+ Reply to Thread
Results 1 to 6 of 6
    Mar 2018
    Default 18F26K42 TMR1 Interrupt troubles
    Hello, I am a first-time caller, long time listener. You folks and this forum have been a wealth of knowledge over the years and I just wanted to say thank you. I currently have a problem that I haven’t been able to crack, I am sure I am missing something but just don’t know what.
    I am trying to get a TMR1 overflow interrupt (no vectors, I turned them off, I think) to work on a 18F26K42. I tried using the DT_INTS-18K42b.bas routine by MPGMike but kept getting a compile error, specifically on the SaveFSR (0), (1), and (2) lines. Based on an earlier post I went into the DT_INTS-18K42b.bas file and replaced the “movff”with “movffl” but that didn’t seem to help either. The test code is below:
        CONFIG FEXTOSC = OFF
        CONFIG RSTOSC = HFINTOSC_64MHZ
        CONFIG CLKOUTEN = OFF
        CONFIG PR1WAY = OFF
        CONFIG CSWEN = ON
        CONFIG FCMEN = OFF
        CONFIG MCLRE = INTMCLR
        CONFIG PWRTS = PWRT_OFF
        CONFIG MVECEN = OFF                        ;disable vector table
        CONFIG IVT1WAY = OFF
        CONFIG LPBOREN = OFF
        CONFIG BOREN = OFF
        CONFIG BORV = VBOR_245
        CONFIG ZCD = OFF
        CONFIG PPS1WAY = OFF
        CONFIG STVREN = OFF
        CONFIG DEBUG = OFF
        CONFIG XINST = OFF
        CONFIG WDTCPS = WDTCPS_31
        CONFIG WDTE = OFF
        CONFIG WDTCWS = WDTCWS_7
        CONFIG WDTCCS = LFINTOSC
        CONFIG BBSIZE = BBSIZE_512
        CONFIG BBEN = OFF
        CONFIG SAFEN = OFF
        CONFIG WRTAPP = OFF
        CONFIG WRTB = OFF
        CONFIG WRTC = OFF
        CONFIG WRTD = OFF
        CONFIG WRTSAF = OFF
        CONFIG LVP = OFF
        CONFIG CP = OFF
    'Defines, Includes, and Constants-----------------------------------------------
    DEFINE OSC 64                                    ' Calibrate PBP to 64MHz clock
    OSCFRQ = 001000                               ' Set system clock to 64MHz internal
    INCLUDE "DT_INTS-18_k42b.bas"         ; Base Interrupt System
    include "ReEnterPBP.bas"
    INT_LIST macro            ; IntSource,      Label,     Type, ResetFlag?
             INT_Handler      TMR1_INT,         _INC_TICK, PBP, YES
        ENDM
        INT_CREATE
    'Direction----------------------------------------------------------------------
    TRISA = 000000
    TRISB = 000000
    TRISC = 000000
    'Alias---------------------------------------------------------------------------
    LED   var PORTA.1
    'Variables----------------------------------------------------------------------
    'Initialize Registers----------------------------------------------------------------------
    Initialize:
        ANSELA   = 000000                      ' Set digital
        ANSELB   = 000000                      ' Set digital
        ANSELC   = 000000                      ' Set digital
        ADCON0   = 000000                     ' Disable ADC
        CM1CON0.7 = 0 : CM2CON0.7 = 0         'Disable comparators
        PMD0=$FF : PMD1=$FF : PMD2=$FF      'Turning off all Peripheral-
        PMD3=$FF : PMD4=$FF : PMD5=$FF      '-Modules, not sure if this is nessesary
        PMD6=$FF : PMD7 = $FF
        PMD1.bit1 = 0                                      'Enable the TMR1 module
        T1CON = 110000                                  'Prescale 1:8; Disable the TMR1
        T1GCON.bit7 = 0                                  'Disable gate, TMR1 always counting
        T1CLK = 000001                                   'Clock Source Fosc/4
        TMR1H = $00 : TMR1L = $00
    @   INT_ENABLE  TMR1_INT
        LED = 0
    'Code---------------------------------------------------------------------------
        pause 1
        Goto Main
    '----- INTERRUPT CODE -------------------
    INC_TICK:
             toggle LED
             TMR1L = $00 : TMR1H = $00
             PIR4.bit0 = 0
    @ INT_RETURN
    '------ END OF INTERRUPTS CODE ----------
    Next, I tried the simple old “ON INTERRUPT GOTO” function of PBP3. The code below seems to compile, it just doesn't work. I can confirm that the TMR1H and TMR1L registers increase to 65535 and then wrap around to 0 and increase again, etc. The interrupt just never occurs. I am using an oscilloscope to monitor the LED pin.
        CONFIG PR1WAY = OFF
        CONFIG CSWEN = ON
        CONFIG FCMEN = OFF
        CONFIG MVECEN = OFF
        CONFIG BOREN = OFF
        CONFIG ZCD = OFF
        CONFIG STVREN = OFF
        CONFIG DEBUG = OFF
        CONFIG XINST = OFF
        CONFIG WDTE = OFF
        CONFIG BBEN = OFF
        CONFIG SAFEN = OFF
        CONFIG WRTAPP = OFF
        CONFIG WRTB = OFF
        CONFIG WRTC = OFF
        CONFIG WRTD = OFF
        CONFIG WRTSAF = OFF
        CONFIG LVP = OFF
        CONFIG CP = OFF
    on interrupt goto INC_TICK
    TRISA = 000000
    TRISB = 000000
    TRISC = 000000
    LED    VAr PORTA.1
    Initilize:
        PMD1.bit1 = 0   'Turning on the TMR1 peripheral module
        PIR4.bit0 = 0                                             'Clear the Int flag
        PIE4.bit0 = 1                                             'Enable timer int
        INTCON0.bit7 = 1                                      'Enable global int
        T1CON.bit0 = 1                                         'Start the timer
        LED = 0
        pause 1
        Goto Main
    Disable
    INC_TICK:
             toggle LED
             PIR4.bit0 = 0
             Resume
    enable
    I apologize for throwing two sets of code at you. I would be very happy if I could get either method to work. Software particulars: PBP 3.1.1.4; MPASM 5.0.0.5; MPLABX 5.76; Microcode Studio Plus 4.05. I am guessing I missed something or forgot to turn something on. I would love to learn more about "DEFINE INTHAND" but would be very happy to get any timer interrupt to work with any method possible at this point.
    Any advice would be appreciated.
    -Jon
    Default Re: 18F26K42 TMR1 Interrupt troubles
    I don't have a definitive answer for you but here's a couple of things.
    First, if you haven't already, make SURE that you have Control of the pin where you have the LED connected. Make it blink a couple of times at startup or whatever.
    In case there's something weird with the .BIT modifier I'd try the "standard" PIR4.0 syntax. I'm not sure it's even any difference under the hood but just to make sure.
    In your main code, do:
    IF PIR4.0 = 1 THEN
      TOGGLE LED
       PIR4.0 = 0
    That'll tell you if the interrupt flag gets set or not.
    your code would toggle led @32mS intervals , its a bit hard to see .
    I can't compile pbp3 for this chip but can say that these settings work in xc8
        CONFIG PR1WAY = OFF
        CONFIG CSWEN = ON
        CONFIG FCMEN = OFF
        CONFIG MVECEN = OFF
        CONFIG BOREN = OFF
        CONFIG ZCD = OFF
        CONFIG STVREN = OFF
        CONFIG DEBUG = OFF
        CONFIG XINST = OFF
        CONFIG WDTE = OFF
        CONFIG BBEN = OFF
        CONFIG SAFEN = OFF
        CONFIG WRTAPP = OFF
        CONFIG WRTB = OFF
        CONFIG WRTC = OFF
        CONFIG WRTD = OFF
        CONFIG WRTSAF = OFF
        CONFIG LVP = OFF
        CONFIG CP = OFF
    OSCFRQ = 8                              ' Set system clock to 64MHz internal
    OSCCON1 = $60
    TRISA.1 = 0
    LED    VAR LATA.1
    Initilize:
        ANSELA   = 0                      ' Set digital
         LED = 0
        INTCON0.7 = 1                                      'Enable global int
        T1CON = $35                                          'Prescale 1:8; enable the TMR1
        T1CLK = 1                                           'Clock Source Fosc/4
        PIR4.0 = 0                                             'Clear the Int flag
        PIE4.0 = 1                                             'Enable timer int
                                            'Start the timer
    C0UNTER VAR BYTE
        pause 1
        Goto Main
    Disable
    INC_TICK:
             COUNTER=COUNTER+1
             IF COUNTER==31 THEN
             LED=!LED           ;TOGGLE LED ONCE PER SEC
             COUNTER=0
             PIR4.0 = 0
             Resume
    enable
    Mar 2018
    Sorry for the delay. I responded a week ago, but maybe I responded to the wrong post? Thank you for your feedback.
    Henrik- As far as I know I have control of the LED pin, I made a simple blinky light to prove it to myself on that pin. I also implemented the startup blink as you’ve suggested just to make sure I didn’t change anything. I changed the bit syntax (which I like better) but no luck.
    I also modified my code as you suggested, no luck. This must mean I didn’t set the interrupt, but I’m not sure what I am missing. I remember there used to be 3 int register bits that need to be set the peripheral, unmasked peripherals, and a global. Here I am only setting 2. Feels weird.
    Richard- I agree the light blink is a bit quick. I have an oscilloscope I’m using on the pin to help me out. Originally, I was trying to interrupt on TMR0 with a prescale of 1:32768 and a TMR0H and TMR0L of $FE17 or about (if I did my math right) 1 second. No luck there either.
    Thanks again for your feedback.
    Northeast
    SecaRider, my hat is off and a knee is bent to respect your tenacity tackling the new K42. For starters, practically all of the latest PIC offerings responded to the tweaks in the PIR/PIE listings for the DT_INTS-xx.bas routines. It was discussed previously that due to the extended memory range, the DT_INTS would require a much more intensive revamp to work with the K42 PICs.
    With that said, "DEFINE INTHAND" is a DEFINE that directs the compiler to send the PC (Program Counter) to whatever you specify as your Interrupt Handler. Ultimately, with Vectored Interrupts turned off, that address will be 0x08. Universally agreed upon is the practice of placing your Interrupt Handler as close to the top of your Code Page as possible, with a command, "GOTO MAIN" (or START, or INIT) above your Interrupt Handler Label. DEFINE INTHAND is used only for Assembly Code interrupts. I don't know how proficient you are at ASM. There are work-arounds with w-save variables for "W", "BSR", "STATUS" and maybe some variables. Theoretically you could use INTHAND to go to an Interrupt Handler that uses PBP. The variables probably won't survive the RETURN intact (suggested by more skilled programmers in previous topics). If nothing else, you could INTHAND with your Interrupt Handler to "CALL" (ASM version of GOSUB) another PBP scripted subroutine.
    The K42s are different enough from anything else ever created in the PIC 8-bit lineup that they must be treated carefully. I hope this helps point you in a better direction.
    Mar 2018
    mpgmike - I fear it is less about tenacity and more about stubbornness and a little bit of self loathing. Thank you for the synopsis on the "DEFINE INTHAND," this is very useful information. I have a working knowledge of ASM. To me, it is easier to read than write. Your post did indeed help me decide a newer direction...K40's! Thanks again.
  1. 12F683, TMR1 and ON INTERRUPT revisited
    By AvionicsMaster1 in forum PBP3
    Last Post: - 17th September 2013, 19:07
  2. Difficulty toggling LED with TMR1 overflow interrupt
    By jgjgjg in forum mel PIC BASIC Pro
    Last Post: - 30th July 2012, 11:17
  3. How to set Tmr1 to interrupt every 5 seconds
    Last Post: - 3rd December 2008, 03:51
  4. TMR1 100Hz Exactly Interrupt Routine
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 15th February 2007, 05:51
  5. TMR1 interrupt question
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 15th February 2006, 03:02
Members who have read this thread : 26
