+ Reply to Thread
Results 1 to 6 of 6
    Default problem with LCD large Numbers
    Hi all
    I have been away for a LOONG time, finally getting back working with PICs.
    I have developed a program to display large numbers on a 4x20 LCD, using PBP 2.6. The PIC is an 18F14K22.
    I used POKECODE to store the number patterns in code space, making the overall program quite efficient.
    Everything works great, except for a bug I simply cannot figure out. The code is well commented, so should be easy to follow.
    The bug is: when a three digit number is chosen with the units and tens digits BOTH ZERO, or just the tens digit is 0.
    When the number is any hundreds (100, 200, 300, etc) or a number with 0 in the tens digit (101, 306, 802, etc).
    What happens with the two zero example is: the display is there, but is flickering at a very high rate. At first I thought I might have a CLS command somewhere, but that is not it. With a number with the tens digit 0, the display totally "hangs".
    I'm really happy with the code otherwise, but have been pulling out what little hair I have left !
    The total program is posted below. Once again, I am using a 18F14K22. Perhaps someone can download the code and try it.
    DEFINE OSC 16
    OSCCON = %11110110 ' 16 MHZ INTERNAL OSCILLATOR
    TX var PORTC.0
    TRISC = %10110000
    ROW1 con 128 ' VALUES FOR THE ROWS ( USED IN PATTERN DISPLAY)
    ROW2 con 192
    ROW3 con 148
    ROW4 con 212
    ROW VAR BYTE '4 X 20 ROW NUMBER - 1 TO 4
    COL VAR BYTE '4 X 20 COLUMN NUMBER - 0 TO 19
    CHAR VAR BYTE ' SPECIAL LARGE FONT CHARACTER (1 THRU 7)
    Z VAR WORD ' USED TO SEQUENCE THROUGH THE POKED CODE
    A VAR WORD ' START POINT OF SEARCHED POKE CODE
    B VAR WORD ' END POINT OF SEARCHED POKE CODE
    NUMBER VAR WORD
    TEMP VAR WORD
    COL_OFFSET VAR BYTE ' USED TO POSITION UNITS, HUNDREDS, AND TENS
    COUNTER VAR BYTE ' A COUNTER FOR THE DIGIT NUMBER
    COUNTER = 0
    NUMBER = 369
    ' THIS IS ANY NUMBER THAT CAN BE DISPLAYED FOR TEST PURPOSES
    ' CHANGING IT WITH ZEROS IN THE UNITS AND TENS DISPLAY CAUSES A RAPID FLICKER
    ' PLACING A ZERO IN ONLY THE TENS SPACE "HANGS" THE DISPLAY ! ! !
    serout2 tx,84,[254,$01] ' CLEAR THE DISPLAY
    ''' FIRST WRITE THE CHARACTER PATTERNS TO LCD RAM FOR A PATTERN DISPLAY
    ' 0 Left-right UP-ramp (TOP)
    serout2 tx,84,[254,$40,$00,$01,$03,$07,$0F,$1F,$1F,$1F]
    serout2 tx,84,[254,ROW1, 0]
    PAUSE 1
    ' 1 Right-left DOWN-ramp (TOP)
    serout2 tx,84,[254,$48,$00,$10,$18,$1C,$1E,$1F,$1F,$1F]
    serout2 tx,84,[254,ROW1+2, 1]
    PAUSE 1
    ' 2 Left-right UP-ramp. (BOTTOM)
    serout2 tx,84,[254,$50,$1F,$1F,$1F,$1E,$1C,$18,$10,$00]
    serout2 tx,84,[254,ROW1+4, 2]
    PAUSE 1
    ' 3 Right-left DOWN-ramp (BOTTOM)
    serout2 tx,84,[254,$58,$1F,$1F,$1F,$0F,$07,$03,$01,$00]
    serout2 tx,84,[254,ROW1+6, 3]
    pause 1
    ' 4 UPPER block.
    serout2 tx,84,[254,$60,$1F,$1F,$1F,$1F,$00,$00,$00,$00]
    serout2 tx,84,[254,ROW1+8, 4]
    PAUSE 1
    ' 5 LOWER block.
    serout2 tx,84,[254,$68,$00,$00,$00,$00,$1F,$1F,$1F,$1F]
    serout2 tx,84,[254,ROW1+10, 5]
    PAUSE 1
    '6 SMALL UP-RAMP
    serout2 tx,84,[254,$70,$01,$03,$07,$0F,$1F,$00,$00,$00] '6
    serout2 tx,84,[254,ROW1+12, 6]
    PAUSE 1
    ' '7 FULL BLOCK
    serout2 tx,84,[254,$78,$1F,$1F,$1F,$1F,$1F,$1F,$1F,$1F] '7
    serout2 tx,84,[254,ROW1+14, 7]
    PAUSE 2000 ' SHORT DELAY TO DISPLAY THE SPECIAL CHARACTERS
    START: ' FIRST GET THE THREE DIGITS ( THOUSANDS WILL BE ADDED LATER)
    TEMP = NUMBER DIG 0
    COUNTER = 1 ' SPACE FOR UNITS DIGIT
    GOSUB GET_NUMBER
    TEMP = NUMBER DIG 1
    COUNTER = 2 ' SPACE FOR TENS DIGIT
    GOSUB GET_NUMBER
    TEMP = NUMBER DIG 2
    COUNTER = 3 ' SPACE FOR HUNDREDS DIGIT
    GOSUB GET_NUMBER
    GOTO START
    GET_NUMBER:
    IF TEMP = 0 THEN
    A = $2400 : B= $2448 ' these are the start and end points for the pattern for zero
    GOSUB DISPLAY
    IF TEMP = 1 THEN
    A = $2450 : B = $246C
    GOSUB DISPLAY
    IF TEMP = 2 THEN
    A = $2470 :B = $24B6
    GOSUB DISPLAY
    IF TEMP = 3 THEN
    A = $24C0 : B = $2506
    GOSUB DISPLAY
    IF TEMP = 4 THEN
    A = $2510 : B = $253E
    GOSUB DISPLAY
    IF TEMP = 5 THEN
    A = $2540 : B = $2586
    GOSUB DISPLAY
    IF TEMP = 6 THEN
    A = $2590 : B = $25DC
    GOSUB DISPLAY
    IF TEMP = 7 THEN
    A = $25E0 : B = $2608
    GOSUB DISPLAY
    IF TEMP = 8 THEN
    A = $2610 : B = $2662
    GOSUB DISPLAY
    IF TEMP = 9 THEN
    A = $2670 : B = $26BC
    GOSUB DISPLAY
    RETURN ' RETURN T0 START
    ' ZERO IS 2400 TO 2448 ONE IS 2450 TO 246C TWO IS 2470 TO 24B6
    ' THREE IS 24C0 TO 2506 FOUR IS 2510 TO 253E FIVE IS 2540 TO 2586
    ' SIX IS 2590 TO 25DC SEVEN IS 25E0 TO 2608 EIGHT IS 2610 TO 2662
    ' NINE IS 2670 TO 26BC
    DISPLAY:
    FOR Z = A TO B
    PEEKCODE z,ROW
    z=z+2
    peekcode z,COL
    z=z+2
    peekcode z,CHAR
    IF COUNTER = 1 THEN COL_OFFSET = 14 ' POSITION THE UNITS DIGIT
    IF COUNTER = 2 THEN COL_OFFSET = 9 ' POSITION THE TENS DIGIT
    IF COUNTER = 3 THEN COL_OFFSET = 4 ' POSITION THE HUNDREDS DIGIT
    COL = COL+COL_OFFSET
    SEROUT2 TX,84,[254,(ROW + COL),CHAR]
    z=z+1
    NEXT Z
    RETURN ' RETURN TO GET_NUMBER
    ''''''''''''' CODE FOR DIGITS O TO 9 '''''''''''''''''''
    '' THE ADDRESSES CHOSEN THE THE DISPLAY WERE COMPLETLY ARBITRARY ''
    '''''''''''''''''''' ZERO '''''''''''''''''
    POKECODE @$2400,128,0,0,128,1,4,128,2,4,128,3,1,192,0,7,192 ,3,7,148,0,7,148,3,7
    POKECODE @$2430,212,0,3,212,1,5,212,2,5,212,3,2 ''' ENDS AT $2448
    ''''''''''''''''''''' ONE ''''''''''''''''''
    POKECODE @$2450,128,0,8,128,1,7,192,1,7,148,1,7,212,1,7 '' ENDS AT $246C
    '''''''''''''''''''''' TWO '''''''''''''
    POKECODE @$2470,128,0,0,128,1,4,128,2,4,128,3,1,192,2,5,192 ,3,4,148,0,5,148,1,4
    POKECODE @$24A0,212,0,7,212,1,5,212,2,5,212,3,5 ''ENDS AT $24B6
    ''''''''''''''''''' THREE '''''''''''''
    POKECODE @$24C0,128,0,2,128,1,4,128,2,4,128,3,1,192,3,7,148 ,1,4,148,2,4,148,3,7
    POKECODE @$24F0,212,0,1,212,1,5,212,2,5,212,3,2 '' ENDS AT $2506
    '''''''''''''''''' FOUR ''''''''''''''
    POKECODE @$2510,128,0,7,128,3,7,192,0,7,192,1,5,192,2,5,192 ,3,7,148,3,7,212,3,7
    ' ENDS AT $253E
    ''''''''''''''''''''FIVE '''''''''''''''''''''
    POKECODE @$2540,128,0,7,128,1,4,128,2,4,128,3,4,192,0,7,192 ,1,5,192,2,5,148,3,1
    POKECODE @$2570,212,0,5,212,1,5,212,2,5,212,3,2 ''ENDS AT $2586
    ''''''''''''''''''''''''''''''''''' SIX ''''''''''''
    POKECODE @$2590,128,0,0,128,1,4,128,2,4,128,3,1,192,0,7,148 ,0,7,148,1,4,148,2,4 '
    POKECODE @$25C0,148,3,1,212,0,3,212,1,5,212,2,5,212,3,2 '' ENDS AT $25DC
    '''''''''''''''''''''' SEVEN ''''''''''''''
    POKECODE @$25E0,128,0,4,128,1,4,128,3,2,128,2,4,192,2,7,148 ,1,7,212,0,7 'ENDS AT $2608
    ''''''''''''''''''' EIGHT '''''''''''''''
    POKECODE @$2610,128,0,0,128,1,4,128,2,4,128,3,1,192,0,3,192 ,1,5,192,2,5,192,3,2
    POKECODE @$2640,148,0,0,148,3,1,212,0,3,212,1,5,212,2,5,212 ,3,2 'ENDS AT $2662
    ''''''''''''''''''''' NINE ''''''''''''
    POKECODE @$2670,128,0,0,128,1,4,128,2,4,128,3,1,192,0,3,192 ,1,5,192,2,5,192,3,7
    POKECODE @$26A0,148,3,7,212,0,3,212,1,5,212,2,5,212,3,2 ' ENDS AT $26BC
    Last edited by ozarkshermit; - 9th December 2017 at 21:17. Reason: more information
    Default Re: problem with LCD large Numbers
    I can't quite see why the pgm misbehaves like you mention ,. but I will make these comments
    peek/poke is the least efficient way to use progmem, it only stores 1 byte per every word of flash it uses
    readcode is faster and better and on a pic18 can use the entire progmem word
    there is no need to store the row/col data in the font ,the "display" routine can calculate that information along with the column offset
    the font can be compressed to this [blank added]
    asm
    db  0,4,4,1,      7,32,32,7,   7,32,32,7,    3,5,5,2      ;0
     db  32,8,7,32,    32,32,7,32,  32,32,7,32,   32,32,7,32   ;1
     db  0,4,4,1,      32,32,5,4,   5,4,32,32,    7,5,5,5      ;2
     db  2,4,4,1,      32,32,32,7,  32,4,4,7,     1,5,5,2      ;3
     db  7,32,32,7,    7,5,5,7,32,  32,32,7,      32,32,32,7   ;4
     db  7,4,4,3,      7,5,5,32,    32,32,32,1,   5,5,5,2      ;5
     db  0,4,4,1,      7,32,32,32,  7,4,4,1,      3,5,5,2      ;6
     db  4,4,4,1,      32,32,32,7,  32,32,7,32,   32,7,32,32   ;7
     db  0,4,4,1,      3,5,5,2,0,   32,32,1,      3,5,5,2      ;8
     db  0,4,4,1,      3,5,5,7,     32,32,32,7,   32,5,5,2     ;9
     db  32,32,32,32,  32,32,32,32, 32,32,32,32,  32,32,32,32  ;blank
    endasm
    fully defining the font and adding a blank make leading zero suppression/ field justification far easier
    my take for a pic18f26k22 [pbp3]
      CONFIG  FOSC = INTIO67
      CONFIG  PLLCFG = ON
      CONFIG  PRICLKEN = OFF
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = OFF
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 32768
      CONFIG  CCP2MX = PORTC1
      CONFIG  PBADEN = OFF
      CONFIG  CCP3MX = PORTB5
      CONFIG  HFOFST = ON
      CONFIG  T3CMX = PORTC0
      CONFIG  P2BMX = PORTB5
      CONFIG  MCLRE = EXTMCLR
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
    DEFINE OSC 64
    OSCCON = %01110000
    ANSELb = 0
    ANSELA = 0
    ANSELC = 0
    OSCTUNE.6=1
    goto overasm
    asm
    bigfont         ;pic18 only  must be in 1st 64k block
    ft1=_rowbuff          ;shortcut to read data into rowbuffer   0:1
    ft2=_rowbuff+2        ;shortcut to read data into rowbuffer   2:3
    GLetAddress macro Label, Wout
        CHK?RP Wout
        movlw low Label          ; get low byte
        movwf Wout
        movlw High Label         ; get high byte
        movwf Wout + 1
        BANKSEL 0
    endasm
    overasm:
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    Define LCD_Bits 4
    DEFINE LCD_LINES 4
    Define LCD_Commandus 2000
    Define LCD_DATAUS 50
     ROW VAR BYTE '4 X 20 ROW NUMBER - 0 TO 3
     COL VAR BYTE '4 X 20 COLUMN NUMBER - 0 TO 4
     slz var bit
     rows var byte[4]       ;lcd page  start addresses
     rowbuff var byte[4]    ;a row of data for lcd
     ctemp var word
     ft1  var word ext    ;shortcut to read data into rowbuffer   0:1
     ft2  var word ext    ;shortcut to read data into rowbuffer   2:3
     parsedig var byte
     NUMBER VAR WORD
     TEMP VAR WORD
     COL_OFFSET VAR BYTE ' USED TO POSITION font
     font var word       ;address of data
     NUMBER = 0
     lcdout 254,$01 ' CLEAR THE DISPLAY
     arraywrite rows,[128,192,148,212] ;pbp3 for earlier rows[0]=128:rows[0]=192: etc.........
    @ GLetAddress bigfont ,_font     ;get font address
        lcdout 254,$40,$00,$01,$03,$07,$0F,$1F,$1F,$1F
        lcdout 254,rows[0], 0
        PAUSE 1
        lcdout 254,$48,$00,$10,$18,$1C,$1E,$1F,$1F,$1F
        lcdout 254,rows[0]+2, 1
        PAUSE 1
        lcdout 254,$50,$1F,$1F,$1F,$1E,$1C,$18,$10,$00
        lcdout 254,rows[0]+4, 2
        PAUSE 1
        lcdout 254,$58,$1F,$1F,$1F,$0F,$07,$03,$01,$00
        lcdout 254,rows[0]+6, 3
        pause 1
        ' 4 UPPER block.
        lcdout 254,$60,$1F,$1F,$1F,$1F,$00,$00,$00,$00
        lcdout 254,rows[0]+8, 4
        PAUSE 1
        ' 5 LOWER block.
        lcdout 254,$68,$00,$00,$00,$00,$1F,$1F,$1F,$1F
        lcdout 254,rows[0]+10, 5
        PAUSE 1
        '6 SMALL UP-RAMP
        lcdout 254,$70,$01,$03,$07,$0F,$1F,$00,$00,$00 '6
        lcdout 254,rows[0]+12, 6
        PAUSE 1
        ' '7 FULL BLOCK
        lcdout 254,$78,$1F,$1F,$1F,$1F,$1F,$1F,$1F,$1F '7
        lcdout 254,rows[0]+14, 7
    START:     ;display 4 digits right justified with noleading zeros
        parsedig = 4
        slz = 1    ;suppress leading zeros  on
        col = 0
        while  parsedig
            parsedig = parsedig - 1
            TEMP = NUMBER DIG parsedig
            if slz  then
                if temp then      ;if temp > 0 then display it and cancel zero suppression
                    GOSUB DISPLAY
                    slz = 0   ;suppress zeros  cancelled
                    if parsedig then temp = 10;blank   suppress all zeros except for dig 0
                    GOSUB DISPLAY
                GOSUB DISPLAY
            col = col + 1
        wend
        pause 10
        NUMBER = number + 1
        if number>9999 then number=0
    GOTO START
     ;pic18 only  font must be in 1st 64k block for readcode to function
    DISPLAY:      ;disp big digit in TEMP var @ column COL       digits 0-9 and blank
        COL_OFFSET = (col*5)
        ctemp =  font + (temp*16); 16 bytes per chr
        for row = 0 to 3          ;read data as words to reduce code and more speed
            readcode ctemp,ft1      ;shortcut to read data into rowbuffer   0:1
            ctemp = ctemp + 2            ;next word
            readcode ctemp,ft2      ;shortcut to read data into rowbuffer   2:3
            ctemp = ctemp + 2            ;next row
            lcdout 254,(COL_OFFSET + rows[row]),str rowbuff\4;for early versions pbp  might need   rowbuff[0],rowbuff[1],rowbuff[2],rowbuff[3]
        next
    Richard:
    Thanks for your response. I modified your program to use with a 18F14K22, and since I have a serial LCD backpack, I changed the LCD stuff to SEROUT2. Also, no PB3 here, still on 2.6, but the program works great. Got 4 Warnings regarding the assembly stuff, I will try to figure that out, but the program runs just fine.
    My intent in developing this program was to have a routine to add to my programs that use LCD's with some numeric display requirements.
    I still plan on spending some (a little) time on my original program, to try to figure out the problem - hate to have an error like that that I do not understand.
    once again THANKS
    ozarkshermit, Attached is a program I wrote quite a few years ago to test the theory of using BIG numbers on a 4 x 20 LCD display. Enjoy...
    EN82fn
    Aug 2003
    Australia
    Your Z loop increments Z by 6 for each iteration.
    You increment Z by 5 manually within the loop, and the NEXT Z used to close the loop iterates another 1.
    If you take the difference between your start and end indexes for each digit A and B,
    the difference between A and B for digit zero is the only set that is evenly divisible by 6.
    The other digits overshoot the loop index by 2.
    Oct 2009
    Utah, USA
    You might also check this thread...
    http://www.picbasic.co.uk/forum/showthread.php?t=17707
    good luck
    Dwight
    Dwight
  1. Math problem with PBP 2.6 and 18F4550, large numbers
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2013, 04:41
  2. handling Large Numbers
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 26th April 2007, 02:33
  3. Multiplying large numbers
    By jhonea1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2006, 17:41
  4. How to display large numbers
    Last Post: - 26th March 2006, 23:17
  5. math problems - large numbers
    By Tomasm in forum mel PIC BASIC Pro
    Last Post: - 16th February 2004, 07:48
Members who have read this thread : 21
