ICD2 debugger/programmer with PBP possible?
+ Reply to Thread
Results 1 to 6 of 6
    Jan 2008
    Selm, Germany
    Question ICD2 debugger/programmer with PBP possible?
    Hy folks,
    i bought an ICD2 debugger some years ago and it has a cool textool socket programming adapter. I tried to figure out how to use it but it seems to me that its only useful when programming in C which I coulndīt. So is it easily possible to use it with PBP like a PICKIT programmer, maybe even as debugger or not. And: does it support 18F45K22 devices?
    regards
    Mugelpower
    Default Re: ICD2 debugger/programmer with PBP possible?
    me too , I offered it free to anyone in Australia . no takers not one
    your PICKIT2 will pgm 18F45K22 devices , all you need is to update the devicelist file [PK2DeviceFile.dat]
    henrik gave you the link
    I have a PICKIT3 I only use it if I have too the pk2 is a heaps better programmer
    Northeast
    I have both and usually use the ME Labs U2 Programmer. I use the PICKit3 for surface mount processors and haven't used the PICKit2 in several years. Not sure where I put it, actually. The U2 has a dip socket. Drop the PIC into the slot and hit Control P.
    Can't you take the ZIF socket add-on circuitboard from the U2 and just plug that into the PK2?
    (haven't looked at PK2 yet, but it's on my get-it-next list)
    Jan 2008
    Selm, Germany
    Since last friday iīm posessing the PICkit3 too, also the PICkit 2 and the ICD2 and a Velleman PicProg.
    Used the PICkit 2 but got programming problems . The ICD2 programming adapter has this stupid Western-socket.
    Will see if i can solder anything else to it that fits to the PICkit2 or 3 .
    You should be able to assemble a ribbon cable from the Pickit2
    to the U2 ZIF socket PCB
    Name:  U2 icsp.schematic.jpg
    That's what I did except in reverse; a ribbon cable from my U2 to prototype boards, bypassing the ZIF.
    Work's great!
  1. PBP + MPLAB + PICKit 3 Debugger / Programmer
    By HenrikOlsson in forum General
    Last Post: - 10th February 2011, 19:53
  2. Pbp + Mplab + Icd2
    By eduardojx in forum mel PIC BASIC Pro
    Last Post: - 17th July 2009, 03:54
  3. Unpacking a PICkit 2 Programmer/Debugger
    By duncan303 in forum General
    Last Post: - 14th May 2009, 21:24
  4. ICD2 with PBP
    By Worayoot in forum General
    Last Post: - 5th January 2005, 19:36
  5. How do I put a NOP at location 0 for the ICD2 by use PBP?
    By Worayoot in forum mel PIC BASIC Pro
    Last Post: - 7th April 2004, 05:04
