I have had some issues with the different versions of PBP so I upgraded to Vs PBPX 3.1.0.4
This program compiles just fine but it does not enter the interrupt on RX
INCLUDE "modedefs.bas"
include "ALLDIGITAL.pbp"
INCLUDE "C:\PBP\DT_INTS-18.bas" ; Base Interrupt System
INCLUDE "C:\PBP\ReEnterPBP-18.bas" ; Include if using PBP interrupts
Define PULSIN_MAX 1000
DEFINE HSER_RCSTA 90h 'Hser receive status init
DEFINE HSER_TXSTA 24h 'Hser transmit status init
DEFINE HSER_BAUD 9600 'Hser baud rate
DEFINE HSER_SPBRG 25
DEFINE HSER_CLROERR 1
OSCCON =$D2 'clock speed
mem1 var byte
INT_Handler RX1_INT, _read_serial, PBP, yes
@ INT_ENABLE RX1_INT ; enable external (RX) interrupts
MAIN:
SEROUT2 PORTB.0 ,16468,["here",cr,cr]
GOTO MAIN
read_serial:
hserin 250 , NoRS232,[mem1,mem1]
serout2 PORTB.0,16468,["got it",cr]
Pause 1000
@ INT_RETURN
NoRS232:
serout2 PORTB.0,16468,["No rs232",cr]
@ INT_RETURN
The exact same code runs in the 18F1320 except the OSCCON is $60 for the 18F1320 and $D2 for the 18F26K22.
Does anyone know where I might be needing to look?
Mike
