SSD1306 INCLUDE for PBP3 - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 12
Results 41 to 49 of 49
  1. #41
    Default Re: SSD1306 INCLUDE for PBP3
    I also got the two Label after column 1 warnings (GLCDS_BAR_?CCBWC) etc but it turns out that there's a whitespace infront of those two macro labels on the include file. There was also an ELSE in column 1 causing another warning.
    i had a look at the org file i posted and it has the same errors, i always have trouble with white space
    also found 2017 version where the glcd_clrxy routine was ok, so i must have broken it when i added the bar stuff
    this is better
    glcd_clrxy:    ' clear area  x1y1 to x2 y2
       FOR GRX = 0 TO 31
            glcd_buff[GRX] = glcdData
        NEXT
        CTEMP = (1 + GX_ - GX)*(1 + GY_ -  GY)
        gosub   setxy
        glcd_rad=32
        GRX = CTEMP/32
        while grx
            gosub ssd_data
            grx=grx-1
        wend
        glcd_rad = CTEMP//32
        IF glcd_rad  THEN
            gosub ssd_data
  2. #42
  3. #43
    I'm trying to run this on 16F886
    and getting error
    ASM Symbol not previously defined FSR1L Error 113
    Any ideas?
  4. #44
    Wrong MCU selected on the IDE?
    and getting error
    my expectation is that old clunker chips with only one FSR register will likely not have enough Flash and/or Sram
    to be useful with this sort of display, the code makes no allowance for them
  6. #46
    Well, as author stated, this code is suited for 16F series and fits under 4K. 886 has 8K.
  7. #47
    I have not found FSR1L register on 886 chip...
    OK, will try with 18F2550 later and write back.
  9. #49
    Had no chance to test it yet on PBP, connected to Arduino uno for testing and launched adafruit library demos. Adjusted some speeds and quite impressed. Should I expect same speed on PIC18F2550 or it will be significantly slower?
  1. SSD1306 Include example
    By timc in forum Code Examples
    Last Post: - 28th November 2017, 08:53
  2. SSD1306 start display problem
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 14th December 2016, 19:16
  3. Using INCLUDE to add a text file in PBP3
    By Sumobob in forum PBP3
    Last Post: - 16th May 2016, 18:56
  4. PBP3 to include 18F97J94?
    By fowardbias in forum PBP3
    Last Post: - 18th December 2013, 16:42
  5. Help With OLED Display / 128X64 SSD1306
    By Denner in forum General
    Last Post: - 25th May 2013, 15:40
