Once again, Thanks for the mod's.
    EN82fn
    That's odd... I don't get that.
    That size check is there to make sure the loader doesn't grow bigger than what's reserved (this one's a bit larger at 512 bytes vs 384).
    What version of mpasmx are you using? I was using 5.77
    It says, V5.778 in the toolchain. I did notice and have worked on trying to get the bootloader to work with usart2 with no success. I don't understand why?
    I have attached the modified version. Maybe if you can, take a look?
    EN82fn
    All of the control registers for UART1 are in the access bank so you can get away with not using banksel to get to them.
    UART2 registers are in a different bank (bank 14, 0x0E99-0x0E9F) so you have to load the BSR (ie BANKSEL RC2STA) to access them.
    You can still use UART1 but assign it to different pins with the PPS... that would be a lot easier (and smaller) than adding all the code to get at UART2.
    Tumbleweed, I think I will go the ( BANKSEL RC2STA) route because I use the uart1 for different communications to remote arrays. Thanks for the advice, I should have seen that. I am by no means an asm guru but I do know enough to get into trouble.....
    EN82fn
    Well, This has been a prosperous morning as I have the bootloader running on com2. For this project I need to bootload it over Bluetooth. Thanks so much Tumbleweed for the advice. I can see a whole new future with these K40's.... Thanks...
    EN82fn
  1. Replies: 0
    Last Post: - 14th November 2013, 03:32
  2. Error while compiling
    By BobK in forum mel PIC BASIC Pro
    Last Post: - 20th April 2013, 17:01
  3. Replies: 1
    Last Post: - 30th March 2012, 04:13
  4. Compile error & syntax error on the word "loop:" as a label?
    Last Post: - 7th March 2010, 04:14
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 14:31
Members who have read this thread : 19
