Again about array
+ Reply to Thread
Results 1 to 7 of 7
    Dec 2008
    Ploiesti, ROMANIA
    Default Again about array
    Hi !
    I tried to read 10 samples of ADC values and sending to LCD display.
    DataW 	var word[10]
    i       var byte
    for i=0 to 9
        ADCON0.1 = 1			' Start conversion
    	While ADCON0.1=1:Wend		' Wait for conversion
    	DataW.HighByte=ADRESH		' Read variable from ADC and save
    	DataW.LowByte=ADRESL
    	pause 50
    next i
    IF DATAW < 1023   THEN
          LCDOUT $fe,1
          for i=0 to 9
          lcdout dec dataw[i], " "
          next i
          endfor
    PAUSE 1000
    Endif
    Goto main
    But on LCD I have the value of ADC and seven "0". (like : 77 0 0 0 0 0 0 0)
    Please, help ! What I do wrong ?
    Thanks !
    Sep 2009
    Default Re: Again about array
    Where you index your array here
    for i=0 to 9
    	pause 50
    next i
    Also high and low byte will just use first word of array.
    IF DATAW < 1023 THEN this also only reference first word of array.
    Array must be used as in LCDOUT.
    So your code should look like this
    TmpW var word
    DataW 	var word[10]
    i       var byte
    for i=0 to 9
    	TmpW .HighByte=ADRESH		' Read variable from ADC and save
    	TmpW .LowByte=ADRESL
            DataW[i]=TmpW
    	pause 50
    next i
    LCDOUT $fe,1
    for i=0 to 9
    next i
    Dec 2008
    Ploiesti, ROMANIA
    Thank you verry much ! Works fine !
    I really appreciate it !
    ...and how to continue to second line of LCD ? There is no room for ten values on the first line ...
    Something like this ?
    LCDOUT $fe,1
    for i=0 to 3
          lcdout dec dataw[i], ","
    next i
    lcdout $FE, $C0
    for i=4 to 7
    next i
    Note : there is room only for four values on the line
    Sep 2009
    That should work.
    Oct 2009
    Quote Originally Posted by fratello View Post
    Line 1 = $80
    Line 2 = $C0
    If you have a 4 line LCD
    Line 1 = $fe,$80,
    Line 2 = $fe,$C0,
    Line 3 = $fe,$94,
    Line 4 = $fe,$d4,
    Then you can only fit 8 values!
    For 10 I guess you have to use a larger display or maybe use hex notation.
    Dec 2008
    Ploiesti, ROMANIA
    Yes, I use only 8 value.
    Thank you, all !
  1. Copying Array to Array
    By vamtbrider in forum mel PIC BASIC Pro
    Last Post: - 24th April 2010, 01:12
  2. Custom array of ports using array?
    By blainecf in forum mel PIC BASIC Pro
    Last Post: - 18th June 2006, 01:43
  3. Array
    By ripmax in forum mel PIC BASIC Pro
    Last Post: - 29th March 2006, 22:21
  4. Array
    By p5taylor in forum mel PIC BASIC
    Last Post: - 20th February 2006, 21:08
  5. Word array behaving like byte array.... wierd
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2005, 15:43
Members who have read this thread : 18
