SPI hardware communication issue
+ Reply to Thread
Results 1 to 7 of 7
    Apr 2012
    Leicester UK
    Default SPI hardware communication issue
    Hello,
    Can I have some guidance, I have written the code below to drive a set of LEDs attached to a SN74HC595, I am using a PIC16F1825 to drive the SN74HC595.
    3 LEDs are attached to the PIC16F1825 to provide feedback that the code is cycling as expected. These all function correctly.
    The connection between the PIC and the shift register is as below:
    PIC16F1825 SN74HC595
    SDO PIN 3 RA4 PIN 14 SER
    SDI PIN 9 RA5 Floating Not Connected
    SCK PIN 10 RC0 PIN 11 SRCLK
    Latch out PIN 11 RA2 PIN 12 RCLK
    Common ground and 5V power supply is provided to both the PIC and shift register. no resistors or capacitors are connected between the PIC and the shift register.
    LEDs are connected to the 9 outputs of the shift register.
    The LEDs attached to the shift register stay lit, but do not cycle off, or make any of the expected patterns.
    What am I doing wrong? Thank you in advance.
    TxData var BYTE
    define OSC 4
    OSCCON = %01101010
    HC_Data var PORTA.4       'SDO
    HC_Clk var PORTC.0        'SCK
    HC_latch var PORTA.2      'Digital output
    LED_YELLOW var PORTA.1
    LED_GREEN var PORTC.3
    LED_RED var PORTA.0
    TRISA = 0                 'all digital outputs
    PORTA = 0                 'make all pins low
    ANSELA = 0
    TRISC = %00000010         'all digital outputs except port 1
    PORTC = 0                 'make all pins low
    ANSELC = 0
    APFCON0 = %01000000          'set SPI pin alternative
    SSP1STAT = %00000000
    SSP1CON1 = %01100010
    SSP1CON3 = %00010000
    txdata = 0                   'SPI output byte
    pause 200                    'prove LED function
    LED_YEllow = 1
    LED_Green = 1
    LED_red = 1
    pause 200
    LED_YEllow = 0
    LED_Green = 0
    LED_red = 0
    Main:                                   'set up sequence of signals for output
                        LED_Yellow = 1
    TxData = %10101010
    Gosub Send_Data
    TXDATA = %00000000
    Gosub Send_Data
    TxData = %10000000
    Gosub Send_Data
    TxData = %01000000
    Gosub Send_Data
    TxData = %00100000
    Gosub Send_Data
                        LED_Yellow = 0
                        LED_gREEN = 1
    TxData = %00010000
    Gosub Send_Data
    TxData = %00001000
    Gosub Send_Data
    TxData = %00000100
    Gosub Send_Data
    TXDATA = %00000010
    Gosub Send_Data
    TXDATA = %00000001
    Gosub Send_Data
                        LED_GREEN = 0
    Send_Data :
    SSP1CON1.5 = 0
    SSP1CON1.5 = 1
                        toggle LED_RED
    PAUSEUS 10
    SSP1BUF = TXDATA
    PAUSEUS 10
    HC_Latch=1
    pauseus 5
    HC_Latch=0
    pause 750
    Default Re: SPI hardware communication issue
    I don't think you have set the mssp port correctly and
    PAUSEUS 10
    SSP1BUF = TXDATA
    PAUSEUS 10
    is a dangerous way to wait for tx to complete before latching data
    try this , it works perfectly for me
    '*  Name    : SPI_74HC595.BAS                                   *
    '*  Author  : RICHARD                                           *
    '*  Notice  :                                                   *
    '*  Date    : 2/26/2018                                         *
                 __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_OFF  &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
                  __config      _CONFIG2, _PLLEN_OFF & _LVP_OFF
    TxData var BYTE
    define OSC 4
    OSCCON = %01101010
    HC_latch var LATA.2      'Digital output
    LED_RED var LATA.1
    TRISA = %11101001
    ANSELA = 0
    TRISC = %11111110         'digital output C.0
    ANSELC = 0
    SSP1CON1=$22
    SSP1STAT=$40
    LED_red = 1
    pause 200
    LED_red = 0
        TxData = 0
            Gosub Send_Data
        TXDATA = 1
            Gosub Send_Data
        TxData = 2
            Gosub Send_Data
        TxData = 4
            Gosub Send_Data
        TxData = 15
            Gosub Send_Data
    Send_Data :
    LED_RED=!LED_RED
    pir1.3=0
    SSP1BUF = TXDATA
    while ! pir1.3 :wend      ;WAIT TILL TX COMPLETES
    HC_Latch=0                ;LATCH IN NEW DATA
    ;@ NOP  ; IF NEEDED FOR HIGHER CLOCK SPEEDS
    HC_Latch=1
    Apr 2012
    Leicester UK
    Hi Richard,
    Thank you for the response, and thank you for the working example.
    I shall review it tomorrow after work.
    Just for reference what PIC did you use with that code?
    Many thanks.
    same as you 16f1825
    Apr 2012
    Leicester UK
    I uploaded that code before work and can confirm it worked perfectly, now to study it when I get home and understand where my mistakes are in my original code.
    Thank you for your help.
    Apr 2012
    Leicester UK
    My thanks goes to Richard for his help. But as a benefit to anybody else struggling with this, my corrections to my code are as follows:
    I can confirm that CLKOUT configuration line was the largest issue, as this was blocking the output of the SDO1 therefore the signal to the SN74HC595 was not being sent.
    I have taken Richard's advice to implement using the interrupt flag to check when the signal had been sent to the SN74HC595, though the my next step is to have this trigger as interrupt to control the latch while performing another routine.
    Finally changed the clock edge bit such that the signal is sent on the correct edge of the clock signal for the serial data output so the data arrives at the SN74HC595 correctly.
    This is my modified code based on my initial code:
                 __config        _CONFIG1,    _CLKOUTEN_OFF
    TxData var BYTE
    define OSC 4
    OSCCON = %01101010
    LED_RED var PORTA.0
    SSP1IF VAR PIR1.3         'SPI interrupt flag
    ANSELA = 0
    ANSELC = 0
    SSP1STAT = %01000000
    SSP1CON1 = %00100010
    'prove LED function
    LED_YEllow = 1
    LED_Green = 1
    LED_red = 1
    pause 200
    LED_YEllow = 0
    LED_Green = 0
    LED_red = 0
                        LED_Yellow = 1
    TXDATA = %00000000
    Gosub Send_Data
    TxData = %10101010
    Gosub Send_Data
    TxData = %01010101
    Gosub Send_Data
    TXDATA = %00000000
    Gosub Send_Data
    TxData = %10000000
    Gosub Send_Data
    TxData = %01000000
    Gosub Send_Data
    TxData = %00100000
    Gosub Send_Data
                        LED_Yellow = 0
                        LED_gREEN = 1
    TxData = %00010000
    Gosub Send_Data
    TxData = %00001000
    Gosub Send_Data
    TxData = %00000100
    Gosub Send_Data
    TXDATA = %00000010
    Gosub Send_Data
    TXDATA = %00000001
    Gosub Send_Data
    TXDATA = %11111111
    Gosub Send_Data
                        LED_GREEN = 0
    Send_Data :
                       toggle LED_RED
    SSP1IF = 0
    SSP1BUF = TXDATA
    while ! SSP1IF :wend      ;WAIT TILL TX COMPLETES
    HC_Latch=1
    'could need a delay here on high processor speeds or no operation commands
    HC_Latch=0
    It might be a lot less complicated to just increase the osc speed from 4MHz and clock the SPI faster. Running at 32MHz with SPICLK=8MHz it takes <2us to send out a byte... hardly worth the bother. At the speed you're running now it takes longer than that just to branch to an interrupt.
    I'd also ditch the PAUSE in the Send_Data routine.
  1. Using SPI hardware
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 13th November 2013, 19:19
  2. Hardware SPI ?
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 27th October 2013, 06:42
  3. SPI on a pic without hardware SPI?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 26th April 2006, 13:29
  4. how can i use I2C and SPI hardware
    By micro in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 15:33
  5. Hardware SPI
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 7th June 2005, 14:23
