Real time clock + external interrupt in one PIC possible?
Results 1 to 2 of 2
    Jan 2008
    Selm, Germany
    Default Real time clock + external interrupt in one PIC possible?
    Hello you all!
    its several years since I postet something here.
    My current problem:
    I need to measure the average speed of a car. I got an input signal from the driveshaft (one per revolution) wich I use for a distance couter with a 16F88 . The program uses "on interrupt" Now I need to divide the distance by real time after pushing a button. I got two favorite PICs because I´m an total inept programmer : 16F88 and 18F1320. Wrote my last program some years ago.
    The clock and the incomming driveshaft pulses both use interrupts and I think thats too much for one of these PICs. No I´m not migrating to DSPic or 24F.
    Any suggestions out there?
    OK
    Default Re: Real time clock + external interrupt in one PIC possible?
    The PIC18F1320 would be my choice only given the 2 you offered. It easily can handle 2 Interrupts, and offers an internal Oscillator.
    - I would run the OSC at 4 MHz.
    - I would use INT0 (RB0) for the driveshaft trigger input. The Interrupt Handler should increment your counter variable every time the driveshaft makes another pass.
    - I would use TMR1 to create the 1 second timer (actually 1/2 second timer).
    > T1CON = %0011000X; .7 = TMR1H & TMR1L written to independently, <5-4> = 1:8 Prescale, .1 = Clock source is Fosc/4, .0 = On/Off
    > Preload TMR1 = 3035 (T1 will tick at 0.000008 seconds, times 62500 (65535 - 3035) = 0.5 seconds); TMR1H = $0B, TMR1L = $DB
    Since your TMR1_INT will occur every half second, it would probably be easiest to calculate your vehicle's speed by running the math around that. Say for instance your counter variable = 35 when your TMR1_INT overflows. You double it and get 70 driveshaft pulses per second. If you need better resolution, you could create a variable that will count 1/2 second TMR1 Interrupts and calculate vehicle speed only after 10 have occurred; which is 5 seconds. Be sure to clear your counter variable after using it in your calculation.
    There is some detail here, and some things left ambiguous. Hopefully this guides you to a working piece.
  1. real time clock
    By maria in forum Code Examples
    Last Post: - 1st March 2022, 12:13
  2. Real Time Clock
    By in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2012, 04:52
  3. Real time clock
    By PlantBob in forum mel PIC BASIC Pro
    Last Post: - 10th February 2011, 13:01
  4. Real Time Clock
    Last Post: - 8th December 2006, 02:02
  5. ds1307 real-time clock
    By mle in forum mel PIC BASIC Pro
    Last Post: - 16th August 2004, 16:22
