Trying to get LCD to work on 18f45k22 and portB and EasyPic V7 - no luck
Results 1 to 15 of 15
    Oct 2008
    Default Trying to get LCD to work on 18f45k22 and portB and EasyPic V7 - no luck
    I have tried everything I can think of to get this to work...anybody got any ideas what I am doing wrong or a missed setting?
    Thanks Don
    @ __CONFIG _CONFIG1H, _IESO_OFF_1H & _FCMEN_OFF_1H & _PRICLKEN_ON_1H & _PLLCFG_ON_1H & _FOSC_ECMPIO6_1H
    @ __CONFIG _CONFIG2L, _PWRTEN_OFF_2L & _BOREN_SBORDIS_2L & _BORV_190_2L
    @ __CONFIG _CONFIG2H, _WDTPS_32768_2H & _WDTEN_OFF_2H
    @ __CONFIG _CONFIG3H, _MCLRE_EXTMCLR_3H & _T3CMX_PORTB5_3H & _HFOFST_ON_3H & _CCP3MX_PORTB5_3H & _PBADEN_OFF_3H & _CCP2MX_PORTC1_3H
    @ __CONFIG _CONFIG4L, _DEBUG_OFF_4L & _XINST_OFF_4L & _LVP_OFF_4L & _STVREN_ON_4L
    @ __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    @ __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    @ __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
    @ __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    @ __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    @ __CONFIG _CONFIG7H, _EBTRB_OFF_7H
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    Define LCD_Bits 4
    DEFINE LCD_LINES 2
    Define LCD_Commandus 2000
    Define LCD_DATAUS 50
    ANSELB = %00000000
    TRISB = %00000000
    LCDOUT $FE,1,"Hello"
    Default Re: Trying to get LCD to work on 18f45k22 and portB and EasyPic V7 - no luck
    what sort of external clock are you using ?
    @ what freq ?
    you have no define OSC
    TRISB = %00000000 is unnecessary for lcd
    Oct 2008
    Hi Richard,
    I am using an 8mhz ext. crystal..
    Oct 2008
    Richard,
    This code is written in Mikro Basic I think and works...I was trying to convert it to PicBasic..
    Below it I have pasted the Config file that goes with it..
    ' * Project name:
    ' Lcd_Test (Demonstration of the LCD library routines)
    ' * Copyright:
    ' (c) Mikroelektronika, 2011.
    ' * Revision History:
    ' 20110929:
    ' - initial release (FJ);
    ' * Description:
    ' This code demonstrates how to use LCD 4-bit library. LCD is first
    ' initialized, then some text is written, then the text is moved.
    ' * Test configuration:
    ' MCU: PIC18F45K22
    ' http://ww1.microchip.com/downloads/e...Doc/41412D.pdf
    ' Dev.Board: EasyPIC7 - ac:LCD
    ' http://www.mikroe.com/easypic/
    ' Oscillator: HS-PLL 32.0000 MHz, 8.0000 MHz Crystal
    ' Ext. Modules: Character Lcd 2x16
    ' http://www.mikroe.com/store/components/various/
    ' SW: mikroBasic PRO for PIC
    ' http://www.mikroe.com/mikrobasic/pic/
    ' * NOTES:
    ' - Turn on Lcd backlight switch SW4.6. (board specific)
    program Lcd
    ' Lcd module connections
    dim LCD_RS as sbit at LATB4_bit
    LCD_EN as sbit at LATB5_bit
    LCD_D4 as sbit at LATB0_bit
    LCD_D5 as sbit at LATB1_bit
    LCD_D6 as sbit at LATB2_bit
    LCD_D7 as sbit at LATB3_bit
    dim LCD_RS_Direction as sbit at TRISB4_bit
    LCD_EN_Direction as sbit at TRISB5_bit
    LCD_D4_Direction as sbit at TRISB0_bit
    LCD_D5_Direction as sbit at TRISB1_bit
    LCD_D6_Direction as sbit at TRISB2_bit
    LCD_D7_Direction as sbit at TRISB3_bit
    ' End Lcd module connections
    dim txt1 as char[16]
    txt2 as char[9]
    txt3 as char[8]
    txt4 as char[7]
    i as byte ' Loop variable
    sub procedure Move_Delay() ' Function used for text moving
    Delay_ms(500) ' You can change the moving speed here
    end sub
    ANSELB = 0 ' Configure PORTB pins as digital
    txt1 = "mikroElektronika"
    txt2 = "EasyPIC7"
    txt3 = "Lcd4bit"
    txt4 = "example"
    Lcd_Init() ' Initialize Lcd
    Lcd_Cmd(_LCD_CLEAR) ' Clear display
    Lcd_Cmd(_LCD_CURSOR_OFF) ' Cursor off
    Lcd_Out(1,6,txt3) ' Write text in first row
    Lcd_Out(2,6,txt4) ' Write text in second row
    Delay_ms(2000)
    Lcd_Cmd(_LCD_CLEAR) ' Clear display4
    Lcd_Out(1,1,txt1) ' Write text in first row
    Lcd_Out(2,5,txt2) ' Write text in second row
    Delay_ms(500)
    ' Moving text
    for i=0 to 3 ' Move text to the right 4 times
    Lcd_Cmd(_LCD_SHIFT_RIGHT)
    Move_Delay()
    next i
    while TRUE ' Endless loop
    for i=0 to 7 ' Move text to the left 8 times
    Lcd_Cmd(_LCD_SHIFT_LEFT)
    Move_Delay()
    next i
    for i=0 to 7 ' Move text to the right 8 times
    Move_Delay()
    next i
    wend
    end.
    The config file...
    <?xml version="1.0"?>
    <MCU_DEVICE_FLAGS>
    <DEVICE>
    <DEVICE_NAME>P18F45K22</DEVICE_NAME>
    <VALUE>
    <COUNT>11</COUNT>
    <VALUE0>
    <VAL>$300001:$0033</VAL>
    </VALUE0>
    <VALUE1>
    <VAL>$300002:$001F</VAL>
    </VALUE1>
    <VALUE2>
    <VAL>$300003:$003C</VAL>
    </VALUE2>
    <VALUE3>
    <VAL>$300005:$00BD</VAL>
    </VALUE3>
    <VALUE4>
    <VAL>$300006:$0081</VAL>
    </VALUE4>
    <VALUE5>
    <VAL>$300008:$000F</VAL>
    </VALUE5>
    <VALUE6>
    <VAL>$300009:$00C0</VAL>
    </VALUE6>
    <VALUE7>
    <VAL>$30000A:$000F</VAL>
    </VALUE7>
    <VALUE8>
    <VAL>$30000B:$00E0</VAL>
    </VALUE8>
    <VALUE9>
    <VAL>$30000C:$000F</VAL>
    </VALUE9>
    <VALUE10>
    <VAL>$30000D:$0040</VAL>
    </VALUE10>
    </VALUE>
    </DEVICE>
    </MCU_DEVICE_FLAGS>
    your config is incorrect for those settings
      __config  _CONFIG1H, _FOSC_HSHP_1H & _PLLCFG_ON_1H & _PRICLKEN_OFF_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
      __config  _CONFIG2L, _PWRTEN_OFF_2L & _BOREN_SBORDIS_2L & _BORV_190_2L
      __config  _CONFIG2H, _WDTEN_ON_2H & _WDTPS_32768_2H
      __config  _CONFIG3H, _CCP2MX_PORTC1_3H & _PBADEN_OFF_3H & _CCP3MX_PORTB5_3H & _HFOFST_ON_3H & _T3CMX_PORTC0_3H & _P2BMX_PORTD2_3H & _MCLRE_EXTMCLR_3H
      __config  _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
      __config  _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
      __config  _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
      __config  _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
      __config  _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
      __config  _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
      __config  _CONFIG7H, _EBTRB_OFF_7H
    and you need a
    define OSC 32
    statement in your code
    why use a xtal ? why run at 8MHz ?
    when the chip has a int osc that can do 64mhz
    Oct 2008
    Well that worked fine.....
    Well the board has a crystal hook up but can be strapped in and out.
    I did try just the define osc 32 with my config and it also worked...
    as you probably surmised, I am pretty much a newbie..so why the ocs 32 define and say not 16 or 8?
    By the way thanks a bunch
    define OSC 32
    tells the compiler to perform all timing calculations for a clock speed of 32 MHz
    it defaults to 4 MHz if omitted , it should match the real clock speed used
    using 8 or 16 is simply wrong
    _PLLCFG_ON with a 8mhz xtal yields a 32 MHz clock
    no point guessing read the manual, read the data sheet
    Oct 2008
    Soif I was using an internal oscillator, I would define it in Config1h and further in OSCCON?
    yes
    not forgetting if and when the pll is engaged
    and setting define OSC appropriately
    there is a tool called meconfig , look it up and download a copy , it makes life easier.
    pity is that melabs don't update things much anymore so newer chips are missing , its still useful though
    Oct 2008
    Ok Richard Thank you but it looks like meconfig is not anywhere.. at least I couldn't find it to download..I will keep looking but ME labs has a posting that is discontinued and end of life....
    me either, thats a shame . i better not have another pc crash or that may be the end of it
    welcome to the Death Spiral of legacy software
    seems the spiral is tightening
    Oct 2008
    What is the chance you could email me a copy?
    ok , the install file is only 1900k bytes, but too big to post
    pm me your email and I can send it
    ps
    maybe one of the moderators could upload it to Darrel's central repository , its his work after all
    meConfig install that is
    Oct 2008
    I guess I don't know how to pm..lol
    Quote Originally Posted by dbachman View Post
    Like this Don
  1. Replies: 3
    Last Post: - 6th November 2011, 20:33
  2. Replies: 36
    Last Post: - 14th March 2011, 19:38
  3. Replies: 6
    Last Post: - 12th March 2011, 14:11
  4. LCD Data on portA and portB
    By EDWARD in forum mel PIC BASIC
    Last Post: - 22nd July 2005, 15:27
  5. Lcd On Porta And Portb
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 5th May 2005, 06:53
