Code for SHT21
Results 1 to 5 of 5
Thread: Code for SHT21
    Jul 2009
    Ohio, USA
    Default Code for SHT21
    Hello all,
    I have been using SHT11 and Tracy Allen's code for some time. I recently got a SHT21 and found the conversion does not work.
    I found this on the Basic Stamp Forum:
    Just to compare in red and blue, the formulae for the SHT2x:
    °C = -46.85 + 175.72 * rawT / (2^resT) resT is 14 bits default
    %RH = -6 + 125 * rawH / (2^resH) resH is 12 bits default
    res = resolution, tradeoff with speed, set in the user register.
    with formulae for SHT1x:
    °C = -40.1 + 0.01 * rawT on 14 bit setting and 5V supply
    %RH1 = -2.0468 + 0.0367 * rawH - 1.5955E-6 * rawH^2 on 12 bit setting
    then temperature compensation
    %RH = (°C - 25) * (.01 + 0.00008 * rawH) + RH1
    The SHT1x too has both high and low resolution modes.
    Does anyone else use a SHT21 and what does the code actually look like?
    Thanks in advance
    Mike2545
    OK
    Default Re: Code for SHT21
    Not familiar with the SHT11, but at a glance I can say the PIC will not work with decimals or negatives. However. if you wanted to add -46.85 + 175.72 it could be structured
    (17572 - 4685) / 100
    Multiplication works similarly; Var * 1.75 becomes (Var * 175) / 100.
    Something tells me I'm not even getting close to the jist of your question. If you can elaborate some, I'll see if I can help.
    Jul 2009
    Ohio, USA
    mpgmike,
    Thanks for the response. I'll link the code for the sht11 on the parallax site and the data sheet for the sht21.
    https://www.parallax.com/sites/defau...ample-Code.zip
    http://www.mouser.com/ds/2/682/Sensi..._V4-469715.pdf
    If you don't have the BS2 editor here is the code:
    '   File...... SHT11.BS2
    '   Purpose... Interface to Sensirion SHT11 temperature/humidity sensor
    '   E-mail.... [email protected]
    '   Date...... 12/30/02
    '   {$STAMP BS2}
    ' Program Description
    ' This program demonstrates the interface and conversion of SHT11 data to
    ' usable program values.
    ' For detailed information on the use and application of the ** operator,
    ' see Tracy Allen's web page at this link:
    ' -- http://www.emesystems.com/BS2math1.htm
    ' For Tracy's SHT1x code [very advanced]:
    ' -- http://www.emesystems.com/OL2sht1x.htm
    ' For SHT11/15 documentation and app notes, visit:
    ' -- http://www.sensirion.com
    ' I/O Definitions
    ShtData         CON     1                       ' bi-directional data
    Clock           CON     0
    ' Constants
    ShtTemp         CON     %00011                  ' read temperature
    ShtHumi         CON     %00101                  ' read humidity
    ShtStatW        CON     %00110                  ' status register write
    ShtStatR        CON     %00111                  ' status register read
    ShtReset        CON     %11110                  ' soft reset (wait 11 ms after)
    Ack             CON     0
    NoAck           CON     1
    No              CON     0
    Yes             CON     1
    MoveTo          CON     2                       ' for DEBUG control
    ClrRt           CON     11                      ' clear DEBUG line to right
    DegSym          CON     186                     ' degrees symbol for DEBUG
    ' Variables
    ioByte          VAR     Byte                    ' data from/to SHT1x
    ackBit          VAR     Bit                     ' ack/nak from/to SHT1x
    toDelay         VAR     Byte                    ' timeout delay timer
    timeOut         VAR     Bit                     ' timeout status
    soT             VAR     Word                    ' temp counts from SHT1x
    tC              VAR     Word                    ' temp - celcius
    tF              VAR     Word                    ' temp - fahrenheit
    soRH            VAR     Word                    ' humidity counts from SHT1x
    rhLin           VAR     Word                    ' humidity; linearized
    rhTrue          VAR     Word                    ' humidity; temp compensated
    status          VAR     Byte                    ' SHT1x status byte
    ' EEPROM Data
    ' Initialization
    Initialize:
      GOSUB SHT_Connection_Reset                    ' reset device connection
      PAUSE 250                                     ' let DEBUG window open
      DEBUG CLS
      DEBUG "SHT1x Demo", CR
      DEBUG "----------", CR
      ' GOTO Main                                   ' skip heater demo
    ' Program Code
    Sensor_Demo:
      GOSUB SHT_Measure_Temp
      DEBUG MoveTo, 0, 3
      DEBUG "tF...... "
      DEBUG DEC (tF / 10), ".", DEC1 tF, DegSym, ClrRt, CR
      GOSUB SHT_Measure_Humidity
      DEBUG "rhLin... "
      DEBUG DEC (rhLin / 10), ".", DEC1 rhLin, "%", ClrRt, CR, CR
    Heater_On:
      DEBUG "SHT1x heater on", CR
      status = %00000100                            ' heater bit = On
      GOSUB SHT_Write_Status
      DEBUG "Waiting 2 seconds", CR
      PAUSE 2000
    Heater_Off:
      DEBUG "SHT1x heater off", CR, CR
      status = %00000000                            ' heater bit = Off
      DEBUG "tF...... "
      DEBUG "rhLin... "
      PAUSE 5000
      DEBUG CLS
    Main2:
      DEBUG MoveTo, 0, 3
      DEBUG "soT...... "
      DEBUG DEC soT, ClrRt, CR
      DEBUG "tC....... "
      DEBUG DEC (tC / 10), ".", DEC1 tC, DegSym, ClrRt, CR
      DEBUG "tF....... "
      DEBUG MoveTo, 0, 7
      DEBUG "soRH..... "
      DEBUG DEC soRH, ClrRt, CR
      DEBUG "rhLin.... "
      DEBUG "rhTrue... "
      DEBUG DEC (rhTrue / 10), ".", DEC1 rhTrue, "%", ClrRt
      PAUSE 1000                                    ' minimum delay between readings
      GOTO Main2
    ' Subroutines
    ' connection reset: 9 clock cyles with ShtData high, then start sequence
    SHT_Connection_Reset:
      SHIFTOUT ShtData, Clock, LSBFIRST, [$FFF\9]
    ' generates SHT1x "start" sequence
    '          _____         _____
    ' ShtData       |_______|
    '              ___     ___
    ' Clock    ___|   |___|   |___
    SHT_Start:
      INPUT ShtData                                 ' let pull-up take line high
      LOW Clock
      HIGH Clock
      LOW ShtData
      LOW Clock
      HIGH Clock
      INPUT ShtData
      LOW Clock
    ' measure temperature
    ' -- celcius = soT * 0.01 - 40
    ' -- fahrenheit = soT * 0.018 - 40
    SHT_Measure_Temp:
      GOSUB SHT_Start                               ' alert device
      ioByte = ShtTemp                              ' temperature command
      GOSUB SHT_Write_Byte                          ' send command
      GOSUB SHT_Wait                                ' wait until measurement done
      ackBit = Ack                                  ' another read follows
      GOSUB SHT_Read_Byte                           ' get MSB
      soT.HIGHBYTE = ioByte
      ackBit = NoAck                                ' last read
      GOSUB SHT_Read_Byte                           ' get LSB
      soT.LOWBYTE = ioByte
      ' Note: Conversion factors are multiplied by 10 to return the
      '       temperature values in tenths of degrees
      tC = soT / 10 - 400                           ' convert to tenths C
      tF = soT ** 11796 - 400                       ' convert to tenths F
    ' measure humidity
    SHT_Measure_Humidity:
      ioByte = ShtHumi                              ' humidity command
      soRH.HIGHBYTE = ioByte
      soRH.LOWBYTE = ioByte
      ' linearize humidity
      '   rhLin = (soRH * 0.0405) - (soRH^2 * 0.0000028) - 4
      ' for the BASIC Stamp:
      '   rhLin = (soRH * 0.0405) - (soRH * 0.004 * soRH * 0.0007) - 4
      ' Conversion factors are multiplied by 10 and then rounded to
      ' return tenths
      rhLin = (soRH ** 26542)
      rhLin = rhLin - ((soRH ** 3468) * (soRH ** 3468) + 50 / 100)
      rhLin = rhLin - 40
      ' temperature compensated humidity
      '   rhTrue = (tC - 25) * (soRH * 0.00008 + 0.01) + rhLin
      ' Conversion factors are multiplied by 100 to improve accuracy and then
      ' rounded off.
      rhTrue = ((tC / 10 - 25) * (soRH ** 524 + 1) + (rhLin * 10)) + 5 / 10
    ' sends "status"
    SHT_Write_Status:
      ioByte = ShtStatW                             ' write to status reg command
      ioByte = status
    ' returns "status"
    SHT_Read_Status:
      GOSUB SHT_Read_Byte                           ' send command
      ackBit = NoAck                                ' only one byte to read
      GOSUB SHT_Read_Byte
    ' sends "ioByte"
    ' returns "ackBit"
    SHT_Write_Byte:
      SHIFTOUT ShtData, Clock, MSBFIRST, [ioByte]   ' send byte
      SHIFTIN  ShtData, Clock, LSBPRE, [ackBit\1]   ' get ack bit
    ' returns "ioByte"
    ' sends "ackBit"
    SHT_Read_Byte:
      SHIFTIN  ShtData, Clock, MSBPRE, [ioByte]     ' get byte
      SHIFTOUT ShtData, Clock, LSBFIRST, [ackBit\1] ' send ack bit
      INPUT ShtData                                 ' release data line
    ' wait for device to finish measurement (pulls data line low)
    ' -- timeout after ~1/4 second
    SHT_Wait:
      INPUT ShtData                                 ' data line is input
      FOR toDelay = 1 TO 250                        ' give ~1/4 second to finish
        timeOut = INS.LOWBIT(ShtData)               ' scan data line
        IF (timeOut = No) THEN SHT_Wait_Done        ' if low, we're done
        PAUSE 1
      NEXT
    SHT_Wait_Done:
    ' reset SHT1x with soft reset
    SHT_Soft_Reset:
      GOSUB SHT_Connection_Reset                    ' reset the connection
      ioByte = ShtReset                             ' reset command
      ackBit = NoAck                                ' only one byte to send
      GOSUB SHT_Write_Byte                          ' send it
      PAUSE 11                                      ' wait at least 11 ms
    What I am trying to do is, write code to read the SHT21 temperature and humidity.
    Jul 2009
    Ohio, USA
    mpgmike, I got the sensor to respond to my finger temp difference. Here is the code so far:
    Yes, yes, I am prototyping on a Stamp :/
    ' {$STAMP BS2p}
    ' {$PBASIC 2.0}
      tf    VAR Byte
      tc    VAR Byte
      rawT  VAR Word
      rawRH VAR Byte
      DEBUG CLS
      DEBUG "SHT21 Demo", CR
    I2COUT 0 ,%10000000, [%11100011]
      PAUSE 50
    I2CIN  1 , %10000001, [rawT]
      DEBUG 2, 0, 3
      DEBUG "rawT...... "
      DEBUG  DEC rawT, 11, CR
      rawT= rawT <<2
      tC = (rawT & $fffc) ** 17572 - 4685
      DEBUG "Deg C......", DEC tC
      PAUSE 500
      GOTO main
    Getting elevated readings on the SHT21
    The SHT21 temp says my room is 42°C (107.6°F) Actual temperature is ~ 23.8°C (75°F)
    rawT @ 42°C = 111
    don't know much about stamp code but here goes
    from the sensiron web example
    float SHT2x_CalcTemperatureC(u16t u16sT)
    ft temperatureC; // variable for result
    u16sT &= ~0x0003; // clear bits [1..0] (status bits)
    //-- calculate temperature [°C] --
    temperatureC= -46.85 + 175.72/65536 *(ft)u16sT; //T= -46.85 + 175.72 * ST/2^16
    return temperatureC;
    the reading is not shifted <<2 places the two lsb are just masked off
    so
    rawT= rawT <<2
    becomes
    rawT= rawT & ~3 ;ie %1111111111111100
    is hold master mode is that what you need ?
    try
    I2COUT 0 ,%10000000, [%11110011]
    might be better
    PAUSE 50 is this long enough at max resoloution ?
    rawT @ 42°C = 111
    by my calcs rawT should be 33132 @ 42°C
    what rawT do you actually get ?
  1. 16F877A and Sensirion SHT21
    By ctravel in forum mel PIC BASIC Pro
    Last Post: - 25th June 2016, 08:15
  2. avr code to code for PIC
    By JasonMcG in forum General
    Last Post: - 11th September 2014, 00:57
  3. Serial problem between BasicStamp code and PBP code
    By AllanZilkowsky in forum mel PIC BASIC Pro
    Last Post: - 6th April 2014, 02:15
  4. Working code but my layman approach uses too much code space
    By Christopher4187 in forum mel PIC BASIC Pro
    Last Post: - 14th December 2012, 20:44
  5. Code: Why is this code greater than 2000 words?
    By DrDreas in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 19:51
