MCP3201 problems
Results 1 to 17 of 17
    Dec 2008
    Ploiesti, ROMANIA
    Default MCP3201 problems
    Hi ! I tried to make an adapter for steering wheel audio controls, based on MCP3201 (since my previous tries based on PIC ADC failed, being inaccurate) . In Proteus it works fine, but in "real world" it doesn't work properly ...I can't figure out why !
    Maybe someone can point me in the right direction ! Thanks in advance !
    Default Re: MCP3201 problems
    What exactly does "doesn't work properly" mean?
    What DOES it do and what do you expect it to do? Which PIC are you using and what does your hardware look like?
    You've been around here long enough to know that a simple "doesn't work" is the wrong type of problem description. At least you did post the code so thumbs up for that ;-)
    Give us something to work with. Does the PIC run at all? Does it run at the desired speed? Do you have control over the output pins? Is it a specific routine that doesn't work as expected. Basic stuff like that....
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply !
    I attached iin my first post the Proteus simulation and the pbp file ... I used 16F676 for "driving" six resistors (for Sony players); MCP3201 must read the valiues of the steering wheel commands. But no matter what button I press, there are only two or three commands of six (Vol +, Source and seek+) and sometimes the same button does one of the three commands, randomly...
    Yes, I saw that but not everyone is fortunate to have Protues and the there are basically no comments in the code as to what the intention of it is nor for which processor it's intended. But now we know :-)
    Do you have the serial display in the actual prototype as well? In that case you can determine if the values are being read correctly and the logic is at fault OR if the problem is either with the code reading the ADC or possibly with the hardware itself.
    Speaking of hardware, I don't see a single decoupling capacitor in the schematic. Things like that may fly in simulation, seldom in real life.
    The code seems to decode the the expected ADC reading values correctly but what does it do when a value does NOT match one of the cases? For example if adc_res is 700? I think you should set b_level to 0 at the start of the routine. Not that THAT neccesarily is the problem but still....
    Also, I think you should "release" the CS pin as soon as you've done shifiting in the data.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks again !
    I have 100 nF capacitors near to power pins of PIC and MCP ... I use a Sony player for tests ; I don't have a serial display.
    As I said, my previous attempts (using PIC ADC) worked very fine in Proteus, worked very fine "on work table", but not so well on the car : sometimes the buttons wouldn't react properly (maybe because of automotive environment ?).
    I used LM2931-CZ5 for power supply, 100 nF ceramic capacitors, even a 100 uH coil before the voltage regulator. The part of code which reads the values of ADC is the same in this code...
    Aug 2011
    There isn't 16 bits of data to read, so the adc_RES parameter will have to be adjusted after you shift in the data.
    Even if you change it to not read 16-bits you should mask out the first few bits read since they are undefined.
    See section 6.1 in the MCP3201 datasheet.
    Bombay, India
    It is a long time since I used the MCP3201, so I am not current with the information. I will suggest the following change to be made
       if b_level=last_b_level then
            b_cnt=b_cnt+1
            pauseus 500
                if b_cnt > 10 then
                TRISc = %11111111
                gosub comenzi
              b_cnt = 0
    This change will ensure that only 10 stable level readings will be counted. Any fluctuation will be ignored.
    The ADC way for reading keys is not the ideal way.
    Jerson
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for suport !
    @Tumbleweed : I used code from this post : http://www.picbasic.co.uk/forum/show...207#post123207
    @Jerson : Tried already ...no improvement !
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_ON
    DEFINE OSC  4
    CMCON = 7
    ADCON0 = 0
    ADCON1 = 0
    ANSEL = 0
    VRCON = 0
    TRISA       = %00000100
    PORTA       = %00000000
    TRISC       = %11111111
    PORTC       = %00000000
    MI  VAR PORTA.1
    SCK VAR PORTA.2
    CSN VAR PORTA.0
    adc_RES  var Word
    last_b_level 	var byte
    b_level 	var byte
    b_cnt 		var byte
    b_act 		var byte
    CSN = 1
    TRISC = %11111111
    CSN = 0
    SHIFTIn MI, SCK, 4, [adc_RES\16]
    CSN  = 1
    if adc_RES < 2600 then
        IF adc_RES >  300 AND adc_RES < 320 THEN b_level=1
            IF adc_RES > 560 AND adc_RES < 590 THEN b_level=2
                IF adc_RES > 890 AND adc_RES < 910 THEN b_level=3
                    IF adc_RES > 1280 AND adc_RES < 1300 THEN b_level=4
                        IF adc_RES > 1790 AND adc_RES < 1820 THEN b_level=5
                            IF adc_RES > 2420 AND adc_RES < 2440 THEN b_level=6
            b_cnt=b_cnt+1
            pauseus 500
                if b_cnt > 10 then
                TRISc = %11111111
                gosub comenzi
    	    b_cnt= 0
        last_b_level=b_level
    serout2 porta.5, 84, [ dec adc_RES, " ", dec b_level, " ", dec b_cnt, 13]       ; to see ADC values
    pauseus 100
    comenzi:
    IF b_level=1 THEN gosub VoldN
    IF b_level=2 THEN gosub Volup
    IF b_level=3 THEN gosub Mute
    IF b_level=4 THEN gosub SeekUp
    IF b_level=5 THEN gosub SeekDn
    IF b_level=6 THEN gosub Source
    last_b_level=0
    b_cnt=0
    voldn:
    TRISC = %11111011
    TRISC = %11111111
    volup:
    TRISC = %11111101
    TRISC = %11111111
    seekup:
    TRISC = %11011111
    pause 250
    TRISC = %11111111
    seekdn:
    TRISC = %11111110
    pause 250
    TRISC = %11111111
    source:
    TRISC = %11110111
    pause 200
    TRISC = %11111111
    mute:
    TRISC = %11101111
    pause 200
    TRISC = %11111111
    Aug 2011
    You missed the following from that post...
    Sensor = (Sensor & $FFF) * 5000
    The AND with $FFF masks out the unused bits. The multiply by 5000 is to scale it to 5V, so you can skip that part.
    Look at the diagram in post #4 of that thread and you'll see that the first few bits of data are invalid. To be honest it looks to me like even that code from Darrel isn't quite right since it also shows getting a duplicate B1 bit into the LSB. I would think the result should be shifted right by 1 before doing the AND.
    I don't think your original problem with the pic ADC had anything to do with the internal adc being inaccurate so none of this may help much. You say it worked fine until you put it into the vehicle. That should be a clue.
    Dec 2008
    Ploiesti, ROMANIA
    Despite all the modification, the "adapter" still work foolish ... No change to the initial code.
    "You say it worked fine until you put it into the vehicle. That should be a clue. "
    I think so ! But I have not been able to identify and eliminate the cause so far.That's why I've been thinking about using this MCP ....
    Aug 2011
    Do the raw ADC readings out the serial port make sense? I'd concentrate on getting those right first.
    It would be a lot easier to use another pic with 3 extra I/O pins. Then your 6 push buttons would be reliable. But if you are minimalist and want a challenge go for it.
    Dec 2008
    Ploiesti, ROMANIA
    @tumbleweed : I don't understand what you mean ...
    @Mark's : It's impossible another approach ! The steering wheel commands don't allow ...
    Jan 2014
    Hello Fratello,
    Sounds like a hardware issue. I worked with LM2931 and i had some strange problems because I used a lower capacitance on output. Connect a 100uF (0,1uF is too low) near the stab pack on output line. "On work table" all are ok because may be you use a power supply who have a big capacitance. Also, when pic works with signals its necessary to decoupling with 10uF capacitance.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks ....but I have already FULL decoupling...Name:  decoupling.jpg
    Sep 2010
    Las Vegas, NV
    Just curious if the symptoms change when the RPM is varied?
    Dec 2008
    Ploiesti, ROMANIA
    Nope ! No change !
  1. Shiftin problem (16f877A with MCP3201)
    Last Post: - 17th November 2013, 04:10
  2. IF ....THEN.... problems
    By bursach in forum mel PIC BASIC Pro
    Last Post: - 24th February 2011, 20:42
  3. New and I'm having problems!
    By Roddy Wayne in forum mel PIC BASIC Pro
    Last Post: - 12th April 2009, 07:38
  4. IR problems
    By Snap in forum General
    Last Post: - 6th August 2007, 07:20
  5. A/D Problems!
    By scottl in forum General
    Last Post: - 20th May 2006, 16:49
