Help with PORTB Interrupt On Change Please
Results 1 to 3 of 3
    Jan 2011
    Sydney, Australia
    Default Help with PORTB Interrupt On Change Please
    Hi All,
    I am looking to use PORTB Interrupt On Change on a PIC18F26J50 but can't get my head around how to determine which pin (PORTB.4 - 7) caused the interrupt.
    I would like to set up four momentary action switches to each of the four PORTB IOC pins (with associated pull up resistors) and then action different sections of code depending on which switch was activated.
    I have searched the FORUM looking for examples but haven't found anything which answers my questions.
    Any assistance and/or guidance would be greatly appreciated.
    Cheers
    Barry
    VK2XBP
    Default Re: Help with PORTB Interrupt On Change Please
    one way
    oldportb var byte
    pbchange var byte
    in main before isr enabled
    oldportb=portb
    in isr {portb must have changed to get here}
    pbchange = portb ^ oldportb ; xor portb with last known state and set bits that changed
    oldportb=portb ;update state
    pbchange=pbchange>>4 ; shift result to low byte
    int returm
    Jan 2011
    Sydney, Australia
    Thanks Richard.
    It was the xor process that I was missing.
    Cheers
    Barry
    VK2XBP
  1. PORTB + PORTC Interrupt-On-Change
    By Aussie Barry in forum mel PIC BASIC Pro
    Last Post: - 26th March 2014, 13:02
  2. PortB Change Interrupts
    By backstabber in forum mel PIC BASIC Pro
    Last Post: - 8th October 2011, 03:52
  3. Replies: 6
    Last Post: - 12th March 2011, 13:11
  4. Returning from Int on PortB change
    By sheryl in forum mel PIC BASIC Pro
    Last Post: - 11th December 2008, 18:09
  5. Interrupt portb
    By tazntex in forum mel PIC BASIC Pro
    Last Post: - 18th August 2008, 21:05
