Circumference of circle to many decimal places
Results 1 to 11 of 11
    Aug 2003
    Default Circumference of circle to many decimal places
    Hi Guys,
    I was involved in a coding challenge to calculate 2 pi r,
    the circumference of a circle, given the radius as input, without any multiplication, division, or floats,
    so I pretended I was using an 8 bit pic It was done in C, but all variables were integers,
    so hopefully this BASIC is a good representation. (only the C was tested).
    Cheers
       var word input = 300 ‘ input radius
        var byte twopi[19] = { 0x00,0x00,0x00,0x06,0x02,0x08,0x03,0x01,0x08,0x05,0x03,0x00,0x07,0x01,0x07,0x09,0x05,0x09,0x00 }
        var byte otput[19] = { 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 }
        var word adcnt = 0 ‘ counter
        var byte dgcnt = 0 ‘ digit index
        var byte carry = 0 ‘ carry digit
        while (adcnt < input)  ‘ multiply through addition
            dgcnt = 17 : carry = 0
            while (dgcnt > 0) ‘ cycle the digits
            	otput[dgcnt] = otput[dgcnt] + twopi[dgcnt] + carry : carry = 0 ‘ add digit
              	if (otput[dgcnt] > 9)
     		otput[dgcnt] = otput[dgcnt] - 10 : carry = 1
     		endif ‘ carry digit
                dgcnt = dgcnt - 1
            wend ‘ dgcnt
            if (carry != 0)
    		otput[dgcnt] = otput[dgcnt] + 1
            adcnt = adcnt + 1
    	wend ‘ adcnt
        twopi[18] = 0 // terminate string
        // answer: 1884.9555921538758 is the string in the otput array
    Default Re: Circumference of circle to many decimal places
    Nice idea! Thanks for sharing it.
    How can you tell where the decimal dot would be?
    Aug 2003
    I think I made a mistake for BASIC. I don’t think you get to populate the first two arrays that way,
    but in some program they would be populated at run time with the input received, so I guess that’s ok.
    The addition is done the same way you were taught to do it on paper in primary school
    You could insert a decimal point with a value such as $2E in the input arrays somewhere, which would also require you keep them aligned.
    For the constant Pi2, it just goes between the first 6 and the 2. Then if the input had a decimal point, the array would have to be rotated so that
    for this example, the decimal point value is also at index 4 int he array. Ignore it in calculation, but remember it’s index to be passed through to the output.
    Still just as you were taught in school on paper. The decimal point is there on paper, but you do nothing with it other than also print it for the output.
    In any case of course, PBP doesn’t actually know the input or the output result as any variable of it’s own, but could still display it on a screen.
    The population is a C way and since you developed for C first it was expected I guess
    Aug 2005
    Michigan, USA
    Art, if it's not too much trouble, I would love to see what the C code looked like.
    Cheerful regards, Mike, K8LH
    OK
    Archimedes considered his greatest achievement working out the math to calculate the volume of a circle.
    Jun 2016
    A circle does't have volume! Very likely you meant Area.
    Alberto
    OK
    Sorry, you're right, I meant volume of a sphere.
    Aug 2003
    // input ASCII into input array
        // check ASCII numeric range (0x30-0x39 & 0x2E) here, and subtract 0x30 for all but 0x2E
        // rotate input array left until the decimal point is aligned with twopi array
        unsigned int input = 100; // 2:45am cheat
        unsigned char twopi[19] = { 0x00,0x00,0x00,0x06,0x02,0x08,0x03,0x01,0x08,0x05,0x03,0x00,0x07,0x01,0x07,0x09,0x05,0x09,0x00 };
        unsigned char otput[19] = { 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 };
        int adcnt = 0; // counter
        unsigned char dgcnt = 0; // digit index
        unsigned char carry = 0; // carry digit
        while (adcnt < input) { // multiply through addition
            dgcnt = 17; carry = 0;
            while (dgcnt > 0) { // cycle the digits
                otput[dgcnt] = otput[dgcnt] + twopi[dgcnt] + carry; carry = 0;// add digit
                if (otput[dgcnt] > 9) { otput[dgcnt] = otput[dgcnt] - 10; carry = 1; } // carry digit
                dgcnt--;
            } // dgcnt
            if (carry != 0) { otput[dgcnt] = otput[dgcnt] + 1; }
            adcnt++;
        } // adcnt
        twopi[18] = 0x00; // terminate string
        printf("%d%d%d%d.%d%d%d%d%d%d",otput[0],otput[1],otput[2],otput[3],otput[4],otput[5],otput[6],otput[7],otput[8],otput[9]);
    Aug 2003
    But in C, since you usually have math.h with floating point, you wouldn’t actually do that.
    This was part of a challenge with strict constraints.
    To do it in C, it’s:
    float circ;
    float radius;
    const float pi = 3.1415; // or however far you want to take it
    radius = 10.0
    circ = (2*pi)*radius;
    Aug 2011
    With a single precision float that's about as far as you can take it... 6-7 digits.
    You'll almost certainly never get the 17 digit answer.
  1. Want to display less decimal places on LCD from 16bit ADC
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2015, 22:14
  2. Replies: 2
    Last Post: - 8th April 2012, 15:11
  3. How long does this circle take?
    By IAmTheAnswer in forum mel PIC BASIC Pro
    Last Post: - 9th May 2010, 15:14
  4. Bcd-->Decimal please help
    By memo333 in forum mel PIC BASIC Pro
    Last Post: - 18th January 2006, 11:27
  5. Decimal value
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 7th April 2005, 16:39
