16LF628 Problem
Results 1 to 3 of 3
Thread: 16LF628 Problem
    Sep 2003
    Vermont
    Default 16LF628 Problem
    I am running a 16LF628 on 3 volts @ 8 MHz with a resonator. The chip runs fine, but when I take pin RA1 high, the oscillator stops!?! My first impulse was to pull the chip, but I want to know why it is doing it? I remembered CMCON = 7, and this circuit has worked on 4 exact same boards, with the same code. The current draw is minimal, and I even removed the load, but it still does it. The really wierd part, is that after a random length of time, it starts up where it stopped! Any ideas? Poltergeist?
    Ron
    Look at the voltage-frequency chart in the data sheet. You're limited to a MAX frequency at lower operating voltages, and it's affected big time by ambient temperature.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2003
    Vermont
    Thanks Bruce. I replaced the resonator with a 4 MHz part and it ran fine. It was just the erratic behavior with port A that fascinated me.
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. Problem to compile my program
    By wagner in forum Off Topic
    Last Post: - 7th July 2008, 20:17
  3. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  4. PicBasic Pro Math Problem??
    By Glen65 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 04:36
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 22:59
