Mplabx 4.15
Results 1 to 3 of 3
Thread: Mplabx 4.15
    Default Mplabx 4.15
    I recently up graded MPLABX to 4.15 and want to move the PB3 toolchain to the new IDE. Question: will I have a choice of programmers, PK3 or the PBP USB programmer? If a program with a pbp. extension is imported into the project will this bring the other files with it? Still trying to get a handle on the integrating of the two. I am willing to rewrite code if it's the only way to move over. I did see the video on the PBP3 site and it didn't get into the details.
    Aug 2011
    Default Re: Mplabx 4.15
    ...and want to move the PB3 toolchain to the new IDE
    I'm not sure there's much benefit in that. I can't really think of any new features you'd get, and if MCSP works for you you'd probably be loosing some.
    You'd only be able to choose programmers supported by MPLABX, so you'd loose the USB programmer. There's no way to add custom programmers to MPLABX like there is with MCSP.
    Thank you for the reply and I agree. I'll hold off on this. The reason is more of convenience. Some older project code is in assembly in the MPLAB IDE.
  1. Installing PBP3.1 with MPLAB 8 AND MPLABX
    By MikeBZH in forum General
    Last Post: - 4th April 2023, 19:41
  2. How to setup pbp3 with MPLABX?
    By thasatelliteguy in forum mel PIC BASIC Pro
    Last Post: - 20th November 2017, 12:46
  3. mplabx and dt ints 18
    By richard in forum General
    Last Post: - 21st July 2015, 21:15
  4. Integrate PBP3 in MPLABX.
    By Ziko87 in forum PBP3
    Last Post: - 21st May 2013, 13:41
  5. Can't get ISIS/Proteus VSM to work with PBP3 and MPLABX
    By chicowoodhill in forum mel PIC BASIC Pro
    Last Post: - 28th July 2012, 20:45
