Hello, welcome to our forum.
It looks like you have registered but you have not yet posted and messages. Our requirements are that you must post at least two messages, to allow the moderators to review your registration, before you will be allowed access to the full range of forum areas.
Please make a couple of posts, until then you may see a notice that says you are banned from certain forum areas.
Thank you.
Remove Text Formatting
Loading...
+ Reply to Thread
Results 1 to 5 of 5
Thread: Code for SHT21
    Jul 2009
    Ohio, USA
    Default Code for SHT21
    Hello all,
    I have been using SHT11 and Tracy Allen's code for some time. I recently got a SHT21 and found the conversion does not work.
    I found this on the Basic Stamp Forum:
    Just to compare in red and blue, the formulae for the SHT2x:
    C = -46.85 + 175.72 * rawT / (2^resT) resT is 14 bits default
    %RH = -6 + 125 * rawH / (2^resH) resH is 12 bits default
    res = resolution, tradeoff with speed, set in the user register.
    with formulae for SHT1x:
    C = -40.1 + 0.01 * rawT on 14 bit setting and 5V supply
    %RH1 = -2.0468 + 0.0367 * rawH - 1.5955E-6 * rawH^2 on 12 bit setting
    then temperature compensation
    %RH = (C - 25) * (.01 + 0.00008 * rawH) + RH1
    The SHT1x too has both high and low resolution modes.
    Does anyone else use a SHT21 and what does the code actually look like?
    Thanks in advance
    Mike2545
    Default Re: Code for SHT21
    Not familiar with the SHT11, but at a glance I can say the PIC will not work with decimals or negatives. However. if you wanted to add -46.85 + 175.72 it could be structured
    (17572 - 4685) / 100
    Multiplication works similarly; Var * 1.75 becomes (Var * 175) / 100.
    Something tells me I'm not even getting close to the jist of your question. If you can elaborate some, I'll see if I can help.
    Jul 2009
    Ohio, USA
    mpgmike,
    Thanks for the response. I'll link the code for the sht11 on the parallax site and the data sheet for the sht21.
    https://www.parallax.com/sites/defau...ample-Code.zip
    http://www.mouser.com/ds/2/682/Sensi..._V4-469715.pdf
    If you don't have the BS2 editor here is the code:
    '   File...... SHT11.BS2
    '   Purpose... Interface to Sensirion SHT11 temperature/humidity sensor
    '   E-mail.... stamptech@parallaxinc.com
    '   Date...... 12/30/02
    '   {$STAMP BS2}
    ' Program Description
    ' This program demonstrates the interface and conversion of SHT11 data to
    ' usable program values.
    ' For detailed information on the use and application of the ** operator,
    ' see Tracy Allen's web page at this link:
    ' -- http://www.emesystems.com/BS2math1.htm
    ' For Tracy's SHT1x code [very advanced]:
    ' -- http://www.emesystems.com/OL2sht1x.htm
    ' For SHT11/15 documentation and app notes, visit:
    ' -- http://www.sensirion.com
    ' I/O Definitions
    ShtData         CON     1                       ' bi-directional data
    Clock           CON     0
    ' Constants
    ShtTemp         CON     %00011                  ' read temperature
    ShtHumi         CON     %00101                  ' read humidity
    ShtStatW        CON     %00110                  ' status register write
    ShtStatR        CON     %00111                  ' status register read
    ShtReset        CON     %11110                  ' soft reset (wait 11 ms after)
    Ack             CON     0
    NoAck           CON     1
    No              CON     0
    Yes             CON     1
    MoveTo          CON     2                       ' for DEBUG control
    ClrRt           CON     11                      ' clear DEBUG line to right
    DegSym          CON     186                     ' degrees symbol for DEBUG
    ' Variables
    ioByte          VAR     Byte                    ' data from/to SHT1x
    ackBit          VAR     Bit                     ' ack/nak from/to SHT1x
    toDelay         VAR     Byte                    ' timeout delay timer
    timeOut         VAR     Bit                     ' timeout status
    soT             VAR     Word                    ' temp counts from SHT1x
    tC              VAR     Word                    ' temp - celcius
    tF              VAR     Word                    ' temp - fahrenheit
    soRH            VAR     Word                    ' humidity counts from SHT1x
    rhLin           VAR     Word                    ' humidity; linearized
    rhTrue          VAR     Word                    ' humidity; temp compensated
    status          VAR     Byte                    ' SHT1x status byte
    ' EEPROM Data
    ' Initialization
    Initialize:
      GOSUB SHT_Connection_Reset                    ' reset device connection
      PAUSE 250                                     ' let DEBUG window open
      DEBUG CLS
      DEBUG "SHT1x Demo", CR
      DEBUG "----------", CR
      ' GOTO Main                                   ' skip heater demo
    ' Program Code
    Sensor_Demo:
      GOSUB SHT_Measure_Temp
      DEBUG MoveTo, 0, 3
      DEBUG "tF...... "
      DEBUG DEC (tF / 10), ".", DEC1 tF, DegSym, ClrRt, CR
      GOSUB SHT_Measure_Humidity
      DEBUG "rhLin... "
      DEBUG DEC (rhLin / 10), ".", DEC1 rhLin, "%", ClrRt, CR, CR
    Heater_On:
      DEBUG "SHT1x heater on", CR
      status = %00000100                            ' heater bit = On
      GOSUB SHT_Write_Status
      DEBUG "Waiting 2 seconds", CR
      PAUSE 2000
    Heater_Off:
      DEBUG "SHT1x heater off", CR, CR
      status = %00000000                            ' heater bit = Off
      DEBUG "tF...... "
      DEBUG "rhLin... "
      PAUSE 5000
      DEBUG CLS
    Main2:
      DEBUG MoveTo, 0, 3
      DEBUG "soT...... "
      DEBUG DEC soT, ClrRt, CR
      DEBUG "tC....... "
      DEBUG DEC (tC / 10), ".", DEC1 tC, DegSym, ClrRt, CR
      DEBUG "tF....... "
      DEBUG MoveTo, 0, 7
      DEBUG "soRH..... "
      DEBUG DEC soRH, ClrRt, CR
      DEBUG "rhLin.... "
      DEBUG "rhTrue... "
      DEBUG DEC (rhTrue / 10), ".", DEC1 rhTrue, "%", ClrRt
      PAUSE 1000                                    ' minimum delay between readings
      GOTO Main2
    ' Subroutines
    ' connection reset: 9 clock cyles with ShtData high, then start sequence
    SHT_Connection_Reset:
      SHIFTOUT ShtData, Clock, LSBFIRST, [$FFF\9]
    ' generates SHT1x "start" sequence
    '          _____         _____
    ' ShtData       |_______|
    '              ___     ___
    ' Clock    ___|   |___|   |___
    SHT_Start:
      INPUT ShtData                                 ' let pull-up take line high
      LOW Clock
      HIGH Clock
      LOW ShtData
      LOW Clock
      HIGH Clock
      INPUT ShtData
      LOW Clock
    ' measure temperature
    ' -- celcius = soT * 0.01 - 40
    ' -- fahrenheit = soT * 0.018 - 40
    SHT_Measure_Temp:
      GOSUB SHT_Start                               ' alert device
      ioByte = ShtTemp                              ' temperature command
      GOSUB SHT_Write_Byte                          ' send command
      GOSUB SHT_Wait                                ' wait until measurement done
      ackBit = Ack                                  ' another read follows
      GOSUB SHT_Read_Byte                           ' get MSB
      soT.HIGHBYTE = ioByte
      ackBit = NoAck                                ' last read
      GOSUB SHT_Read_Byte                           ' get LSB
      soT.LOWBYTE = ioByte
      ' Note: Conversion factors are multiplied by 10 to return the
      '       temperature values in tenths of degrees
      tC = soT / 10 - 400                           ' convert to tenths C
      tF = soT ** 11796 - 400                       ' convert to tenths F
    ' measure humidity
    SHT_Measure_Humidity:
      ioByte = ShtHumi                              ' humidity command
      soRH.HIGHBYTE = ioByte
      soRH.LOWBYTE = ioByte
      ' linearize humidity
      '   rhLin = (soRH * 0.0405) - (soRH^2 * 0.0000028) - 4
      ' for the BASIC Stamp:
      '   rhLin = (soRH * 0.0405) - (soRH * 0.004 * soRH * 0.0007) - 4
      ' Conversion factors are multiplied by 10 and then rounded to
      ' return tenths
      rhLin = (soRH ** 26542)
      rhLin = rhLin - ((soRH ** 3468) * (soRH ** 3468) + 50 / 100)
      rhLin = rhLin - 40
      ' temperature compensated humidity
      '   rhTrue = (tC - 25) * (soRH * 0.00008 + 0.01) + rhLin
      ' Conversion factors are multiplied by 100 to improve accuracy and then
      ' rounded off.
      rhTrue = ((tC / 10 - 25) * (soRH ** 524 + 1) + (rhLin * 10)) + 5 / 10
    ' sends "status"
    SHT_Write_Status:
      ioByte = ShtStatW                             ' write to status reg command
      ioByte = status
    ' returns "status"
    SHT_Read_Status:
      GOSUB SHT_Read_Byte                           ' send command
      ackBit = NoAck                                ' only one byte to read
      GOSUB SHT_Read_Byte
    ' sends "ioByte"
    ' returns "ackBit"
    SHT_Write_Byte:
      SHIFTOUT ShtData, Clock, MSBFIRST, [ioByte]   ' send byte
      SHIFTIN  ShtData, Clock, LSBPRE, [ackBit\1]   ' get ack bit
    ' returns "ioByte"
    ' sends "ackBit"
    SHT_Read_Byte:
      SHIFTIN  ShtData, Clock, MSBPRE, [ioByte]     ' get byte
      SHIFTOUT ShtData, Clock, LSBFIRST, [ackBit\1] ' send ack bit
      INPUT ShtData                                 ' release data line
    ' wait for device to finish measurement (pulls data line low)
    ' -- timeout after ~1/4 second
    SHT_Wait:
      INPUT ShtData                                 ' data line is input
      FOR toDelay = 1 TO 250                        ' give ~1/4 second to finish
        timeOut = INS.LOWBIT(ShtData)               ' scan data line
        IF (timeOut = No) THEN SHT_Wait_Done        ' if low, we're done
        PAUSE 1
      NEXT
    SHT_Wait_Done:
    ' reset SHT1x with soft reset
    SHT_Soft_Reset:
      GOSUB SHT_Connection_Reset                    ' reset the connection
      ioByte = ShtReset                             ' reset command
      ackBit = NoAck                                ' only one byte to send
      GOSUB SHT_Write_Byte                          ' send it
      PAUSE 11                                      ' wait at least 11 ms
    What I am trying to do is, write code to read the SHT21 temperature and humidity.
    Jul 2009
    Ohio, USA
    mpgmike, I got the sensor to respond to my finger temp difference. Here is the code so far:
    Yes, yes, I am prototyping on a Stamp :/
    ' {$STAMP BS2p}
    ' {$PBASIC 2.0}
      tf    VAR Byte
      tc    VAR Byte
      rawT  VAR Word
      rawRH VAR Byte
      DEBUG CLS
      DEBUG "SHT21 Demo", CR
    I2COUT 0 ,%10000000, [%11100011]
      PAUSE 50
    I2CIN  1 , %10000001, [rawT]
      DEBUG 2, 0, 3
      DEBUG "rawT...... "
      DEBUG  DEC rawT, 11, CR
      rawT= rawT <<2
      tC = (rawT & $fffc) ** 17572 - 4685
      DEBUG "Deg C......", DEC tC
      PAUSE 500
      GOTO main
    Getting elevated readings on the SHT21
    The SHT21 temp says my room is 42C (107.6F) Actual temperature is ~ 23.8C (75F)
    rawT @ 42C = 111
    don't know much about stamp code but here goes
    from the sensiron web example
    float SHT2x_CalcTemperatureC(u16t u16sT)
    ft temperatureC; // variable for result
    u16sT &= ~0x0003; // clear bits [1..0] (status bits)
    //-- calculate temperature [C] --
    temperatureC= -46.85 + 175.72/65536 *(ft)u16sT; //T= -46.85 + 175.72 * ST/2^16
    return temperatureC;
    the reading is not shifted <<2 places the two lsb are just masked off
    so
    rawT= rawT <<2
    becomes
    rawT= rawT & ~3 ;ie %1111111111111100
    is hold master mode is that what you need ?
    try
    I2COUT 0 ,%10000000, [%11110011]
    might be better
    PAUSE 50 is this long enough at max resoloution ?
    rawT @ 42C = 111
    by my calcs rawT should be 33132 @ 42C
    what rawT do you actually get ?
  1. 16F877A and Sensirion SHT21
    By ctravel in forum mel PIC BASIC Pro
    Last Post: - 25th June 2016, 08:15
  2. avr code to code for PIC
    By JasonMcG in forum General
    Last Post: - 11th September 2014, 00:57
  3. Serial problem between BasicStamp code and PBP code
    By AllanZilkowsky in forum mel PIC BASIC Pro
    Last Post: - 6th April 2014, 02:15
  4. Working code but my layman approach uses too much code space
    Last Post: - 14th December 2012, 20:44
  5. Code: Why is this code greater than 2000 words?
    By DrDreas in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 19:51
Members who have read this thread : 18
