Remove Text Formatting
Loading...
+ Reply to Thread
Results 1 to 20 of 20
    Sep 2016
    Default how to use HX711 Load Cell Module
    I want to use HX711 to my Weighing Scale.Iam new to External ADC.
    I Have Read Data sheet but Not able to write program.
    Pls help.
    Oct 2009
    Default Re: how to use HX711 Load Cell Module
    May not help directly, but there are plenty of arduino projects that you might be able to reverse engineer to work in PBP https://github.com/sparkfun/HX711-Lo...ier/tree/V_1.1
    You didn't say anything about what you're trying to do, nor which MCU you want to use. For starters, readings will be 3 bytes long, so using a PIC18FXX series processor will allow you to store ADC values as LONGs. Furthermore, the ADC value will be signed ($800000 - $FFFFFF). LONGs work out very well for that.
    It looks like the software portion of operating this HX711 is fairly simple. I'll skip the SFRs etc and just get to the function part of code:
    Weight VAR LONG
    b0 VAR BYTE
    DOUT VAR PORTA.0
    PD_SCK VAR PORTA.1
    Mainloop:
    LOW PD_SCK
    IF DOUT = 0 THEN
     FOR b0 = 25 TO 1 STEP -1 ;This would be for 128X Gain, use 26 for 64X or 1 TO 27 for 32X
      HIGH PD_SCK
      PAUSE 100
      Weight.b0 = DOUT
     NEXT b0
    ;More code
    This will allow retrieval of the individual bits at a 10 Hz rate as specified in the HX711 Data Sheet. It is capable of an 80 Hz rate. This would require a PAUSEUS 12500 (12.5 ms). Bits are shifted out MSB First, so the first bit will be Weight.23, then Weight.22 right on down to Weight.0 (where the number after the variable is for the individual bit within the LONG variable).
    There are hardware options listed in the Data Sheet as well. I only wanted to help you with the basic code for retrieving the data.
    Sep 2009
    Where in loop you set clock to 0?
    Oops, good eye.
    For bo...
    HIGH PD_SCK
    PAUSE 100
    Weight.b0 = DOUT
    LOW PD_SCK
    PAUSE 100
    NEXT b0
    According to the Data Sheet, you can reduce PAUSE times until communication gets fuzzy, then back off a couple ms.
    Sep 2016
    TRIED YOUR CODE WITH MY CODE.
    PROBLEM IS THAT IT ONLY SHOW 000001 (BLINK FREQUENTLY)
    '* Name : UNTITLED.BAS *
    '* Notice : Copyright (c) 2017 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 3/1/2017 *
    '* Version : 1.0 *
    '* Notes : *
    'LOAD INDICATOR 16F877A'
    b0 VAR BYTE
    DOUT VAR PORTC.4
    PD_SCK VAR PORTC.3
    DG1 VAR WORD
    DG2 VAR WORD
    DG3 VAR WORD
    DG4 VAR WORD
    DG5 VAR WORD
    DG6 VAR WORD
    I VAR BYTE
    DIGIT VAR byte
    DG VAR byte
    COUNTT VAR BYTE
    N VAR word
    TRISA=0
    TRISB=0
    TRISC=%00010000
    TRISD=1
    TRISE=0
    ADCON0=7
    CMCON=7
    ADCON1=7
    GOSUB DISPLAY
    MAIN:
    LOW PD_SCK
    IF DOUT = 0 THEN MAIN
    FOR b0 = 0 TO 23
    HIGH PD_SCK
    N= DOUT
    LOW PD_SCK
    NEXT b0
    GOSUB DISPLAY
    GOSUB DIGITCALC
    GOTO MAIN
    __________________________________________________ _
    DISPLAY: ' 'DATA FOR DG1,DG2,DG3,DG4,DG5,DG6 IS PUT ON PORTC AND THE CORRESPONDING
    'PINS ON PORTB TOGGLED
    'THIS IS DONE 100 TIMES
    FOR COUNTT=0 TO 99
    PORTB=DG1
    PORTA.5=0
    PAUSEUS 100
    PORTA.5=1
    PORTB=DG2
    PORTA.4=0
    PAUSEUS 100
    PORTA.4=1
    PORTB=DG3
    PORTA.3=0
    PAUSEUS 100
    PORTA.3=1
    PORTB=DG4
    PORTA.2=0
    PAUSEUS 100
    PORTA.2=1
    PORTB=DG5
    PORTA.1=0
    PAUSEUS 100
    PORTA.1=1
    PORTB=DG6
    PORTE.0=0
    PAUSEUS 100
    PORTE.0=1
    NEXT COUNTT
    DIGITCALC: ''THIS ROUTINE BREAKS UP THE NUMBER INTO 3 DISTINCT PARTS - DG1,DG2,DG3,DG4,DG5,DG6
    'NOTICE THAT ANOTHER SUBROUTINE IS CALLED EACH TIME
    DIGIT=0
    LP1:
    IF N<10000 THEN DS1
    N=N-10000
    DIGIT=DIGIT+1
    GOTO LP1
    DS1:
    GOSUB FND
    DG1=DG
    DIGIT=0
    LP2:
    IF N<1000 THEN DS2
    N=N-1000
    DIGIT=DIGIT+1
    GOTO LP2
    DS2:
    GOSUB FND
    DG2=DG
    DIGIT=0
    LP3:
    IF N<100 THEN DS3
    N=N-100
    DIGIT=DIGIT+1
    GOTO LP3
    DS3:
    GOSUB FND
    DG3=DG
    DIGIT=0
    LP4:
    IF N<10 THEN DS4
    N=N-10
    DIGIT=DIGIT+1
    GOTO LP4
    DS4:
    GOSUB FND
    DG4=DG
    DIGIT=N
    GOSUB FND
    DG5=DG
    '_________________________________________________ _________________________
    FND: ''THIS ROUTINE IDENTIFIES THE SEGMENTS TO LIGHT UP
    '7 SEGMENTS WIRED UP AS FOLLOWS
    'A -PORTB.7
    'B -PORTB.6
    'C -PORTB.5
    'D -PORTB.4
    'E -PORTB.3
    'F -PORTB.1
    'G -PORTB.2
    'DECMAL=PORTB.0
    FND0:
    IF DIGIT>0 THEN FND1
    DG=%00000101
    GOTO FNDEND
    FND1:
    IF DIGIT>1 THEN FND2
    DG=%10011111
    GOTO FNDEND
    FND2:
    IF DIGIT>2 THEN FND3
    DG=%00100011
    GOTO FNDEND
    FND3:
    IF DIGIT>3 THEN FND4
    DG=%00001011
    GOTO FNDEND
    FND4:
    IF DIGIT>4 THEN FND5
    DG=%10011001
    GOTO FNDEND
    FND5:
    IF DIGIT>5 THEN FND6
    DG=%01001001
    GOTO FNDEND
    FND6:
    IF DIGIT>6 THEN FND7
    DG=%01000001
    GOTO FNDEND
    FND7:
    IF DIGIT>7 THEN FND8
    DG=%00011111
    GOTO FNDEND
    FND8:
    IF DIGIT>8 THEN FND9
    DG=%00000001
    GOTO FNDEND
    FND9:
    DG=%00011001
    FNDEND:
    Sep 2009
    First N VAR LONG 'You have 23bits, so you need place to store them.
    Second in FOR loop you assign always same bit in N. N=DOUT should be N.0[bo]=DOUT
    Sep 2016
    IAM USING 16F877A
    THIS CODE DISPLAYS 65535 .
    MAIN:
    DOUT=1
    LOW PD_SCK
    FOR b0 = 0 TO 23 ;This would be for 128X Gain, use 26 for 64X or 1 TO 27 for 32X
    HIGH PD_SCK
    N.0[b0] = DOUT
    LOW PD_SCK
    NEXT b0
    Sep 2009
    You can't store 23bit to single word.
    Sep 2016
    if i want to use only 16 bits
    Sep 2016
    iam using picbasic pro 2.60
    Sep 2009
    Just reject lower 16bits.
    Try something like this
    IF b0>7 then N.0[b0-8]=...
    Did you set pin to input?
    And if so, why you try to set it to 1?
    Quote Originally Posted by Kritika View Post
    IAM USING 16F877A
    MAIN:
    DOUT=1
    LOW PD_SCK
    HIGH PD_SCK
    N.0[b0] = DOUT
    LOW PD_SCK
    NEXT b0
    It looks like you gave it the answer before you asked the question. DOUT should be set as an input (TRIS pin = 1) in which case "DOUT = 1" in an inappropriate statement.
    You might want to look at the possibility of using a PIC18F processor for this project so you are able to use LONG variables.
    Sep 2016
    GOT INSANE, TILL NOW NO SUCESS
    CHANGED MY CODE TO
    MAIN:
    ADDO=1
    ADSK=0
    COUNTY=0
    IF ADDO=0 THEN MAIN
    FOR b0 = 1 to 24
    ADSK=1
    COUNTY=COUNTY*10
    ADSK=0
    IF ADDO=1 THEN COUNTY=COUNTY+1
    ADSK=1
    county = county xor 65535
    n.0[b0]=county
    ADSK=0
    NEXT b0
    If I want to play with USB, I buy a couple PIC18F25K50's. If I want to build an ignition timing controller, I buy a couple PIC16F1619's. You seemed determined to stick with the PIC16F877A. Would you be willing to spend the minimal amount of money for even a PIC18F45K22 (40 pins with same power supply pins as your PIC16F877A) if that means you get your project launched? I doubt the Great Pyramid on the Giza Plateau was built with bronze chisels (if you get my drift).
    HX711_reading =$AABBCC and would be stored little-endian. I.E. if the address
    of HX711_reading starts at 30h, then $CC will be stored at 30h followed by $BB at 31h followed by $AA at 32h
    HX711_reading VAR BYTE[3]
    HX711_upper var word
    Then read your 24 bits into the array in little-endian style from the HX711
    then the upper 16 bits can be used
    HX711_upper = HX711_reading[1]+HX711_reading[2]*256
    no need for long , simple
    if you use an word EXT reference to the array address +1 the above calc can be avoided entirely
    eg
    @ HX711_upper = HX711_reading+1
    HX711_upper var word EXT
    This is more entertaining than Free to Air TV
    one more thing if you spend a few minutes searching the forum you will find
    PutMulResult?D macro
    and
    GetMulResult?D macro
    which enable you to do 32 bit divides with pic16's and 12's with div32
    there are examples using 32 bit constants as well as arrays
    even getting and using the remainder too
    Sep 2016
    I GOT Fluctuating VALUES BY THIS CODE
    MAIN:
    DOUT=1
    LOW PD_SCK
    FOR b0 = 1 TO 16 ;This would be for 128X Gain, use 26 for 64X or 1 TO 27 for 32X
    HIGH PD_SCK
    N.0[B0]=DOUT
    LOW PD_SCK
    NEXT b0.
    HOW CAN I MAKE THESE VALUES STABLE
    65535.........12584......
    by interpreting the data correctly
    1, the HX711 clocks out the data MSB first , you are storing it as if LSB is first
    2, @128 gain the NX711 yields 25 bits of data , if you only read 16 of them you may need to reset the NX711 after read
    3, the dout data is ready to read immediately after the clk pulse not during
    4, the HX711 signals data ready by setting dout low
    Get rid of "DOUT = 1"
  1. Load needed for circuit to work ?
    Last Post: - 6th May 2012, 09:48
  2. Patch 2.60a refuses to load
    By BrianT in forum mel PIC BASIC Pro
    Last Post: - 27th July 2010, 12:33
  3. Load caps
    By grounded in forum Off Topic
    Last Post: - 30th November 2009, 15:43
  4. Measuring mains load
    By Freman in forum General
    Last Post: - 13th June 2008, 00:33
  5. ADC Load
    By CocaColaKid in forum General
    Last Post: - 19th November 2004, 12:43
Members who have read this thread : 19
